Question about Bunn Coffee Makers & Espresso Machines
Our bunn NHS Velocity was unplugged accidently. Now when we make coffee it is really luke warm and the light doesn't appear on
    An expert who has written 200 answers of more than 400 characters.
  • Bunn Expert
  • 238 Answers
This is really a home style VPR brewer (but looks nicer)
if you listen to their video (link below) they mention it has a pre-heated tank of water already in the brewer. This means the brewer needs to be pre-filled with a full pot of water and pre-heated prior to using the brewer. Unplugging this unit won't be a problem UNLESS it was emptied of tank water and not refilled when powered up.
* The unit will try and heat up the tank of water but if empty then just air which overheats the unit then blows the thermal fuse. Call for service.
* The warmer is still working but it's not hot enough to brew frequently as the warmer may take up to an hour to get the tank hot enough to brew or it may not get hot at all if it's own thermal fuse blew too.
* Final; call for service to be safe.
Aloha, ukboy57
Posted on Jan 20, 2018
  • 60 Answers
SOURCE: Warming plate boils coffee.
Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
Posted on Feb 09, 2008
  • 60 Answers
SOURCE: bunn coffee maker
It sounds like you have a pour over model and the problem is the tank isn't full. Turn the machine off (or unplug it). Put a pot on the warmer like you are going to brew coffee. Pour clean cold water into the top until it starts coming out the sprayhead (above where the coffee grounds go). Now plug it in and turn on. Let it heat up then you can brew.
The way your machine works is that there is always about 2-1/2 pots of water in the tank. The water you pour in to make coffee is actually pushing the hot water in the tank out. So, if you don't fill the tank before using it, you may be hurting the heating element since it isn't totally submerged in water.
Posted on Oct 12, 2008
  • 131 Answers
SOURCE: Warming tray too hot
You can either replace the warming element with a new one, or some people put 3 or 4 pennies on the top of the warmer tray. Don't laugh- this really does work!
Posted on Feb 12, 2009
  • 131 Answers
SOURCE: bunn commercial coffee maker plug overheats, no hot water
Most likely this is your heating element, but it could also be your main thermostat
Posted on Feb 13, 2009
  • 4088 Answers
SOURCE: the tassimo coffee maker does not heat up the
Take the machine back for warranty replacement.
Posted on Feb 21, 2010
My Bunn model CWTF35-TS heats properly sometimes and is only luke warm other times! Just wondering what maybe causing this?
Defective temperature sensor is my guess, try running white vinegar through it a few times, the sensor may have hard water deposits on it which can alter the readings.
Aug 31, 2016 | Bunn Coffee Makers & Espresso Machines
Brand new! Cleaned it out with vinegar initially, poured in and turned it on. Still waiting, nothing is coming out at all. What's the problem?
LOL add another pot of water it has a storage tank of 1 pot might take several pots to get all the vinegar out .
Dec 22, 2015 | Bunn O-MATIC NHS 10-Cup Professional Home...
My bunn makes great coffee, but after 10 min in the cup it is luke warm. Could the initial temperture be set too low?
If by meaning the coffee pot, the bottom warmer maybe loose and dropped inside the machine.Normal brew temp is 195 degrees out of tank.There also may be problem with the hi-limit ,t-stat or element.
Dec 24, 2010 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Will not make hot water. This machine is an auto feed. The water will process through the filter, but the water is only luke warm.
Sounds like the hi-limit thermostat on the boiler is damaged, also check to make sure thermostat is set correctly.
Oct 05, 2010 | Bunn RTF Coffee Maker
Water not hot on Bunn coffee maker
Check the Hi-limit thermostat on top of the tank, then the pressure stat setting and then the inline fuse and then elements.
Mar 03, 2010 | Bunn CWTF20-3 Automatic Coffee Brewer -...
Our Bunn VPR coffeemaker takes a LONG time to heat up the water. If we don't wait several hours between pots of coffee, the coffee is luke-warm at best. Does this sound like a heating element or...
We left vinegar in the coffeemaker overnight. Seems to have done the trick - water is heating up now after 20 or so minutes instead of several hours.
Jan 05, 2010 | Bunn VPR Coffee Maker
Adjusting the temperature
Our Bunn VPR was delivering luke warm coffee. The problem was lime scale buildup on the heating element. I recommend using a cleaner such as Brew Rite or a vinegar solution. If it still does not heat properly, unplug and remove the heating element for cleaning. This corrected our problem.
Jun 17, 2009 | Bunn VPR Coffee Maker
Bunn Dual Wamer not keeping coffee warm
its still under warranty. take it back for a replacement, or send it to bunn, and they will send you a new one
Dec 01, 2008 | Bunn Dual
Coffee Makers & Espresso Machines Logo
51 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
