Main unit cover is open - Office Equipment & Supplies
2 Suggested Answers
SOURCE: Main Unit Cover Open
With the front door open look at the inside /right side about half way down . There should be a stub of plastic molded into the door . this should push a switch when teh door is closed. if not you may need to "extend" the stub somehow as to activate teh switch. I have a short piece of tubing over the stub to get about 1/8 inch of aditional length. Works great.
Posted on May 08, 2010
How do I remove the cover from a split system?
open up the front cover as if removing the filters
along the bottom of the main cover you will find 3 screws
undo then , lift forward and up with the main cover and it separates from the fixed unit on the wall
that is all you can remove as the main unit is fixed with the popes and drain on place
Dec 01, 2015 | LG Heating & Cooling
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
E000012-0106
The machine cannot be operated and the error code <E000012> appears on the display.
Cause and Solution
The delivery feeder unit may not be installed correctly. Follow the procedure below to install the delivery feeder unit correctly. If the error code persists after the delivery feeder unit is installed correctly, contact your local authorized Canon dealer.
Re-install the Delivery Feeder Unit
NOTE
  • You have to remove the delivery feeder unit and reinstall the delivery feeder unit correctly.
  • When you remove the delivery feeder unit, you have to turn the main power switch OFF.
  • Sending or receiving documents cannot be done when the main power switch is OFF or the power cord is disconnected.
  • If the main power switch is turned OFF, all jobs waiting in the print queue will be erased.
  • Documents received into memory and documents stored for delayed send will be retained for approximately 60 minutes after the power cord has been disconnected.
1. Turn OFF the main power switch and disconnect the power cord.
2. Open the front cover.
If you are using the stack bypass tray, close it before opening the front cover. Open the front cover gently holding the handle (A).
3. Push the levers (A) on both sides of the delivery feeder unit and remove the delivery feeder unit gently, holding it by the tabs (B).
CAUTION
Do not place any object on or touch the transfer belt (A) of the delivery feeder unit. You do not need to manually clean the transfer belt even when it is stained by toner, as the delivery feeder unit has a self cleaning function for the belt. Breaking the delivery feeder unit or damaging the transfer belt may result in misfeeds or deterioration in print quality.
4. Install the delivery feeder unit so that the protrusions (A) of the delivery feeder unit fit into the guides (B) and click into place.
5. Confirm that the triangle marks (A) on the delivery feeder unit are aligned with the triangle marks (B) on the machine.
6. Close the front cover.
Close the front cover gently holding the handle.
CAUTION
Be careful not to get your fingers caught.
7. Reconnect the power cord and turn on the main power switch.
Jun 22, 2015 | Office Equipment & Supplies
How to remove left and side casing from kyocera fs-c5025n please
FS-C5025N left cover removal.
1. Open the rear cover.
2. Open the top cover.
3. Remove the opening and closing axis from the main unit frame and then remove the top cover. It pry's out at the hinges.
4. Open the left side cover and then remove the one screw.
5. Remove the waste toner box. To remove waste toner box, press the lock lever in.
6. Remove the paper feed unit .
Feb 18, 2011 | Kyocera FS-5025N Laser Printer
SP MODE AND INSTALLATION PROCEDURE FOR TOSHIBA DP 1660.
Installation Procedure:
01.Open the machine and take out all tape
02. Open the front cover and right hand side cover + blue lock press and open the black part
03. front side two scrow (big) open
04. Out of PC Unit ( drum and developer Unit)
05. done you Two part the ( drum and developer Unit)
06. developer keep on developer
07. total Items set on the machine
08. main switch on
SP mode
01. 0+5 press and main twitch same time for AJ MODE
02. 0+5 press and main twitch same time for ADMODE
Jan 28, 2010 | Toshiba e-Studio163 Copier
E-studio 2830 toshiba printer ... how to clean main charger
Once u open the front cover, u can see 4 process units(CYMK). There is a main charger cleaner with green color knob on each process units.U just need to push the cleaner unit in and out for few times on each process units to clean the main charger.
http://img.photobucket.com/albums/v390/anthonydidi/cleannmaincharger.jpg
Dec 27, 2009 | Toshiba Office Equipment & Supplies
Dec 14, 2009 | Minolta QMS 2200DL Laser Printer
Once the np 6050 is turned on it displays error code E010 switch off and on again
E010 code is main motor lock. Open front cover, Release Transport/Fixing Unit tray. Pull the tray out untill it stops. Try rotating the larger knob to see if Fixing unit will turn...if not, raise the exit/stripper assembly to check for jammed paper. If no paper present and the Unit turns freely, reinsert Transport/Fixing tray into copier. Latch into place. Close front cover. Power on machine.
It is possible that the main motor has failed, but not likely.
Jun 19, 2009 | Canon NP 6050 Copier
Noise
The top of the unit that covers the coffee beans has a plastic point that must depress a button on the main body of the unit when it closes to show the unit that the lid is closed properly. If this is broken (as was mine) I inserted the end of a piece of tooth pick replacing the plastic point in the lid and this now depresses the recessed button on the main unit. The beeper goes off and the on light comes on.
Jun 19, 2008 | Cuisinart Thermal DGB-600 Grinder
k24674
