My pc stuck and wond pass flags - Office Equipment & Supplies
I have canon 2900 and it having every time paper jam problem please help me
Analyse where paper jamming is happening? remove right left back & top covers..press door switch, shoot print command. Remove cartridge after paper jam, check upto where paper travel?
1. If paper jams with curl foldings in cartridge bank area..before entering the fuser assmbly..
# Teflon sleeve not rotation properly due to this paper not passing through it result curl foldings..Replace teflon sleeve..
2. If paper passed fuser assmebly little bit(near about 2-3 inches.
#Problem with paper out sensor/flag. clean sensor, check sensor flag movement & spring.
3. Check registration paper sensor located back side.
# while passing the paper, sensor flag has to act & once paper out it has to reach home,other wise paper jam error will appear.. check flag spring.
Aug 27, 2012 | Office Equipment & Supplies
Paper jam 2 error
There is a little plastic lever/flag which detects the paper at the rear, just after the heat section. I think on this model it can just about be seen by opening the rear door, it should be in the middle of the black lower paper guide section. The "flag" should be protruding slightly to be activated when the paper passes. However if it is stuck down (hence giving you false paper jam message) it will be more difficult to see! Use a decent torch to help see.
Hope this will help you.
Jul 07, 2011 | Samsung ML-2550 Laser Printer
Keeps saying i have a paper jam but I don't see a lick of paper when i open it up
Try to restart it by shutting down the pc and the printer. Pull out the the power plug of your printer and unplug the plug of your printer from pc. After that plug -in again the cable to your printer to pc and plug in the power cable of your printer after that turn on your pc and your printer.
Jul 04, 2011 | Office Equipment & Supplies
I was wondeing if I need a anti theft by pass module for a 2008 dodge ram with a viper 5900sst alrm remote start
yes a spare key will be consumed into the installation using part #
556uw $20-$30
or use canmax part but very expensive $100+ no key consumption.
Nov 20, 2009 | 5900 SST 2-Way Security System / Remote...
How do u get passed the american level where your on the flags ?
you have to use homerball and roll onto the ramp, hit statue really hard, then the flags will move, jump up to get more food on the flags and keep doing that until the hamburger falls
Oct 14, 2009 | EA - Electronic Arts The Simpsons Game for...
Canon PC 941 copier. Paper jam indicated with no paper.
Can be that sensor of the passing of the paper or was broken off flag, or sensor has wedged in position james, more often such can be in block of the fastening, when paper stuck extract. Try its see, this possible behind do. Good luck
Sep 04, 2009 | Office Equipment & Supplies
HP LaserJet 4 Plus Printer gets a paper jam every time
please try to check your print cartridge .... change the print cartridge to a new one , it should be the original type designed for the printer.
try also to clean the interior surfaces of the printer... you can use a blowing machine or use a brush to remove all dirt and stacked materials in the printer.
thanks
May 20, 2009 | HP LaserJet 4 plus Printer
Texts won't send - get stuck in outbox
Check your SMSC number (should be on your sim). If not there then ring your network provider and thei will go through settings with you.
May 12, 2009 | Nokia N95 Cellular Phone
Black flag problem
You got to do under green flag. and u cant do it with your speeding.
Apr 05, 2009 | EA Sports Video Game Consoles & Games
Error: 09,035.43:27650
You have a Cyan ( blue) ink stick stuck or a broken ink stick in the ink loader.
Check the cyan slot carefully, one of the sticks has not moved properly, The machine is not seeing the ink loader moving indicating a stuck cyan stick, Here is the info.
Ink stick count faults (error code 09,03x.4x) are declared when the printer melts 2.5 ink sticks without tripping the color's ink out flag. The ink out flag is used to physically count ink sticks passing thru the ink loader.
Verify that the ink sticks are Xerox 8500/8550 ink sticks. Manually verify that the ink stick are correctly loaded and are able to advance in the ink loader chute. Check for broken ink sticks which can fool the ink out (ink stick counting) sensor.
The ink stick count fault can only be cleared by powering up the printer in internal diagnostics mode. Then scroll and to the Functional menu item Clear ICS Fault.
Dec 19, 2007 | Xerox Phaser 8500/DN Printer
k24674
jasbo
jasbo
