Question about Ovens
My oven is still dirty - Ovens
What if Conection Oven is very dirty
If convection oven is very dirty then you run risk of a fire. I hwould highly recommend a suitable oven cleaner to assist in making the cleaning an easier job as baked on oil and grease can be difficult to remove.
Jan 12, 2017 | Ovens
How do i stop the oven top from clicking?
that is not the oven and it does not look dirty to me .
Jun 24, 2016 | Ovens
My ovens flame is completely a dark yellow is this normal? my cooker is a cannon thankyou
no,this flame is like this because either the flame orfice is dirty or the burner is dirty or the unit isnt getting enough air mixture to completely burn the gas and this will lead to a yellow flame instead of the normal blue flame
Aug 01, 2010 | Ovens
Oven temp stays high and doesn't keep even temps
Have you cleaned your oven lately? Is it dirty inside?
With the oven cold. Look inside for a temperature probe. It usually looksl like a medium piece of copper tubing. Make sure it is clean.
Sounds like your thermostat is causing the problem which might be because of a dirty sensor.
Oct 15, 2009 | Ovens
Window
The inner window should be part of the outer window. The 2 are one piece. If the inner window on the inside is dirty, then the seal has been broken or the glass is cracked. You will have to replace the entire glass or just live with it being dirty.
Feb 15, 2009 | Maytag CWE4800A Electric Single Oven
Oven not reaching correct temp
It isn't a design flaw. It is an air pressure switch. Main fan not running OR oven is dirty and the tube to the air pressure switch is clogged. Dirty ovens aren't a design flaw. I saw it once a week. Five minutes clearing the tube and you back in business. Hope this helps.
Jan 13, 2009 | Lincoln Conveyor Oven - 1133-000-A
Dirty self cleaning oven
easy off has a new spray for self cleaning ovens start with that after getting loose grime then self clean
Oct 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven glass
all oven doors collect grease to some extent, depending on which pane of glass actually got dirty will determine how difficult it is. your owners manual shoudl describe how to remove the oven door, after that, layont it o nthe table and carefully reomving the screws from along bottom panel you should be able to ge tto your dirty glass, might take a few screws, just dissasmble slowly, dont overtigthen screws and above all remembrer how your taking apart for reassmbly
May 03, 2008 | Whirlpool RBS275PD Electric Single Oven
Dirty oven window
Try to remove the door. For the Kitchenaid, thereis a hinge on each side with a latch that flips up. Once the door is removed, remove all screws and you should be able to get at glass. Be very careful, the Kitchenaid had four panes of glass.
Jan 08, 2008 | Whirlpool GBD307PRS Stainless Steel...
Ovens Logo
23 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
