Question about Microwave Ovens
I need a owners manual for a specific micro grill, MICRO GRILL
I have one , but don't know how to use it. I need a manual for a microwave grill, it's name is MICRO GRILL, DISTRIBUTED BY BODY BY JAKE GLOBAL, LLC. It sent me to YouTube but no help there.
MicrowaveSvc
  • 9098 Answers
SOURCE: Goldstar Convection Micro/Grill 800W
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 29, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: panasonic inverter dimension 4 microwave
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Sep 06, 2008
SOURCE: Cannot remove the front grill of GE Micro to replace filter
I have a new ge 1540 and needed to remove the grill to install the charcoal filter.
After removing the two screws on top, you need to slide the grill about 1/2" to the left. Then the grill will wiggle loose and can be removed.
Posted on Dec 11, 2008
  • 86 Answers
SOURCE: Where is the 10 amp fuse on my delonghi micro/combo/grill please
Hi, I take it that this is a combi microwave? Some of these have settings on the front to microwave/grill/etc... so make sure its on the right one first!!
If you have selected the correct one then the m/wave does not work it could be several things!
Microwaves run to earth and need diodes to do this if these break down it will not m/wave! It could also be a internal fuse? ( but very unlikley if everything else works) Then you have the Mag or transformer which could be down to! M/waves run on a high power side and a low power side. The low power will not hurt you to much but the high power side will. My advice to uou is not to touch as it could be fatal as these things carry a high charge even when they are unplugged!
Posted on Dec 28, 2008
  • 8909 Answers
SOURCE: need instruction manual for
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Dec 23, 2010
Panasonic microwave grill not working
I would call customer service with the model number to see if this is a known issue. You might also call a authorized Panasonic repair center and chat with them to get some idea of what a possible repair might cost.
Dec 04, 2012 | Microwave Ovens
The interior bulb of my ge spacemaker oven jvm1490sh01 has blown out. How do I go about replacing it? Thanks
HI,
I looked up your model and found that if you remove the grill above the door, you can ***** the bulb area. With the grill removed, in the middle left side, you will see either a black or metal looking cover, if I remember correctly you slide the cover back toward the wall and lift up. There is where your bulb should be.
If you would like unplug the micro way before you enter this area for safety only. I normally don't but I know what I am looking for.
Good luck, be safe
Jul 23, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My LG MICROWAVE OVEN IS MODEL MC-7836M CONVECTION MICRO GRILL IT IS RUNNING BUT NOT HEATING and GRILL ALSO NOT WORKING
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Jul 27, 2010 | LG LRM1230W Microwave Oven
Can't remove the vent grill
Two problems found. The electrician that installed the micro. installed it incorrectly. The fan was supposed to be turned so that the exhaust would go through the pre-installed duct in the wall. To remove the grill, there is two screws on top of the micro. which have to be removed. The builder put in a deeper cabinet that covers the screws because it looks better. To fix it I have to drop the micro, take off the grill, clean it and all the grease off the micro., replace the charcoal filter, turn the fan so it will exhaust through the duct and reinstall the micro.
May 27, 2009 | Kenmore 80412 Microwave Oven
Emerson Microwave Oven and Grill
The micro wave part is not working in your oven. It is mainly due to to the defect in the magnetron and the related components like high voltage side fuse and high voltage diode etc. you can check the fuse and the diode with a multimeter. If they are ok replace the magnetron.
May 23, 2009 | Microwave Ovens
Instructions for Sharp R953 900wt jet convection grill microwave
i have need instruction book how i can use sharp micro wave oven r953
Dec 27, 2008 | Microwave Ovens
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replace oven ligh on LG microwave
Hello Bob,
Here is a link to the service manual for your micro.. you should find everything you need to know about testing it and disassembling it as well.. Hope this helps you..
http://136.166.4.200/contents/Microwave/LMVM1945xx/LMVM1945_Service_Manual.pdf
Hope this helps you.. if it does, please rank this response accordingly..
Good Luck
Sep 30, 2008 | LG LMVM1945 Microwave Oven
How to Remove an OTR Microwave from the wall
first you need to take the grill off the front of the micro there should be two screws on the very top of the unit that allow you to take the grill cover off there also should be two screws in the cabinet above the micro that hold the unit in place some models have a silver hook or latch on the left side that you pull forward to release the unit from the back plate do not pull on this till you have taken out the two set screw on top of the cabinet after doing this the micro should come down
Mar 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
57 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
