Question about Winter Sports
My sled 1998 polaris touring ideals great half speed good high speed cuts out I have cleaned the carbs twice drained gas put new gas in still stall out still what's next
  • 682 Answers
Did you try changing the spark plugs?
Posted on Jan 03, 2017
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Jan 04, 2016 | Cars & Trucks
What would be the cause or most likely cause of noticable hesitation on acceleration of 2002 polaris xc sp 500 with tps
I've owned many polaris snowmobiles and to me it sounds exactly as the current owner states. It probably needs the carbs thoroughly cleaned, taken out and apart. I would also get new plugs as well. I prefer ngk plugs for my sleds. If you've never done it there ate plenty of you tube videos on how to clean and adjust the carbs.
Dec 09, 2017 | Winter Sports
Polaris troubleshooting
Sounds like a carb issue...make sure you have fresh ,clean gas.You havent got water in your carb/tank have you? I would start by taking the carb apart and give it a really good clean.Check all jets and orifices.Another words,take apart anything in the carb that you can,clean and replace.
Aug 08, 2014 | Polaris 2008 Sportsman 500 H.O
2010 Sportsman 500 HO
have seen this happen to my honda, water gets ingested in the carb when in deep water and settles in the bottom of the fuel bowl. you must remove the fuel bowl drain cap to drain out water
May 07, 2017 | Polaris ATV
Need a new carb or find a cheap rebuilt one at
check if ur gas line is workin rite take off tank, off n on 'switch if not that clean ur carb i had same problem clean off n on switch on gas tank if that aint problem ur carb is clogg some weres or just dirty
Apr 11, 2011 | Polaris ATV
Idling good start good but stalls if pressing throtle
there is a piece of debris floating around in the sediment bowl of your carburetor, its lodged in the high speed jet causing it to stumble and backfire......it will most likely need a carb rebuild average repair cost on this machine is around 150 dollars at a reputable polaris dealer
Nov 19, 2009 | Polaris ATV
Wont start
you need to have your compression checked. this happened to me and one cylinder was toast. they should be around 120 psi and not more than 5% difference between the two. if not clean the carbs
Jan 31, 2009 | Polaris New Genuine Polaris Snowmobile...
Backfires and bogs
put it in a warm garage overnight the other possibility is the timing is out.
Robert
Jan 22, 2009 | Polaris New Genuine Polaris Snowmobile...
Winter Sports Logo
463 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Winter Sport Expert? Answer questions, earn points and help others
