My 22inch onida LCD is in stanby mode, after keeping ON for sometime(20 to 30) then multi restarts required to get the dispaly. once display appears no issue till we OFF, kindly help me on this issue
welcomejee
  • 10594 Answers
SOURCE: I have a Sony DSC-F88
Your DSC-F88 has problem with CCD Imager and needs to be replaced. Good news is Sony will replace it free of cost. Click Sony Official website to get further instructions. Hope this info will helpful for you.
Posted on Aug 12, 2008
SOURCE: motorola W510
http://www.youtube.com/watch?v=
Posted on Aug 13, 2008
budmrtn
  • 11361 Answers
SOURCE: My Tv wont turn on Stanby
Unplug it for about an hour to let it reset itself, if it still does not work, then you will have to open it up and troubleshoot it.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Sep 05, 2010
SOURCE: bush lcd 37 inch tv keeps going to stanby
my bush lcd tv keeps staying in standby mode and wont go on if it does go on its only for a minute or two....
Help please
Posted on Nov 18, 2010
SOURCE: Dear Sir, My Samsung C160
I have a concern about samsung SGH - C160, my initial problem tuh hp when going in life reset code * 2767 * 3855 #, while in reset my hp not a problem but when I want to change my simcard hp so i beg solutions kept reset her???
Posted on Oct 03, 2012
ONIDA 22"LCD
There could have been a power supply failure.
Jan 10, 2014 | Televison & Video
I have vertical lines on my monitor and cannot make them disappear through any settings ? can anyone help
When does it appear on windows or before
If in Windows then uninstall the drivers of Display Adapter
Steps :-
Right Click my computer -> Manage -> Device Manager -> Display -> Uninstall -> Restart the Computer
Still Nogo
Update the Drivers of Video or display from Internet
Check if u can see same lines in BIOS Mode
Steps to go into BIOS
Restart Computer -> Keeping tapping F10 Key its a single Key on First Row of Kayboard
Check in that mode if u can see same lines over there contact View Sonic Hardware Problem
Jun 01, 2010 | ViewSonic Monitor Lcd 22in Wide Va2216w...
Screen keeps going black
check your numlock key presss it then check numlock led if it on /off then your computer gives dispaly to monitor perfact then when you power up ther computer press F8 key then enter in enable vga mode if you see safe mode and other mennu.
But if you can't able to see those menu then you have to check your monitor to cpu vga cable connection.
Also check your monitor is properly working? or not.
Aug 13, 2009 | Acer X193W LCD Monitor
Bush lcd 37 inch tv keeps going to stanby
Help please
Mar 04, 2009 | Televison & Video
I have a ViewSonic flat screen monitor. The images on the sign in page are fuzzy and unreadable. I have Windows XP.
I would check the connections between the monitor and computer. Also the refresh rate and/or resolution might be wrong. To correct this, you will need to boot your computer in safe mode. (restart computer, right after the computer's logo appears rapidly press the F8 key until a black and white menu appears. Select SAFE MODE) once the computer boots to safe mode, the sign on screen will appear very large. Sign onto the computer once at the desktop, RIGHT CLICK the background and select PROPERTIES. Once the display properties window appears click on the last tab SETTINGS. Here is where you can adjust the resolution. Take the screen resoltution to a low setting. You can always change this later when you boot your computer normally to get a better view. Next click on the ADVANCED button click on the MONITOR tab, usually flat screens operate at a lower refresh rate then CRT monitors. I usually keep my refresh rate to 60 Hertz. Next click on the GENERAL tab. This will allow you to change the DPI setting. I usually keep mine set to 96 DPI. You may want to experiment with this as monitors vary. Once done, click on the APPLY button then OK. Restart the comptuer and see if this has improved your display. You may need to do this several times trying different settings until you get a clear display. If you've exhausted all these steps, try a different monitor or changing the cable. If that fixes the problem then you know you have a bad monitor or cable. Good luck, let me know how it turns out.
Dec 19, 2008 | Computers & Internet
Deactivate child lock on Onida TV
Try with 1147 (This one worked on my ONIDA TV) OR 5963 OR PRESS ZOOM BUTON AND VOL- KEY BOTH.
Aug 04, 2008 | Televison & Video
Canon ir 2016 copier on display says ( Download Standby) thanks
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Apr 18, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
Looking for service menu of 32Q6TVH LCD TV (NEC and Onida)
HI FRIEND,
I DON'T KNOW THE SERVICE MENU OF NEC BUT TO ENTER IN ONIDA PRESS VSM AND DISPLAY BUTTON SIMULTANEOUSLY, FROM ORIGINAL REMOTE .
JABBAL,
9422117997
NAGPUR
Jan 15, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
