Question about Collectibles Seeburg Vol. 3 Ref Book Jukebox 19631986 Record Player
My Seeburg STD160 no longer selects the requested record. Any idea which part is the culprit?
It seems to have it's own mind about which record to grab or ignore. I've tried to replace some of the suspects with parts I bought on eBay, but I don't know if the replacements were any good either...
I have a 1971 SEEBURG MODEL USC2 "Bandshell"
Tormat has been energized by movement over the carpet, someone touching it with a high charge or natural static in the air of a dry house. There is a procedure to deenergize the tormat with a battery. I am searching for the battery size and procedure myself. I will come back if I find out
Jan 11, 2011 | Audio Players & Recorders
I have a LPC 480 Seeburg Jukebox that scans, pick up the record, the needle touches the record, then returns the record to the carriage without playing. What can I do?
Try reading this, basically the fault can be in the mech, the amp or trip switches.
Nov 28, 2010 | Audio Players & Recorders
Seeburg selectomatic 200 [has been stored in garage for 30 years ] all funtions work properly except it will only play record for about 1 second, then eject & go to next selected record & play for...
1. Check to see that the end of record switch is OK or not shorted, same with the reject button on the back and all associated connections.
2. THESE THINGS NEED OIL! The trip lever (just to the right of the tonearm) may not be resetting fast enough, or at all, due to gummy grease. Buy the manual (eBay - any service man will insist that you have it.). It will show you where to lubricate everything. NO 3-in-1 or paraffin based oils.
Oct 24, 2009 | Audio Players & Recorders
I have a 1963 seeburg jukebox. the motor runs and turntable goes around normally. but it wont pick up the record. i think its the cam. help thanks
Your Seeburg LPC1 or LPC480 is well overdue for an electrical overhaul.
It most likely can no longer write selections into the memory, or read them out if they're being written in. No way to tell from here. A jukebox that old probably needs to have the units underneath rebuilt with new capacitors. Their lifespan is usually about 25 years, so no surprises there. This is common for all old jukeboxes. Google Vern Tisdale or Bill Bickers for the rebuild kits. You need to solder and read a schematic to do the work, or find someone who can, but the actual parts are not all that expensive.
Sep 29, 2009 | Car Audio & Video
Seeburg Stereo Phonograph Model ESL100 Q-65-H5
End of record switch out of adjustment or bad? Disconnected?
Mar 05, 2009 | Wurlitzer Jukebox 1015 One More Time...
Mechanism will not pick up records
Check out the tormat on your jukebox. It runs almost the full length of the mechanism. On the tormat is the A and B side contacts and a ground rail. You will see that on the mechanism is a arm that runs over these contacts on it it has very fine wire links (similar to those on motor brushes) these can become disconnected and may require being resolderd back into place.
Alan Hood
Jan 17, 2009 | Wurlitzer Jukebox 1015 One More Time...
Collectibles Seeburg Vol. 3 Ref Book Jukebox 19631986 Record Player Logo
26 people viewed this question
Top Collectibles Audio Players & Recorders Experts
Are you a Collectibles Audio Player and Recorder Expert? Answer questions, earn points and help others
