Question about HP LaserJet 1320n Printer
Density Adjustment in HP Laserjet 1320 - HP LaserJet 1320n Printer
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Firstly I doubt that economode is set by default, but maybe the printer is in
economode for some reason.
Secondly I would normally expect the problem to be the toner cartridge but
assuming you have checked this my suggestions are as follows.
1. Run two internal prints from the printer.
a. By pressing the green "go" button briefly.
b. By holding the green "go" button for 5 seconds.
The first print should give you an indication of the print quality, if it
is good then the printer itself is probably behaving normally.
The second print will tell you exactly how the printer is set up. This
includes whether economode is on or off and what print density it is set for
(default is 3, range is 1-5).
2. If economode is on or the print density is lower than 3 the easiest way to
fix this is to do a cold reset on the printer as follows.
Important note: This will reset the printer to factory defaults, the only
setting that is critical is the jetdirect setting. Since you stated that your
printer is a 1320 and that you are running DOS I am assuming that it does not
have an "n" (for network) suffix eg 1320n. If I am right in this assumption you
can ignore the jetdirect comments above, if it is a network printer the second
printout from 1a should provide the jetdirect information which you may need to
keep for future reference.
Cold Reset Procedure:-
a. Turn the printer power off
b. Press and "hold" the green "go" button whilst turning the printer on.
c. Continue to hold the go button for at least 5 seconds and until the amber
attention light turns on (triangle with ! in the middle), this should occur
before 15 seconds elapses.
d. Release the go button.
Factory defaults should now be reset and you can check using 1a whether any
changes occurred.
Posted on Jan 06, 2017
What is print density
It is a measure of how black the print is on the page
Jan 08, 2013 | HP LaserJet 1320 Printer
My hp laserjet 1320 printing is printing too slow
If you're running a Mac, when you try to install the LaserJet 1320, it may suggest that you use the driver set for "HP LaserJet 1320 Foomatic/pxlmono." Do not use those settings. I had to reinstall my 1320 recently and since it said that was the recommended choice, I selected it. If I printed just text, it worked fine, but even a tiny 50KB image would take 5 minutes to print. When I reinstalled it again, I selected the option "HP LaserJet 1320 series," and everything works just fine now.
Apr 12, 2012 | HP LaserJet 1320 Printer
HP 1320 Prints Blank Pages
HP 1320 Prints Blank Pages Problem with the HP LaserJet 1320 Printer
Sep 03, 2011 | HP LaserJet 1320 Printer
Using an HP LJ1320 printer. When I print my page comes out with a faint gray look to it (not white). When I duplex the gray intensifies. I thought my toner cartridge was leaking toner so I replaced the...
Your Print density could be set too high.
Try to Decrease the amount of Density through the device configuration utility.
You Must have teh HP Toolbox installed to change printer settings
Feb 15, 2011 | HP LaserJet 1320 Printer
HP Laserjet 1320 replaced cartridge, toner light stays on
it may be not a genuine one, or you have a paper jam inside the printer
Mar 25, 2010 | HP LaserJet 1320 Printer
The Attention, Ready, and GO LEDs are on solid
Here is service manual for HP 1160/1320 series ->http://filecom.net/CXW_R.
Solution is on page 34. I hope it will help you.
Feb 27, 2010 | HP LaserJet 1320 Printer
Lost CD of HP LaserJet 1320 Printer
hello, i can assist you. go to this link and download what u need for free
http://www.driversforhp.com/wizard/w/HP?gs.hewlettpackarddrivers.wizard&gclid=CIzRyeG1t5sCFZJM5Qod5zOfAg
Jul 02, 2009 | HP LaserJet 1320 Printer
Low Print Quality
1) Make sure your toner is not low.
2) Make sure Print Density is set to 3. (Through the HP Toolbox.
3) Make sure EconoMode is not checked. (Printer Properties>Preferences)
Oct 28, 2008 | HP LaserJet 1320 Printer
Driver for hp laserjet 1320
Use This Link
http://www.driverstock.com/HP-LaserJet-1320-driver-download/10-26-2969-42659/index.html
Oct 18, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1320n Printer Logo
427 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
