There are nuts or allen bolts for both the stem and the bars. They are almost certainly a metric size, but hard to say what unless one has the same bike. My guess would be a 12mm hex, plus or minus, or a 6mm allen, again plus or minus. Get a metric hex/allen set and see what fits.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Fig. 1: Exploded view of the free wheeling hub
Fig. 2: Turn the handle with your hand to the free position
Fig. 3: Note the directions in which you can turn the handle: left-free, right-lock
Fig. 4: With the handle in the free position, remove the six hub cover bolts
Fig. 5: Pull the cover off
Fig. 6: Using the correct size wrench, loosen ...
Fig. 7: ... then remove the center bolt and washer
Fig. 8: Next, remove the outside mounting nuts and washers
Fig. 9: Using a brass bar and hammer, tap on the bolt ends ...
Fig. 10: ... then remove the cone washers
Fig. 11: The free wheeling body should come off easily; be sure to discard the old gaskets
Click to Enlarge
Pull the cover off
To install:
