Question about Saws
To loosen blade of southern cross electric lawnmower Turbo 2000 - the motor also turns even when holding the blade - and should it be loosened in the opposite direction of the blade turn?
2 Suggested Answers
dogsled48195
  • 411 Answers
SOURCE: MTD ride on lawnmower: I
both blades are turning the same way should loosen the same as other
Posted on Feb 12, 2011
Electric mower motor rewinding
contact electric motor re conditioners
Oct 09, 2017 | Cars & Trucks
My lawnmower starts but has no power
Make sure the bolt holding the mower blade hasn't loosened and check to be sure the blade is properly centered on the crankshaft end plate.
Feb 24, 2012 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Is there a fan clutch on a 2000 toyota solara
NOPE YOU HAVE TWO ELECTRIC COOLING FANS. YOU HAVE TO REMOVE FAN SHROUD FROM RADIATOR THEN YOU HAVE TO REMOVE FAN FROM MOTOR USING SOCKET AND WRENCH.HOLD FAN WITH HAND WHILE LOOSEN FAN NUT.AFTER YOU REMOVE FAN BLADE YOU HAVE TO REMOVE THREE SCREWS HOLDING FAN MOTOR TO SHROUD.
Jun 20, 2011 | 2004 Toyota Solara
20" lawnmower 3.75HP Model #11A-072A022
Lawn mower blades bolts are reversed thread. Its righty loosen, lefty tighten....
May 07, 2011 | Garden
Shaft turns while trying to remove blade on B&D MM875 elec. mower
Here's the scoop on the MM875: it has a plastic piece called a "blade insulator" (part # 241381-01) that "locks" the shaft to the blade, so that you can remove the nut by stopping or blocking the blade. If it has been damaged or stripped out, then stopping the blade won't do anything. However, the metal spacer directly under the nut IS still locked to the shaft (because of its shape), so you can use a pipe wrench or something to hold that in place and unscrew the nut. You might even be able to get someone in a home improvement store to do this for you. But you will still need to replace the insulator, which is only a few dollars.
Jul 22, 2010 | Black & Decker 19" Electric Lawnhog...
Repalce blade on 700 series craftsman lawnmower 917.374541
Tilt the mower back in a direction that brings the front (spark plug end) of the engine up and the back of the engine down if possible. This keeps the oil from going places it doesn't need too.
Under the deck of the mower you will find the blade bolt It will be in the center if the blade and should be a hex-head bolt Around the 1/2 " size. You will need to either jam the blade where it can't turn the motor while you attempt to loosen the blade bolt or enlist a helper wearing gloves maybe to hold the dull side of the blade still (if you can't hold it yourself). For easier removal of the blade bolt the next time around, coat the threads with Permatex Anti-Seize Dry Graphite Compound. You won't have it stuck or rusted next time.
Jul 10, 2010 | Craftsman Garden
The spinning part at the base of the lawnmower has stopped spinning, and i cant figure out why. i think it has something to do with connection issues in the nick and the connection to the lawn mower it...
Hello. Most likely the nut which holds the blade tight has loosened enough that the motor spins the shaft but the blade just sits there and doesn't spin. This is an easy repair. You will need a large crescent wrench, or the properly sized open end wrench and a 2 foot long piece of 2x4 lumber. Use the lumber to "lock" the blade against the frame once you have the nut fairly tight. Then give it one more turn to be sure the nut doesn't loosen up on you again. It is best to do this job without turning the mower upside down as doing that will cause the oil to go into the air filter and then it will not start. If this is all basically greek to you ask a neighbor or a friend for help. It is really only a two minute job. J.
May 30, 2010 | Garden
Blade is loose, turning nut just turns motor.
put a screwdriver in the bottom of the motor that should do it
Jul 26, 2009 | Electric Lawn Mower
Cannot remove blades
hi! there,
there are two type of removing the blade of electric fan,one is there is a center knob with mark arrow loosen and tight direction at the center holding fan blade, this to lock fan blade on its shafting. to remove fan blade.loosen holder knob on clockwise direction while holding the fan blade,to release the knob check the arrow on the knob. after loosening knob pull out blade from the shafting.
the other type the fan blade has lock in bolt at the back side of the fan blade bolt in on the shafting of the fan, you need here a tools such as set of socket wrench small one to loosen the bolt
after loosening lock in bolt, pull out fan blade.
besure doing this tha electic fan was unplug to elecrtic source. have a nice day.just rate me,thank's
Apr 18, 2009 | Heating & Cooling
Saws Logo
110 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
