Question about Huawei Cell Phones
I need know passphrase of Huawei power-Fi E8221.How to locate. Urgent.
How do unlock my huawei E5336
In Order to unlock Your Mobile Wi-Fi router Huawei E5336 you have to follow below steps carefully.
  1. Turn Off Your Mobile Wi-FI Router
  2. Find and keep note down your device's IMEI number at somewhere
  3. Generate the unlock code using the Huawei Code Calculator.
  4. Now Insert any other service operator's SIM (Invalid SIM) into the Router and Turn On it.
  5. Connect any device with your Wi-Fi Hotspot (Created By The Huawei E5336).
  6. Now openhttp://192.168.8.1 or htpp://pocket.wifi (Dont Worry if it says your Router is locked or Invalid SIM).
  7. Go to ADVANCED SETTINGS >> SIM SETTINGS >> UNLOCK DEVICE.
  8. Here you can find the box which ask you to enter the UNLOCK CODE, Please enter the UNLOCK CODE (New Algo) which you have generated in STEP -3.
  9. Now Click on APPLY and your modem is unlocked for ever
Note :- Please Make Sure that your device is fully charge
Aug 18, 2014 | Computers & Internet
How to connect a rca thomson router to wifi
You are trying to connect to a modem, not a router, the router, a wi-fi version, is what you are connecting to your network.
First, power off all equipment, computer and modem, use the network cable you have connected to your computer from this modem and disconnect from the computer, connect it to the differently colored port on one end of the Belkin, the others have numbers, connect a network cable from one of the numbered ports to the computer.
Now power on the RCA modem, wait until lights are steady, then turn on the new Belkin router, wait until lights are active, just a few moments, then power on your computer, you should now have internet access and be able to locate the manual from the Belkin's website to further your setting up a passphrase or setting up some security on your wi-fi.
Jun 14, 2014 | Thomson Rca / Digital Broadband Modem...
Don't know how to connect to my home wifi
Connecting your Acer laptop to your home wireless network is fairly simple.
Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position.
Not all models have this switch.
Open the Windows Start menu and select "Connect To."
A list of available connections will appear.
Select "All" from the drop-down menu to view all available networks and connections within range.
Select the desired network and click "Connect."
Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
Mar 11, 2014 | Acer TravelMate 2480-2779 Notebook
HOW DO I SWICH THE WIFI ON
Which model acer ???...
Aug 13, 2013 | Acer Computers & Internet
I forgot my screen lock for my Huwai u 8655-1.. i need ur urgent help
you have to reset your phone to factory settings for this purpose you had do the shutdown your phone, hold the volume down key and press the power button untill a menu appears then select data factory reset,
Jun 24, 2013 | Huawei Cell Phones
How can I get my acer aspire one mini laptop to access wifi?
Connecting your Acer laptop to your home wireless network is fairly simple. Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position. Not all models have this switch. Open the Windows Start menu and select "Connect To." A list of available connections will appear. Select "All" from the drop-down menu to view all available networks and connections within range. Select the desired network and click "Connect." Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
Wireless configuration for your laptop http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
Feb 21, 2013 | Acer Aspire One AOA150-1949 Laptop
My pc details-amd semprom 3200+,mmx,3DNOW,1.8GHZ. MY INTERNET SEVICE MODEM IS WI-FI ENABAL,BUT MY PC IS NOT WI-FI. HOW ITS WI-FI CAPABLE NOW
You must purchase a Wi-Fi adapter (possibly a USB Wi-Fi adapter) & follow the the adapter's installation instructions followed by inputting the modem's SSID & passphrase (if there is one). The SSID will probably show up in a list of available networks. Just follow the adapter's instructions. Refer to the modem's instructions for logon information (i.e., SSID, encryption type (if any), passphrase (if any), WPS PIN # (if any), etc.).
Apr 11, 2011 | Computers & Internet
Passphrase for router?
It means the same thing as password, used for secure wireless.
Jun 12, 2009 | Actiontec GT704WG Wireless Router...
Password
Ok... There are tree things you need to know about securing your WI-FI network.
1: Each computer needs to have "permision" to access your WI-FI network.
2: The "Passphrase" and the "Key" are not the same thing. The "Passphrase" doesn't always work. But the "Key" should. (MACs will need the "key")
3: Some WI-FI equipment is "too old" to use 128 bit WEP or WPA.
(I don't think this aplies to your problem)
Nov 22, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cell Phones Logo
29 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
honeybun1986
john h
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
