No sound when i connect the pc to the tv using the tv and pc 3.5mm socket nb! the audio out jacks on the pc both play my earphones and speakers - help!
SOURCE: Audio Jack Problem
check any other driver installed before the current driver......
Posted on Aug 16, 2007
SOURCE: Connecting laptop audio to tv
i had the same issue with a thinkpad T61 which i was connecting using VGA and a audio jack going straqight from the headphone socket to the back of tv.
I had picture but no sound and i found that once connected the issue could be solved by rotating the projection setting on the laptop(Fn+F7). Basically switched back to laptop only display, then back to laptop and projector display again and teh sound just kicked in.
i think it's related to the projector setting on the laptop rather than an issue with the tv.
Posted on Nov 01, 2007
DCSE
  • 191 Answers
SOURCE: internal speakers not working
try reinstalling the audio drivers first
as it seems to be an issue with either drivers or with the sound card
provide more info like
when was it working fine
wots the operating system you are running
Posted on Jun 07, 2008
  • 38 Answers
SOURCE: External Sound Card
No, that's not going to work. Digital output is just that....Digital. Your trying to send a digital into analog....won't work. Your tv don't have red and white audio out. That's what you hook to, but it still wouldn't be 5.1. Your out of luck my friend. The ONLY way you'll get 5.1 out of that T.V. is to get a 5.1 reciever with CO-AX digital input...the SAME as whats on your T.V. You can only hook-up sound to your X-FI with the line in jack using a y-connector and 1/8" stereo plug....and it won't ever be 5.1. It can't that way. Only way to get 5.1 to work on the blaster is with the tosh-link optical input cable. This too is digital, but uses optics to send it. Remember, you are playing with 2 different formats. Analog with your white/red thing you made and then digital. Digital using co-ax or optical tosh-link. Completely different.....as you now know.
Posted on Dec 05, 2008
clokker
  • 253 Answers
SOURCE: Audio Jack not working on my notebook
Install the sound driver from your computer.You can find it on the homepage from your pc.Re-install it.If this not helps install the ac97 driver...
Posted on Jan 16, 2009
No sound for earphone, there are no rca jacks, the earphone is used to attach speakers, but there is no sound from the earphone jack
if their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
Aug 14, 2012 | Insignia Televison & Video
When I plug in my headphones into the earphone jack on the HP xw4600 workstaion and play music i can hear the music from the 2.1 speaker
If you are saying when earphone plug is inserted you still have sound from speakers either jack on headphones is wrong(stereo or mono?) or the socket the jack plugs into is defective---when a jack is inserted it moves a leaf in the socket to turn the main speakers off.
May 17, 2012 | HP Computers & Internet
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
How do I get sound connecting a pc through hdmi to my tv?
Good Morning!
and wish you a Happy New Year2011.
Your HDMI TV will be having two audio input jacks, which are called "RCA" sockets (Red and White sockets) and your PC will be having regular "EP"(Earphone) socket for Speaker/ Headphone output (Light Green Socket). You need a 2-RCA to Stereo EP Cable, which is easily available. You can try "Radio-shack"
Have a nice day!
Jan 03, 2011 | Computers & Internet
I have a Bush TV model- IDLED 2401. When I put my earphones into the PCAudio Socket there is no result and the TV normal sound is not cut off. Is there some way I can rig up my earphones to get them...
That PC audio socket miniphone jack is for AUDIO INPUT (Green jack) when you use it as a computer monitor, it is to be connected to the PC AUDIO OUTPUT jack (Green) on the PC. Your TV does not have headphone output jack.
To be able to use the headphone with this TV, you will need to look at the on screen sound setup to see if you can turn the TV speakers on/ and off first, if it does not have that function then there is not much you can do.
Post back what you find so we can go further.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 01, 2010 | Televison & Video
No sound
Hello
If picture is OK and there is no sound output from your tv, means either its speaker or the Sound output Ic is not working. The case of speaker fault can be easly detected without opening the TV. You just place your ear very near to the speaker side and switch on the TV by AC mains [not with remote control]. You may hear a "thumb" SOUND OR A "HUM" sound from it. If any one is there the internal speaker is working fine. The fault lies in audio output Ic stage. If there is no sound said above, speaker can be suspected. Befor confirming that the speaker is faulty, if your TV has an earphone or headphone jack in front, insert the earphone or headphone socket into it, and check whether there is any sound heard from it. If there is sound from headphone, means that the headphone socket is faulty, it does not bypass the sound to the speaker. When head phone is connected, the connection to the speaker will automatically cut of. When it is pulled out from the socket, the speaker connection will resume. If the changeover switch inside the earphone socket also show this kind of trouble. If the speaker inside is found faulty, unscrew it out of place after opening the TV, go for a same type and number, impedence and shape.
If there comes the above said "HUM" sound from the speaker, surely the Sound Output Ic is faulty. Replacing it will solve the probelm. Before replacing it, check it soldering points for any loose contact. It is best to resolder all suspected point is sound section before replacing the ic.
Note: In modern TVs there will be any trace of sound, without a video signal. Without video, sound is muted. ok.
Nov 07, 2010 | Toshiba CF19H25 TV
No sound on viewsonic VG730m
you have to connect it via audio cable.
you need a cable with two 3,5mm stereo jacks. this you have to connect with the stereo output of your computer (mostly the green one) with the audio jack on your monitor. it's somewhere on the back i think. sound / volume control you do in windows - its the same as if you connect normal stereo speakers to your computer.
(perhaps you have to unmute or to raise the volume in the monitors os menu)
Jul 23, 2009 | ViewSonic VG730M LCD Monitor
Connect 2.1 Logitech to a TV
if you have an RCA output for your audio. you can buy a lead that goes from 3.5mm headphone jack into 2 RCA phono plugs.
Feb 25, 2009 | Logitech X-530 Computer Speakers
Connect Logitech 2.1 to TV
i dont know how ur tv does not have a earphone jack i wonder now a days how they make such tv's , pls try to take sound from audio LR if it helps other wise no hope to get sound on speakers sorry pls try to find in manual if there is any hidden headphone jack some where see in manual
Connection to a portable tv
The RCA set on a tv [Red /White /Yellow] are INPUT[ VCR/DVD player] not out put. Hook the speakers up the the 3,5mm earphone jack though you will need a conveerter plug like this
Jun 30, 2007 | JBL CREATURE II Computer Speakers
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
