Question about Presto Heating & Cooling
My presto dish pkus i took aoart to ckean and some wires camme odf i need a diagrem where they go please
2 Suggested Answers
  • 13 Answers
SOURCE: RE: Presto Heat Dish buzzer going off
I almost threw my heater out! I cleaned this morning with Window Cleaner and it works just fine now. It was just dust. I cleaned the round metal area not the coils.
Hope this helps.
Emailed Presto about replacing the buzzer and here is the answer I got:
There is no such part. Buzzer sounds when heater:
- is tipped
- rests uneven on floor
- is too close to furniture or wall
- has too much dust on parabolic dish
The most common reason is that the parabolic dish is dusty.
To clean the heater:
1. Unplug the heater and clean it when it is cool
2. Spray a cloth with an all-purpose cleaner such as 409
3. Wrap the cloth around a long handle such as a wooden spoon
4. Wipe between the grate from the outer edge to the center
If you have further questions, please let me know. Or call us at 1-800-877-0441 Monday through Friday 8:00 a.m. to 4:30 p.m. Central Time.
Posted on Jan 13, 2010
Hope this helps.
- is tipped
Jan 11, 2010 | Presto HeatDish Compact Heater
Buzzer goes off
This was the answer from Presto as I had the same problem. Cleaned it with window cleaner and a wooden spoon and paper towels and now it works great!
- is tipped
Dec 29, 2009 | Presto HeatDish Compact Heater
Clean dish
'tdulany's remedy for cleaning the dish on the Presto Heat Dish probably works well, but how do you get past the grill covering the dish in order to clean it?
Nov 26, 2009 | Presto HeatDish Compact Heater
Please give me the number on how to purchase dust remover that came in presto heat dish box. Thank you!
This is the answer I got from Presto. I cleaned it with window cleaner, wooden spoon and paper towels. Dish works great now.
- is tipped
Oct 25, 2009 | Presto HeatDish Compact Heater
Presto Heat Dish "buzzing" while on and sitting stationary
This question has been answered. I was having the same issue and I can tell you that the solution gregstobbe gave worked for my heater.
http://www.fixya.com/support/t1225707-presto_heat_dish_buzzer
Oct 14, 2009 | Presto HeatDish Compact Heater
Presto Heat Dish: footlight lens
The wattage of the replacement bulb should be 4 watts or less. Don't know the wattage of a C7. It is still safe to use. You could call Presto at 800.877.0441 or find a 4 watt bulb.
Jul 06, 2009 | Presto HeatDish Compact Heater
Presto heaters
We have one in our office where our entry is pretty close to teh main door. It used to buzz all the time after being on for maybe 10 minutes. One day I got sick of it and took a cloth and some windex and cleaned the reflecting dish, and that actually stopped it
Oct 29, 2008 | Presto HeatDish Compact Heater
No heat
since the light is on its own circuit this dont surprise me at all. The most likely cause of this is the contacts on the inside of the heater. the wire inside of the unit is very small for a heater, bad design, and is conected by spade conectors. my wire in mine burnt through and did the same thing. I bought some good thick wire and rewired the unit direct and this seemed to fix the problem. If you need further assistance check out some of my other solutions in this same area.
Oct 17, 2008 | Presto HeatDish Compact Heater
Presto Heat Dish
The hardest part of cleaning the dish is that you can't get your hand inside the cage surrounding the dish. What I did was to use a wire cutter to snip enough pieces of the cage off so that I could get access to the dish. If you do it carefully, it looks as if it was intended and doesn't prevent the cage from working. If you think of the cage/dish as a clock, I cut all the strips between 9 and 11, and 1 and 3. Easy to clean the dish afterwards.
That might not solve the buzzing problem, though. It didn't solve it for me.
Feb 07, 2008 | Presto HeatDish Compact Heater
Presto HeatDish Problem
I rewired my heat dish. I UNPLUGGED THE HEAT DISH. I loosened the three screws on the back and removed them. Then I unclipped the dish at the bottom. The dish should be loose and the bottom section of the dish should be detached from the plastic casing. Look inside the casing at the bottom. There is a red cable attached to the buzzer (it’s the silver metallic piece). Detach the red cable from the buzzer. Now look directly behind the buzzer is a black wire that connects to the circuit next the buzzer. Attach the red cable to the female receptor foot the black cable. Plug it in and it should work fine. This will permantly disable the buzzer, SO YOUR HEATDISSH NOW LOINGER HAS A WARNING SYSYTEM. IF YOU TURN YOUR HEATER OVER THE BUZZER DOES NOT GO OFF, THE BUZZER ALSO INDICATES OVERHEATING OF THE UNIT. SO BE CAREFULL. MAKE SURE THE UNIT IS UNPLUGGED WHEN WORKING ON IT. GOOD LUCK AND BE SAFE
Oct 19, 2007 | Presto HeatDish Compact Heater
Heating & Cooling Logo
Top Presto Heating & Cooling Experts
Mack Baxter
paulcarew
Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
