Question about Dryers
Dryer comes on nheat comes out but cloths do not dry takes several times for it to dry
    Uploaded 5 video answers.
  • 47 Answers
I had that same problem on my mom's kenmore dryer. I replaced the temp control which has 4 wires and mounts on the filter housing.
I located a cheap one on ebay: Genuine OEM 3387134 Whirlpool Kenmore Dryer Cycling Thermostat eBay
Posted on Dec 30, 2016
    Top Expert:
  • Dryers Master
  • 49,276 Answers
Check for a plugged heat outlet
Dryer pauses several times and takes 6 hours or more to dry it does not heat.
so it is drying clothes but is taking forever:
so the dryer is not heating:
these should fix the problem Good Luck Tim
Feb 19, 2011 | Danby DCD5505W Electric Dryer
Clothes not drying. Dryer feels hot but clothes remain damp through several cycles.
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
Dec 28, 2010 | Whirlpool Dryers
Heats up but takes several cycles to get clothes dryer
Check for a restriction in your exhaust vent. not just behind the machine but all the way to the outside vent,should have good warm airflow at outside vent. With no good air flow you have no way to get rid of the moisture. and all you will end up with is warm moist clothes. this can happen slowley happen over time and next thing you know it takes several cycles to dry the clothes .it cost a lot to dry them this way
Aug 08, 2010 | Amana NED5400TQ Electric Dryer
Clothes not dryin
clean out the exhaust vent tubes thoroughly. the moister sensor will shut down the high heat if clogged full of lint
Jun 06, 2010 | Estate EED4100SQ Electric Dryer
Dryer model #le86000kq1...clothes are taking long time to dry..have to repeat drying process several times before clothes are actually dry
It may be as simple as dryer duct needs cleaning. I provide that service to several of my commercial customers in group homes. When the duct work is partially closed from build up it reduces dryer efficentcy. Also if you have flex vinyl duct work replece it, its a fire waiting to happen.
Nov 11, 2009 | Whirlpool Dryers
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
If you have'nt done it yet, my first suggestion would be to have the vent on the dryer (inside the dryer all the way to the fan chamber) and the dryer vent pipe to the outside thoroughly cleaned.
That is leading cause for dryers not drying completely.
Also, has the dryer always been a bit slow to dry cloths? If so, try leaving a window open the next time and see if it makes a difference. Some houses are sealed so tight, the dryer can't get enough air. A typical dryer will use up to 200 cu/ft of air per minute when drying. If there is not sufficient air, the cloths take longer to dry.
Good luck, let me know.
May 12, 2009 | Maytag PYG2300A Gas Dryer
Dryer is heating but not get clothes dry...
make sure you have a strong air flow from the dryer it self take hose off and run the unit it should force your hand away if not your dryer is stopped up you will have to take fan casing off and clean (the metal going to hole for vent hose) if you do go outside and make sure you vent outside is opening and free of lint also wash your lint filter with warm soapy water fabric sheets stop them up and cause longer drying time
Nov 12, 2007 | Roper REX4634KQ Electric Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
