Question about Tablets & eReaders
How do i activate screen mirroring on a galaxy tab E ?
Forgot password to my tablet Samsung galaxy tab a
Dr.Fone for Android can help you reset lock screen password from Samsung Galaxy phones easily. No Google Account and No Data Loss!
http://youtu.be/fZmAZxr9JA4
May 22, 2016 | Samsung Tablets & eReaders
How do i take a screen shot on my SM-T550?
Samsung Galaxy Tab A (Wi-Fi, SM-T550) - Taking a ...
? 0:59
https://www.youtube.com/watch?v=u7nPrI5BG10
Jun 4, 2015 - Uploaded by SPSN
Capturing a screen shot is quick and easy on your Samsung Galaxy Tab A.
Taking a Screenshot - Samsung Galaxy Tab A (Wi-Fi, SM ...
www.samsungsupport.com/spsn/detail.jsp?ctg_id=1280...id...
Taking a Screenshot - Samsung Galaxy Tab A (Wi-Fi, SM-T550). Capturing a screen shot is quick and easy on your Samsung Galaxy Tab A. facebook twitter.
Jan 14, 2016 | Tablets & eReaders
How can I reset my Galaxy tab 2 7 to its original settings?
Samsung Galaxy Tab 2 7.0 - How to perform a hard reset with the ...
https://www.androidpit.com/.../samsung-galaxy-tab-2-7-0-how-to-perfor...
Jun 18, 2014 - Samsung Galaxy Tab 2 7.0 - How to perform a hard reset with the ... From the Backup & restore section, ensure the appropriate account is ... In Menu mode, select Settings ? Privacy ? Factory data reset ? Reset Tablet? ... Samsung Galaxy Tab 2 10.1 - How to perform a hard ...
Jun 18, 2014
How to Hard Reset the Galaxy Tab 3 - Android Forum ...
May 7, 2014
More results from www.androidpit.com
Galaxy Note 5: How to Perform Soft & Hard Reset
www.technipages.com/galaxy-note-5-how-to-reset
Aug 23, 2015 - If you want to sell or give away your Samsung Galaxy Note 5, or if you're ... The hard reset will wipe all files off of the internal memory, as well as ... your phone and just perform a factory reset as a way to make it their own. ... November 7, 2015 at 3:44 pm ... I have problem with my Samsung Galaxy tab 2 ...
How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0
? 6:01
https://www.youtube.com/watch?v=7sbgN0PxMzc
May 2, 2013 - Uploaded by HARD RESET KING
How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0Android 4.0 ... hi I got the same one as you and ...
Dec 21, 2015 | Samsung Galaxy Tab 2 7in. WiFi Tablet, 8GB
How come sometimes my screen works real slow, or not at all. but when I restart it the screen works gust fine,
You might have too many apps or you might have too many apps that are active in the background that are slowing your tablet down. Uninstall unused apps or turn them off through settings. Apps always sync in the background, even when you don't use them. When too many apps are running at the same time, they drag down the wifi speed. Go to Settings>Wireless and Networks> Data Usage, view all the apps that are actively syncing. Also, in Settings>Device>Battery, you'll see which apps are actively draining your battery (if this is also an issue). You might be surprised which apps are either draining your battery or always syncing.
Sep 19, 2014 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
Samsumg galaxy tab 3 shuts off every 30 minutes
Check the power settings to see if that is the cause of it shutting down. Streaming music does not produce the keep alive activity that is required, so it thinks that it isn't being used and turns off.
Mar 19, 2014 | Samsung Galaxy Tab Tablet PC
I have a galaxy tab 2 7.0
If it's a Samsung you can either use a feature called screen mirroring that your TV has or send the video directly to the TV via wireless using AllShare Cast since the Galaxy Tab 2 tablet supports it. I've done it with videos. Unfortunately, you bought the one model that does not support HDMI. The original Tabs the Tab 2 10.1 (only, some versions and $40 instead of $10 like the TAB 3 adapter) and the Tab 3 all work using a relatively cheap adapter or dock.
Feb 27, 2014 | Samsung Galaxy Tab Tablet PC
To many patten attempts
  1. With the Samsung Galaxy TAB turned off, press and hold the VOLUME Down button, and then briefly press the POWER button.
Note: If you see "Downloading" on the screen with an Android shoveling you pressed the wrong Volume key. Remove and reinsert the battery and try again.
It should hard reset any of these tablets:
Reset GT-P6210 Galaxy Tab Plus 7.0 WIFI
Reset GT-P6200 Galaxy Tab Plus 7.0 WIFI + 3G
Reset GT-P6810 Galaxy Tab 7.7 WIFI
Reset GT-P6800 Galaxy Tab 7.7 WIFI + 3G
Reset GT-P7310 Galaxy Tab 8.9 WIFI
Reset GT-P7300 Galaxy Tab 8.9 WIFI + 3G
Reset GT-P7510 Galaxy Tab 10.1 WIFI
Reset GT-P7500 Galaxy Tab 10.1 WIFI + 3G
Feb 10, 2014 | Samsung Galaxy Tab 2 7" 8GB Android Tablet...
Tablets & eReaders Logo
70 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
