Where can I get a plastic washer no.12 on diagram for my machine
My Whirlpool washing machine Model number ghw9400pwo is shaking vilently and has started to wear on the plastic around the front of the drum causing plastic pieces to fall off of it. It was bought in 2005...
with nothing it it put one of the flippers at the 12 o'clock area and push up and down. if it clunks and it prob. will the rear bearing is going bad, the more it moves the more bad it is. if it is the case its time for a new washer. the repair of the unit will be more then its worth.
Jan 10, 2011 | Whirlpool GHW9400 Duet Washer
How do we empty the filter on Hotpoint WMA 12?
Remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Reassemble and test.
Dec 19, 2010 | Hotpoint First Edition WMA12 Front Load...
I have a Kenmore Series 70 top loading wash machine that leaks. It is approx 12 years old, model 110.4767290 (canadian). It has a 2 inch crack in the bottom of the plastic tub. I tried filling with expoy...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The numbers following the 110 (which means it's made by Whirlpool) are usually 8 digits. Using the number that you provided, I couldn't find your washer on the Sears site. You will want to verify the number (usually by lifting the lid) and/or check for manuals / parts site from the following Sears site:
http://www.managemyhome.com/
Sears has replacement tubs (at least for my 12 year old top load for about $116.75 (U.S.) but you may be able to get one from Whirlpool for about the same cost. If you can get to the diagrams on the sears site. they often have "Manufacturer Authorized Substitutes) which are Whirlpool numbers.
FOR EXAMPLE, SEE THE SITE FOR OUR WASHER AND YOU'LL SEE EXAMPLES OF PARTS, DIAGRAMS AND COSTS.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26902691&pop=flush
Jun 22, 2010 | Kenmore Washing Machines
I have Kenmore Elite washer (110.24942301) with bad timer, but I can't get to the timer to change it. No screws visible and no plastic caps on sides. There are plastic hinges screwed on behind the top...
Here is a link to a diagram of your control head on your washer. Make the diagram full size and zoom in, (the options to do that will be in blue on the border at the top of the diagram). Use a flat blade screw driver to push from the front on the clip, (#8 in the diagram), and the head should release and lift up. Good luck and don't forget to write back if you need further assistance and/or If I have helped you fix it! Good Luck! Click on the link below.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11024942301&productCategoryId=0153200&brandId=0582&modelName=RESIDENTIAL-WASHER&diagramPageId=00002&componentDescription=CONTROL
May 13, 2009 | Kenmore 24032\24036 Top Load Washer
Washer not aggitating right
REPLACE AGITATOR DOGS THESE ARE PLASTIC PIECES THAT CAUSE THE TOP TO AGITATE THERE IS A SCREW UNDER THE CAP OF THE AGITATOR REMOVE IT AND PULL UP THEN YOU WILL FIND THE AGITATOR DOGS PART # 80040
Apr 30, 2009 | Washing Machines
Washer will not complete a wash cycle and panel lights become dim
ok take the bottom panel off you will see a tech sheet usually on the right side of the unit in plastic. this has everything you need. but the clean out will be directly in front of you when you take the bottom panel off. clean that usually you will find lots of things in there plugging the path for the drain causeing tons of problems with your washer.
Mar 31, 2009 | Kenmore 45981 Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
