Question about Cell Phones
I need to put time on my phone - Cell Phones
Phone do not work
What you need to do first of all put off the powwer supply i.e the phone battery need to be remove from the phone for some time allow it then put the battery back to the phone phone or it position if possible.
Then put on power of the phone if the problem remain same then it could be that the phone battery will need to be recharge .please note this if the phone battery is well charge and the phone problem remain same then you will have to replace the the phone battery if you are able to get to the phone battery.
Please note if all this instruction has been put to place then the phone will surely need to be rebut that is it need computer soft ware programming to help it program to begging again by any computer phone operators around your local area.
Thanks.
Sep 03, 2011 | O2 Xda Atom
Says security incorrect
Allow the phone for some time or put the phone off for some time then put it on again then press in the code if you are very sure of it, then the problem will be solve.
What the problem indicate simply means is that the phone memory has been shock ,then it need some time to reset/ relax.
Good luck.please rate four thump.
Dec 25, 2010 | Cell Phones
That is some time hang us musciply time after then bettery open and stert
Hi armandiyal listen take your battey out. This is a soft reset of your phone. Next I want you make sure all your contact information is backup. you may need to reset the phone . Go into settings and go the setting that says security . Put in the last four digits of your phone number. Before you ro this you have to make sure that you are resetting only your default settings and not the phone. if you reset the phoen you will need to put all the information back into the phone. it is like starting from when you first got the phone. Hope this helps if you need more information let me known
Dec 03, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
My touch screen isn't responding properly. For exmple when i touch the number one, my phone puts the number 2 on the screen. The screen freezes and sometimes doesnt allow me to do anything
hello;
here are some guild line that will help you in maintain your phone
you need to be careful on how it drop from you
you should allow your phone to do one function at a time (i.e)one after the other
solution to solve your phone problem
your phone key need to be celebrate
then how you have to celebrate the phone key is from the screen of your phone at the right Conner of the screen click on it as it move from one position to another till it congratulate you then put off the phone for some tine and put it on in a short time
then your phone will respond to your command
Good luck and thank for using fixya.
Apr 06, 2010 | Samsung Eternity Cell Phone
Battery does'nt charge, won't hold charge,& time,military,when bat. low fromstand
i took phone back,& exchanged for another, but need my time put on new phone,&would like to use my phone #, from cellular south. 228-861-1114,& need to complete instalation of new phone.
May 12, 2009 | Motorola Mobility i425e Pay-As-You-Go Cell...
Unable to put phone in silent in times of need - samsung j700
press <Menu> → Settings →
Phone settings → Phone profiles.
You should see different profiles such as Normal, Outdoor, meeting, etc. Choose the one you want to use. You can change the rings for each of these profiles by selecting the one you want and choosing options/edit.
Apr 21, 2009 | Samsung J700 Cellular Phone
Need puk code for nokia n82
the puk code is required when the pin code is written wrong 3 times, to get the puk call your phone service provider the puk is not related to the phone so if you put in another sim card it will work, or if you put the locked sim card to another phone then the other phone will ask for puk.
its simcard protection incase its stolen, 3 times wrong and its locked, eventually if you enter the puk code wrong too many times it should make the sim card useless so call your phone service provider its your only option.
Mar 26, 2009 | Nokia N82 Cell Phone (Unlocked) - Silver
Can't set home time on CECT P168
I have this phone and I think you need to use military time. So if you want 12 am put in 12 but if you want 12 pm put in 24 ect.
Nov 16, 2008 | Dual Electronics CECT P168 Cellular Phone
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
