Question about KitchenAid Refrigerators
I have a Kitchenaid KSC25INSS01 and noise is coming from the air diffuser. Refrigerator and freezer seem to be working fine. I have a video that I can show you of the problem.
Sounds like 2 beeps at 1/2 second intervals followed by a chugging/whirring sound for about 1.5 seconds. Then process repeats itself.
I have the same issue with the same model. I think it has something to do with the defrost timer. Will wait for an experts answer.
KitchenAid Superba fridge section not cooling, freezer is cold.
You have done a good job of attempting to diagnose by process of elimination, but this is a more complex system. I have provided some links below to assist you in diagnosing your problem. Links courtesy of www.repairclinic.com.
1. Ascertain that the evaporator fan is operational. This may be controlled by the Door Switch, (No.4) and could cause the fan to be inoperable.
2. Ascertain that the Fresh Food compartment light goes off when door is closed.
3. The air diffuser may be faulty by not controlling the air flow from the freezer properly
Tip: Always maintain dual temperature control settings at equal or +/- 1 setting position.
How refrigerators work:
http://www.repairclinic.com/0088_4_3.asp
You will need to verify operation of the following components listed below:
1. Evaporator fan motor
2. Air diffuser assembly
3. Light switch for refrigerator/freezer light
4. Door switch
Click on the links to identify the parts listed
1.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di921541&PartID=921541
2.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di827263&PartID=827263
3.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di438889&PartID=438889
4.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di586519&PartID=586519
Parts breakdown diagram:
http://www.repairclinic.com/Refrigerator-Side-By-Side-Appliance-Diagram
Aug 13, 2009 | Refrigerators
No air coming from air diffuser assembly in fridge
through other postings on your web site I was able to determine that the return air flow vents for the refrigerator (diffuser air) was blocked due to frost. I defrosted the unit and it is working fine now.
Jan 05, 2009 | Refrigerators
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Apr 06, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Kitchenaid Side by side refrigerator section is not cooling the freezer is over cooling
SINCE THE FRESH FOOD SECTION GETS ITS COOLING BY AIR CIRCULATION FROM THE FREEZER, THERE MUST BE A RESTRICTION IN AIR FLOW SOMEWHERE. CHECK THE FREEZER EVAPORATOR AND FAN TO BE SURE THAT THE FAN IS RUNNING, AND THE EVAPORATOR IS NOT RESTRICTED WITH FROST. CHECK THE DAMPER OPENINGS FROM THE FREEZER SIDE TO BE SURE THEY AREN'T ICED OVER. IF IT IS AN ELECTRONIC CONTROL, CHECK THE THERMISTOR CIRCUIT FOR PROPER RESISTANCE. TECH SHEET INSTALLED BEHIND THE TOE PLATE SHOULD GIVE THAT INFORMATION.
Mar 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer is very cold and refrig is not
make sure the return air is open, that is a vent on the side wall of the refrigerator above the crispers on the center mullion. and check to see if the evaporator fan motor is running.
Jan 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is very cold and refrig is cool
Hi. As long as the evaporator motor is working its one of the two as you mentioned. If the compressor and evaporator fan is running and the refrigerator door has been open, with the freezer door closed, reach into the back left top where the diffuser is located and put your hand in front of it and see if any air is coming out. You should feel a moderate breeze. If not, open the freezer door with your hand in front of the diffuser and if the air comes out good now, the return air is blocked (normally ice build up). If no air is felt, the damper is most likely bad. Use a mirror and see if the damper is closed or frosted up. This can happen from the refrigerator or freezer door being left open for some time.If you have a mechanical damper, make sure it is set in the middle. You want more air to the refrigerator section. Email me on ebay, user name themackshack if you need parts! Good luck, Mack
Jan 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool side by side refrigerator not cooling
it might have a defrost problem check timer heaters and defrost limiter if it has a build up of ice in the freezer on back panel if not try turning the control for the food caompartment to let more cold into the food compartment
Aug 29, 2007 | Refrigerators
Frezzer is fine but fridge is warm
See if cold air is coming out of the air diffuser top-back freezer side of fridge. A common problem is a bad air diffuser assembly. Sometimes it may freeze closed and break when it tries to cycle. The freezer usually works fine.
Aug 05, 2007 | Kenmore 53602 / 53604 / 53609 Side by Side...
Refrigerators Logo
48 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
