Question about Sony A/V Receiver
NAD AV713 receiver won't power up
In the past couple weeks, my NAD AV713 AV receiver will switch off after about two minutes, after which I just press the Power button again and everything will be OK. Last night, it decided to die on me. Could it be a burnt internal fuse? There was a thunderstorm in the day but nothing else blew or tripped. If it is a fuse, where is it located? Haven't had a reason to open up the unit so am clueless. Thanks for any info.
  • lkrudol May 22, 2008
    One of my Sony A/V receivers has somewhat the same problem. I turn it one. Gets power then 30 seconds later powers down.
    I assume there is a fuse burned out. I did crack the case but did not see any internal fuse spots and there are no external ones.
    This is about 5 years old and the silver finish models.
I had the same problem with mine AV713 it turns out to be the relais of the power unit (left site above the transformer). solution may be to replace it with e.g. good luck TB
Posted on Jun 18, 2011
My onkyo HT RC330 will not power up at all. Have had problems past couple of months with starting it but if you played around with swith it would start. Now nothing.
Try resetting the AV receiver To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press 8 ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter Standby mode.
It is possible that the protection circuitry has been activated. Remove the power cord from the wall.. Disconnect all speaker cables and input sources, and then leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect only the power cord and set the volume to maximum. If the AV receiver stays on, set then the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources. If the AV receiver turns off when you set the volume to maximum, disconnect the power cord, and contact your dealer.
If the standby light is lit it and the unit will not boot it is most likely that the protection circuit has been activated. If there is no standby light then check the fuses. These units check that the power supplies are operating near specification. If a capacitor or resistor in the circuit, or a broken solder connection the unit will shut down. Because of the temperature the thermal cycling around the power supplies a broken solder joint can occur. This will make for an intermittent operation.
Hope this helps.
26289825-owoa52fq3dbvw0lom3ojbzgr-3-0.jpg Failed resistor or capacitor
Sep 23, 2016 | Onkyo Ht-rc330 5.1-channel Home Theater...
How do I troubleshoot my Onkyo AV Receiver TX-SR603?
Based on your account it appears that you may have an issue with the power supply of the receiver.
Jun 13, 2016 | Onkyo Audio Players & Recorders
My NAD T747 keeps shutting down in Protection Mode at 6db when it used to go much louder. I cleaned the unit. Still nothing.
Modern AV receivers such as your NAD have protection circuits to prevent damage when there is a short on the speaker terminals. Look carefully at the speaker connections on the back of the AV receiver- for example, the speaker cable for front left speakers labelled + and - : there should not be any stray strands of wire that connect from + to - ; this would be a short circuit. Check each of the connections on the AV receiver as well as on the back of each of your Speakers themselves. Also ensure all connections are snug (do not use pliers). If this does not solve your problem, you may need to take your AV receiver on for a service checkup. Good luck !
Dec 12, 2014 | NAD Audio Players & Recorders
How to connect ONYZ home kit sirius to a NAD T775?
Try a factory reset of the receiver.
To perform a factory reset, press and hold the MENU and SOURCE buttons until Factory Reset is displayed. Then Power Off from Back panel for 1 minute and power up normally.
You may have damaged the receiver if you did not power off before installing the Onyx module.
Jul 27, 2014 | NAD Audio Players & Recorders
NAD T763 - i turned it on and all the lights on the display lit up and stay on. It doesn't work at all !! Any suggestions?
Have you tried doing a factory reset?
1. With unit powered ON, press the VIDEO and TONE DEFEAT buttons.
2. Display will show "AH RESET DONE".
3. Power off (from rear panel switch) and back on.
Jan 29, 2011 | NAD T763 Receiver
Hello. I get no sound out of my AVR 7000 Receiver. No cables behind has been touched in the past. I'm trying TEST TONE, and everything seems normal in the display, but still no sound. I use Preout a NAD...
You don't say if all speakers are silent or just the ones to the unspecified NAD power amp. Do ANY speakers work regardless of which device powers them? Could the NAD be the problem?
Dec 25, 2010 | Harman Kardon AVR 7000
My NAD T743 will not switch on. I haven't used for a couple of months and it was working just fine before. Now I tried switching it on using both the power button on the amp itself and the remote, to no...
Hi, have you checked the power button in the back to see if it got pressed by accident? It's a round button located right under the speaker inputs in the back.
Apr 11, 2010 | NAD T743 Receiver
NAD AV-716 Surround sound reciever, i need any info about it.
Dear sir
i would like to inform you that I mail you a letter by post and you will received it within two weeks time.
Regarding NAD AV- 716 details and spare part requirement and also i would like to remind you that my second letter stated all requirements etc.dated 8th march 2013. Please refer to the given below Email address.
Thanking you
Your's Sincerely,
Apr 04, 2009 | NAD T761 Receiver
NAD T762 stuck in standby
Remove the power plug first, try to find the Battery inside the unit,Remove it, just for a minute, or two, and put it Back, hope it work again.if you don,t find in the users manual ,how to reset !
Oct 17, 2017 | NAD T762 Receiver
Sony A/V Receiver Logo
782 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
