Question about Exercise & Fitness
I have a fit bit charge 2. I have the reminder to move set fir every hour from 7:00 to 6:00. I did not feel the vibration at 7:50 AM and do not know why
4 Suggested Answers
  • 10865 Answers
SOURCE: My toyota 1990 is vibrating when moving at 40 to 45 kmp
Hi there. There are a number of things that can cause these symptoms. The most common is that the tires on the front are worn unevenly or that the car needs a front end alignment. take the care to a garage that you trust and have them check the tires and the front end alignment. good luck.
Posted on Mar 18, 2009
sawdust46694
  • 398 Answers
SOURCE: What causes the air conditoner to vibrate? will
take the covers off and look for dirt dobers nest, they are made of mud like stuf. spray some water threw a squart bottle use needle nose and a screw driver to bust them. this hapend to my home and motor home.... bill
ps might be some other debree in the fan.. take a look you will be suprised how easy it can be.
Posted on Jun 30, 2009
  • 11 Answers
SOURCE: I have a 2007 ram 1500. when driving above 50
tires out of balence
Posted on Jul 09, 2010
I bought a 93 tercel with 108,000 miles on it, when i go 50 miles a hour i can hear a faint alarm beeping away. any ideas what it is?
Some cars are fitted with a speed reminder setting. If you exceed the speed that has been entered then an alarm sounds. Maybe a previous owner has set it at 50mph. You can drive at any speed but the reminder will beep if you exceed its' setting. Not saying you definitely have one fitted but might be worth googling or contacting a Toyota dealer.
Aug 06, 2015 | 1993 Toyota Tercel
Can someone tell me what are the main features on the Sony SW2 Smartwatch? I'm finding all the information a bit confusing.
Think of the smartwatch as a smartphone but in miniature so it fits on your wrist.
You can get email, facebook, twitter.
It's touch screen and has a vibration that can remind you about appointments or when you're getting calls.
It's just a way of making smartphones even more accesible to users.
Mar 06, 2014 | Sony SW2 Smartwatch 2
Vibration when going about 40 to 50 miles per hour feels like whole underneath is vibrating
IF you have rear wheel drive then check the u-joints for wear/loose. Check slip joint for wear . Check rear engine mount is in good condition. Check wheel balancing
Nov 25, 2013 | 2006 Saturn Vue
Reset to factory settings
To factory reset your tracker:
1.Attach the charging cable to your tracker and plug the other end into a USB port.
2.Press and hold the button for approximately two seconds and without letting go of the button:
3.Remove the charging cable from your tracker.
4.Wait about seven to nine more seconds after removing the charging cable.
5.Let go of the button and hold it down again.
6.After "ALT" and a white screen flash, let go of the button and hold it down again.
7.After you feel a vibration, let go of the button and hold it down again.
After you see "ERROR," let go of the button and hold it down again.
After you see "ERASE," let go of the button. The tracker will turn off.
8.To turn your tracker back on, press the button or attach the charging cable (make sure to plug in the other end of the cable). If the time on your tracker reads 0:00, the reset was successful.
9.Next you'll tell your Fitbit account that you're setting up a new tracker.
10.If you use the Fitbit app, tap or click the Account icon (User-added image) and choose Set Up a Device.
11.Follow the instructions to replace your tracker.
Apr 14, 2013 | Fitbit One Activity Tracker, Black
2006 freestyle was just inspected by a ford dealer 4 days ago. according to the technician, pads and rotors are good. The car vibrates alot when brakes are applied for an average stop. I can feel the...
a visual inspection would not show up a warped disc/rotor,so as a first step(cheapest)i would change both front rotors/pads but buy genuine parts.(rotors only last about 50/60k before you need to change them anyway)and as mentioned to another person,by the time you buy the bits, take the wheels off,remove the calipers etc you might as well take it to autozone and keep your hands clean.....it only takes an hour, tops....
Jul 23, 2010 | 2006 Ford Freestyle
I have a cub cadet lt1550 and the oil light is blinking and a ch6 code is flashing. checked the oil and it is full. just wanted to know if something is wrong or that is a reminder to change oil and if it...
The mower is programmed to remind you to change the oil every 50 hours. It will continue blinking for 2 hours. It will begin blinking again at 100 hours and every 50 hours after that. There is no manual reset.
May 20, 2010 | Briggs & Stratton Garden
Car steering
There could be numerous problems going wrong. Your car is rear wheel drive so it could very well be a bad wheel bearing. If it is extremely loose it can cause a shake in your steering wheel. You may want to check on the condition of your tires and rims especially the left front. A bad tire can cause a shake and pull. If you know how to use your car jack you can try jacking the vehicle up, and put both hands on your front wheel and move it manually to see if there is looseness. Most shops only charge about 1/2 hour to shake down the front end. BMW parts are expensive so be prepared!
Jul 19, 2008 | 1994 BMW 3 Series
Static line
it might sound strange but i think the screen has dropped. I have seen this happen before, is it just one line or 2 as the screen is fitted in the shield, its held by a thin rubber sometimes it can drop when the tv is being moved about or in a lot of vibration like moving it about in a car. now this may sound strange but the last time i fixed one i used 6 match sticks and clean them up and put them in the screen housing and it keep the screen in place after that. but beautiful when removing the screen case as you can inadvertently damage the screen, the screen is only a thick as a bit of cardboard. i suppose you could even put the tv upside down on the bed or something soft and wiggle the screen back into place. this would not damage thew tv and you will not have to take it apart.
Jul 03, 2017 | Samsung HP-R5072 50 in. Plasma HDTV
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
