Question about Microwave Ovens
Hi i am trying to find out what the output power rating is for a bush oven model number bsopt60x
What is the output power of National NN-C2000P microwave oven?
the pwr rating is normally on the label.
google for a manual
Feb 02, 2016 | Microwave Ovens
On model mw8626w can i use it in my semi with a 1000 watt inverter?
Take a look at the oven's electric rating information. It should be on the label with the model and serial number, and it will tell you how many amps the oven needs. Power in watts is volts times amps, so a 1000-watt inverter is good for about 8 amps at 120 volts output. Some inverters also use a peak rating, meaning power than can be delivered for a short time. The continuous power may be less than that; you'll need to look at the inverter. As long as the power needed by the oven is within the inverter's ratings then you'll be able to use it. Otherwise you'll need to shop for one with more output power.
Jul 15, 2011 | Emerson MW8626W Microwave Oven
What is the wattage of model R-9H84B
That model had 900 watts of microwave power output, and the convection outpout was 1450 watts.
Jun 18, 2011 | Sharp R-9H84B Microwave Oven
Hi, I have a Bush Fp026 food processor and am having problems getting the mixer/processor element to work. The blender is fine, but how do I get the mixer working!? HELP!!
Are you sure you have the Model Number correct. I believe the Bush appliances are also marketed under the Kewwood brand name. Was able to find information for the Kenwood FP260. When you see the picture on the front you should know if it is applicable to your product,
The instruction book is available here.
The machine will not work if not assembled correctly. Check the schematic provide for assembly and make sure you are putting the processor together correctly. The fact the blender works fine suggests that when you assemble the processor it is not engaging with the safety switch which would allow power to engage.
Information on other models can be found here.
Feb 02, 2011 | Microwave Ovens
My model is nn-s253wf, micowave stopped working, no power, checked circuit breaker, is ok ?, unplugged, then plugged back in, still no power ?
Inside the external case and usually to the right left ( from Front) in some models There is a 30 amp fuse ( This may vatry on oven output amperage) Replace that and you should be back in cook mode.
Removing the case you should remember to disconnect from the power plug.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Panasonic NN-S252WF Microwave Oven
What is the wattage of modle number wes0930dn1bb and is there a power setting for 650 watts
Per the owner's manual, it is an 800 watt unit.
Click on this link, then enter your model number "wes0930" and then click on "Use and Care Manual" to download your manual:
I've never heard of a microwave that lets you change the cooking power output. The magnetron tube that produces the microwaves only has off or on modes. No "low wattage" mode.
The "percentage cooking power" adjustments you can make on the control panel only cycle the microwaves on and off to reduce the amount of time the oven is actually cooking.
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung Microwave repair
This would be the turntable coupler, and you can get it here. The best way is to search by model number. If by chance you don't find it, call them at the number on their site.
You need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 24, 2008 | Samsung MD800SC Microwave Oven
Detemining the Wattage of a Samsung Microwave Oven
600 watts.
Samsung MU3050W Microwave Oven Consumer Rating: sdc_stars_sm_5.gif See 1 review | Write a review Information: Product details | Product accessories 1-Stage Programmable Cooking. White Cabinet. 15 Min. Timer Optional Mounting. 0.5 Cavity. 600W Output Power IEC-705 Mech. Control Type. MW Distribution - Turntable. 1 Power Level.
Jul 22, 2008 | Samsung Microwave Ovens
Microwave wattage at different power levels
Usually the output power is adjustable from 10% to 100% in 10% steps relative to the full output power rating.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
Apr 15, 2008 | Panasonic NN-MX25 800 Watts Microwave Oven
Don't understand how to set the power levels
Is your full model number MW8675? If not, please post your full model and let me try again.
Normally you press Time (or Time Cook) then the digits of the time, then Power, then a number from 1 to 9 (which stands for 10% to 90% power level), then Start.
On some models you just press the digits of the time, then Power, then a number from 1 to 9 then Start.
Many Emerson microwave manuals are available for free download here:
If your is not there, try one with a number close to yours.
Feb 24, 2008 | Emerson MW8777W Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
