Question about SanDisk Sansa e250 MP3 Player
I connect my sansa sandisk to my computer and the power goes on on my sansa but my computer says there is no device connected to it.
How do I see what's on my e200 sandisk player????
Posted on Aug 05, 2009
  • 34 Answers
The power goes on or off?? It should turn on automatically as its plugged in and begins to charge. However you cannot access any of your files until its unplugged again and automatically restarts.
Posted on Jul 22, 2009
  • 378 Answers
Check whether u have istalled the proper software on ur computer. Or check connecting using a new genuine data cable
Posted on Jul 21, 2009
My sansa clip is frozen on the blue flower
One issue that people experience with the Sansa Fuze player is that the screen turns white when they are trying to use it. If you experience this common Sansa Fuze MP3 player repair issue, you need to reset your player. Hold down the "Play" and "Power" buttons for about 20 seconds. The player should automatically reset.
MP3 Player Freezes
Another issue is that the player freezes. You may see lights on the player, but it won't do anything. Follow the below steps to correct this issue:
1. Use the above steps to perform a hard reset.
2. Turn the player back on, and slide the "Power" button upward.
3. Use the USB cord that came with your player, and connect it to your computer. Only connect your player directly to the computer. Don't connect it to a USB hub.
4. See if your computer recognizes that a device was connected to it. Or, look in "Devices and Printers" folder, and see if the device shows up in it.
If your device doesn't reset, and the computer doesn't recognize it, contact SanDisk for additional assistance. Or, you can attempt to repair the device yourself.
Repairing Internal Components
If your Sansa Fuze player is out of warranty, you can attempt to repair internal components. This is an "enter at your own risk" solution, but you may be able to fix the issue. If it doesn't work, or if you damage another component, you will most likely need to get a new player.
1. Shut off the device.
2. If you don't have one, purchase a case opener tool. This is a tool with an extremely small head that is used specifically for opening up small devices.
3. Place the head of the tool in the seam of the device, and rise up the faceplate. Do not do this forcibly, or you'll break the ribbon cable connected to it.
4. Remove the ribbon cable from the faceplate.
5. Examine the battery cable. If this connection is loose, your Fuze player won't turn on. Plug the connection firmly into the port.
6. Check the LCD screen connection. A loose connection here means that you can't see anything on your screen. Disconnect the cable from the port, and reconnect it.
7. Reattach the cable to the faceplate, and reattach the faceplate. Turn the device back on.
These Sansa Fuze MP3 player repair suggestions may not fix all issues. If your player is still not working properly, either take it back to the place where you bought it, or contact SanDisk for additional help.
References
Fixya.com, http://www.fixya.com/support/t4267400-sandisk_fuze_4gb_locked_lights_will_not
SanDisk, http://www.sandisk.com/products/sansa-music-and-video-players/sandisk-sansa-fuze
Jul 18, 2011 | SanDisk Sansa Clip MP3 Player
Sandisk e260 froze after power up.
sounds like a firmware program problem and will have to be replaced. You could download an updated firmware but you will have to get a pc connection.
After your device is plugged in, are you able to go to  "my computer" and see a drive folder that has your device on it.
Mar 01, 2009 | SanDisk Sansa e260 MP3 Player
When i start up my SanDisk Sansa E260 it starts then resets
I had the same problem when I connected to the computer. So I used my friends Labtop definite 2.0 usb. Did you try to update your sansa click on link and download install run connect sansa when asked.
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
I hope this works
Feb 19, 2009 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa Express MP3 player stays at SanDisk logo
You may need to get a firmware update from this web site: http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Remember that you need to back up all of your information before doing the update.
Jan 01, 2009 | SanDisk Sansa MP3 Player
Sansa e260
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Sep 02, 2008 | SanDisk Sansa e260 MP3 Player
Sansa Media Disc freeze/restart
Thank you
Computerrep
Aug 22, 2008 | SanDisk Sansa e200 MP3 Player
How can I get my Sansa m250 to power on??
If your Sansa Connect won’t start check to make sure the device is
charged and the hold switch is in the unlocked position. If the device still
will not start, you may need to run the Sansa Device Recovery application.
With a copy of the Sansa Device Recovery application installed on a PC,
you can connect your to the device via the USB cable to the PC, and
restore the device software to an uncorrupted state. However, all of your
subscription settings and content will be removed from the device.
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
or google the sansa connect recovery tool
Mar 06, 2008 | SanDisk Sansa m250 MP3 Player
It shows Sandisk logo and freezes there
Remove the SD card and try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
Wont start!!
This will take care of it.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Best of Luck.
Oct 15, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
209 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
