Question about Mitsubishi Heating & Cooling
Mitsubishi split air con keeps turning off after a few mins the timer light blinks but cleaned it and my kids are special needs and scant regulate body temp having a freak as rental is closed for ages
SOURCE: Air Filter message
Soulvisitor has it right. I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it. Thank you Soulvistor you saved us at least $100.00
Posted on Nov 04, 2008
SOURCE: Mitsubishi dlp tv green timer light blinking
timer light keeps blinking tv does not turn on
Posted on Nov 29, 2008
teeNjay
  • 5 Answers
SOURCE: WS-55909 Mitsubishi Big Screen TV timer keeps blinking
it must be recording soething have u got IQ?
Posted on Dec 30, 2008
SOURCE: i have a mitsubishi wd52528 and i have a blinking
In this case it can indicate various things, I would recommend that you get your users manual, because depending of the color and how fast it's blinking, it;'s the issue you will have.
Posted on Aug 04, 2009
SOURCE: LG AIR CON - thermistor fails
Yes - I've got the same problem too. Unit is less than 6 months old, so not happy!
Posted on Jun 17, 2010
Mitsubishi split ac indoor light blinking unit not working
The blinking is an indicator that it needs service. Call a technician! Ask if they are experienced in mini split systems. You can check the air filters. Check the outdoor coil to see if its clean or covered up with dirt. And at the breaker or disconnect, turn off power, wait 5 mins, and turn it back on. Then give it 3-5 mins to see if it will reset itself. If this don't work, call a tech/service provider! These units are troublesome to troubleshoot.
Jun 06, 2015 | Mitsubishi Heating & Cooling
Mitsubishi air con msza24yv. when we turn it on to the heating mode the operation light keeps blinking and nothing happens
Wait 5 mins after turning the unit on to make sure it is not on a pre heat, and if problem is still there check fault code on controller
Jul 04, 2011 | Mitsubishi MSZ-A24NA Split System Air...
Aircon runs for a few minutes then shuts down and timer light flashes
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
Dec 16, 2010 | Mitsubishi MSZ-A24NA Split System Air...
I have 2 units of 2 hp mitsubishi split type air-con. both units are having problem with timers. the timer will blink after 20 to 45 minutes of operation and then it will turn off by itself but the light...
the timer may have been activated at installation or by someone not fully conversant with the operation
use the remote and follow the instructions in the owners manual to turn the timer off
Sep 06, 2017 | Mitsubishi MSZ12UN Air Conditioner
When we turn on one of the air conditioners, a musty odor comes out of the blower. All the other air conditioners in the house are normal
Some times water will not drain out right need to clean the drain pan, blower wheel will also catch dirt and build up mold. The front cover should come off easy, there should be three screws on the bottom and it should pop right off after that, exposing the pan and blower wheel . Clean as needed.
Aug 28, 2010 | Mitsubishi MSZ-A15NA Split System Air...
MSH12TN Left green light keeps blinking and the air conditioner keeps going off. Room temp is over set temp.
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Aug 23, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Celestial split system air conditioner
TRY TO SHUT DOWN THE BREAK AND TURN IT ON AGAIN 10 MIN LATER
Mar 08, 2009 | Heating & Cooling
Heating & Cooling Logo
325 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
