Question about All-Pro Heating & Cooling
My all pro 115000 will not start with cover on
I have an allpro 115000 btu torpedo heater. Igniter works, nozzle flows freely and the heater runs on jet a. Never had a problem, now ignition is intermittent, heater shuts off within 10 seconds and does...
According to the Owners Manual Trouble Shooting Guide (Page 8), there are 9 different things that could be causing the problem you have. Fortunately, there are 9 solutions to finding and fixing the problem.
Below is a link to your Owners Manual (in case you have misplaced yours) that you can download and print for now and future reference.
This should get your heater fired back up.
Mar 07, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
I have a 115000 heater and when I turn on the switch the unit just hums and then it sounds like it blows an internal breaker and the humming stops
sounds like the motor start capacitor is bad causing the unit to stall and pop the internal circuit will need to remove the cover and look for the silver can looking component that connects to the will then need to get a motor start capacitor to repair the problem ..these usually cost about 6-15 dollars at most appliance parts stores...or you can try a place like
Jan 23, 2011 | Reddy R115DT Oil Filled Utility Heater
Were do i get parts for all pro 115000
Go to Google. Type in Kerosene Heaters and you will find a web site that sells parts. Keep model number handy. Rus
Nov 22, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Honda ridgeline hesitates when I accelerate from a stop. it has 115000 miles. Will changong the plugs fix the problem?
Check first the condition of the plugs if they are covered with black or white color. This may indicate timing adjustments or may need to have the plugs replaced. Oil on the plugs means you need to have the oil seal changed. Check the fast idle control valve if it needs cleaning but normally your issue will be accompanied by idling problems. You may have to have the injector checked if you find gas in the plugs.
Aug 29, 2009 | 2006 Honda Ridgeline
Check engine light
115000 miles on a Benz is not a lot of mileage provided the car was serviced on time and properly. You might want to have someone run a scan for trouble codes to see why the light is on. It could just be a bad 02 (oxygen) sensor. Does the car run OK?
Nov 19, 2008 | 1994 Mercedes-Benz E-Class
Heating & Cooling Logo
26 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
