Question about HP LaserJet 1320n Printer
Density adjustment - HP LaserJet 1320n Printer
Isbcomputer.com is a dedicated online store offers Printer Spare Parts, Formatter Card, Main Board, Power Supply Board, Flat Cables, Fuser Pressure Roller, Gear, Sensor, Scanner Units, HDD Parts, HDD PCB, Hard Disc Drive Spare Parts, Data Recovery, Refilling Products, Jet Image, Toner Powder, Toner Drum, Toner Cartridges, Laptop Accessories, Power Adapters, Computer Accessories, Computer Services, Computer Peripherals and many more Computer and Printer related products at one place with best prices.
Visit - http://isbcomputer.com
Posted on Feb 02, 2017
How to ingrese density
density adjustment are made from within the print driver. you may have a printer issue if your prints are washed out or light.
Oct 11, 2013 | Kyocera Fs-1300d Printer
Sir photo are printing very dark even darkness adjusted to low
It's been a long time since I worked on of these machines. I believe under the additional function option there is adjustment option for image density. This should overide current copier density settings. Sorry I can not remember exact naming.
Jun 24, 2011 | Canon imageRUNNER 400S Copier
My phaser 740 has print that flakes off when you print pictures with real dark areas. I assume it needs more fuser heat or less paper speed. The problem is I can' t figure out how to adjust either of these...
Recalibrate the colors. Flaking is sometimes caused by more ink/toner than can be fused to the media. There's a limit for the total amount of ink/toner. Yours may be set too high.
You'll need a copy of the Printer's User's Guide (also Downloadable from Xerox.com)
Controlling Color Density
When colors look faded, adjust the toner color density to extend the life of the components.
Print and use the Color Reference Page 1 In the printer's front panel, scroll to Calibrate Colors,
press Menu and print the Color Reference Page. 2 Compare the Color Reference Page to the Color Density
Samples on page 39. Make a note of the value (-10 to +10) for each color that most closely matches the samples.
3 Adjust the density for each color: Enter the value noted in Step 2 in the Calibrate Colors menu, under Adjust Each Color.
? Decrease color density: Press . ? Increase color density: Press --->.
4 Reprint the Color Reference Page; check your adjustments
Dec 09, 2010 | Tektronix Phaser 740P Laser Printer
Machine status P-9 what is this message?
Black Imaging Unit failure
• All density readings taken from the density pattern produced
on the Transfer Belt are 0.5 g/m2 (IDC Sensor
photoreceiver output) or less during max. density
adjustment (Vg/Vdc adjustment).
on the Transfer Belt are 4.5 g/m2 (IDC Sensor
Photoreceiver output) or more during max. density
adjustment (Vg/Vdc adjustment.)
Remove and reset the Black Image Unit. If this doesn't help the Image Unit may need to be replaced.
May 25, 2010 | Konica Minolta bizhub C250 All-In-One...
Error code e03-40
---Copy Density Sensor output adjustment-----
1. Sensor connector is disconnected.
2. Sensor is defective.
3. SPC PCB connector is disconnected.
4. SPC PCB is defective
there is a sensor in the drum unit that measures/sensors toner density on the drum. the sensor is usually dirty and needs a clean. there could be a number of causes so a technician needs to be called.
May 01, 2010 | Panasonic Workio DP-3520 Copier
How do I get a darker print?
when you click to print a document it has properties next to the printer click on this then set the print quality to best it will come out darker!!
Apr 08, 2010 | Dell Photo 964 All-In-One InkJet Printer
AR 405 copier has service code of F2-31
F2 31 Content Process control trouble (OPC base surface reflection factor is improper) Detail Usually the sensor gain is adjusted so that the output is a certain value, by reading the drum base surface with the image density sensor before starting process control. However, a certain output is not obtained by adjusting the sensor gain. Cause Image density sensor defective Check and remedy Check process control sensor output with SIM44-03. (Do not adjust) If the result is far different from the specified value, it suggests the sensor is defective. Check the sensor and harness. If the deviation is relatively small, check the sensor and drum surface for contamination.
Nov 23, 2009 | Sharp Office Equipment & Supplies
How to change the density of the printer HP LaserJet 5p
I'm afraid this won't be of much help to the original poster, who asked the question a year ago, but anyway - others may be looking for this too, just like I did...
To change the print density, a simple command must be sent to the printer. This is done in two steps:
  1. Create a file, containing the command
  2. Send it to the printer ("copy" it to the printer, in a DOS shell)
The command is:
<ESC>%-12345X@PJL DEFAULT DENSITY=4
where <ESC> represents the "Escape" character (character code 27). There are several ways to generate the Escape character (which cannot be directly entered in a text editor): E.g. substitute the character with any other, save the command and then replace the first character with 0x1b using a hex editor.
Or:
  • Open a DOS window
  • Enter:
    copy con density.txt <Enter>
  • Hold the <Alt> key
  • type 27 on the numeric keypad
  • Release the <Alt> key - the Esc. char. is shown as ^[
  • Type the rest of the command (e.g. %-12345X@PJL DEFAULT DENSITY=4) - adjust the density value to the one you actually want to set.
  • press <Enter> <ctrl-Z> <Enter> to write the file
When you have successfully created the command file, send it to the printer. In the DOS window, enter:
copy density.txt LPT1
(assuming that your printer is connected to LPT1)
That's it!
To verify that the density has actually been set, print a printer status page.
The printer remembers this setting, so this needs to be done only once.
Mar 31, 2009 | HP LaserJet 5p Printer
How to clean Density Sensor of Hp 3500 ?
Thank you for this info. I used your advice to fix my HP printer and it worked. By the way, great link to HP support parges on the www.partshere.com site. I was able to fix my printer and by the way purchased more printer parts and fusers. Thank you again!
Feb 27, 2008 | HP Color LaserJet 3500 Printer
Konica Minolta 2300DL
Yes! you can find toner density settings in your drivers page from control panel -> printers and faxes -> your printer -> properties
Feb 09, 2008 | Konica Minolta magicolor 2300DL Laser...
HP LaserJet 1320n Printer Logo
57 people viewed this question
Seeker5211
Seeker5211
