Question about Procom Heating & Cooling
I just bought a Procom Magnum 175vt torpedo kerosene heater and it is showing C1 in the display when I turn it on and it doesn't do anything. I know before now it had never gave trouble.pleze help:.
  • 193 Answers
SOURCE: Hi, I need parts for a kerosene torpedo heater.
You need to call Portable Heater Part in Valparasio,in for replacement parts
Posted on Oct 18, 2009
SOURCE: Dayton kerosene heater 3E219B will not turn on
I have a Dayton Model # 3e219b 150,000 BTU potable heater and it runs fine with the top cover off.But if I put the cover on it will go out is less than a minute and trip the reset.
Posted on Dec 05, 2009
  • 4 Answers
SOURCE: TORPEDO KEROSENE HEATER DOES NOT STAY LIT. I
The fact that it lights up at all should tell you its not the ignitor. Does the unit have a thermostat? What temp do you have it set at? Does the unit blow into a corner or some way that the therostat is being activated to cut out by the hot air getting back to it before the rest of your space gets warm?There are so many questions.Does the flame go out first,or does the power to fan kik out with the flame? This could be related to a faulty or out of position tip over cut out,witch is for safety.I'm going to help you by teaching you to help yourself. Troubleshooting is a series of tests. Most every machine is nothing but a bunch of valves,and switches.First find out if its running out of fuel,,or cutting operation all together.If its running out of fuel to the firing rack you be able to see and hear it,,,NOTICE that it looks and sounds like its petering out.If its cutting fuel,fan,and power instanly then its most likely the thermostat shutting it off ,,or the tipover cutout. It could be a multitude of things.The best way to find out is to figure out how the machine works,,,understand the componits that make it up and what they do,,then single them out one at a time and test them to eliminate them from the list of possible problems. UNDERSTAND? If the ignitor clicks and the rack lights up,,,its not the ignitor,after all the ignitor IS igniting. Find out more about whats up with it and repost,,good luck bud.
Posted on Dec 25, 2009
heatman101
  • 43501 Answers
SOURCE: I have a kerosene torpedo
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
SOURCE: Monitor 2400 Kerosene heater service
Drain the air out of the supply line at the bulk tank shutoff valve; there should be a small hex plug for doing this. On the bottom right hand side of the heater is a round hole that allows access to a finger pump for the fuel; press this three times slowly. Heater should start!
Posted on Dec 14, 2010
Have a c1 code on my procom magnum vt220 with a line voltage of 123 volts
C1 means that prior codes need to be cleared. Press MODE/RESET button to clear Code and restart
heater.
Jan 11, 2018 | Cars & Trucks
No kerosene to orfice
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
heatman101
Feb 10, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Light turns on but will not fire
heatman101
Dec 21, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
I dont get not kerosene when i turn it on.
heatman101
Nov 25, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Oct 07, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Heating & Cooling Logo
51 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
