Want to stream local tv channels to my wii so I can drop cable. Is this possible and how many?
SyNNeR6x3
  • 19 Answers
SOURCE: cannot get local channels back
Are you positive that your city has not done the Digital Conversion? Some Cities are doing it early before the February deadline. Also make sure you are tuning in to the correct channels. Meaning that if on your Cable Provider ABC was on Channel 3 that does not mean that ABC with still be on Channel 3 after you have your Cable turned off. Most of the Time the Local Stations Tag will let you know what channel its on. It will be something like "KWAS ABC 27" So on your TV you would Tune it to channel 27 to get ABC and the same fore NBC , FOX, CBS , etc...
I hope this helps Take Care =)
Posted on Dec 07, 2008
jerryg50
  • 1689 Answers
SOURCE: TV stuck on Channel Fixed;6
Go in to the user menu and find where the Auto Channel Setup is located. You can consult the instruction booklet for your TV set. Try this and see if it works. If it does not then there are a number of areas in the set where there can be some defective components.
The tuner is controled by the uPC system. There are a number of interface circuits involved for the channel control. Problems in these areas can cause the channels to not be able to be changed.
Jerry G.
Posted on Jan 17, 2009
SOURCE: Local TV channels drop out after a few minutes
We're still hanging on by our toenails waiting for a helpful response from FixYa. We did contact Philips tech support and they basically said that we need a new TV...so they're sending one to replace this one, and we are sending back the "old" one (that we just bought in December '08).
Posted on Apr 10, 2009
  • 56 Answers
SOURCE: unable to receive local channels
According to the manual for the 42LC2D it should be able to receive local channels through a normal analogue antenna connected to the anntenna/cable coax input connector. You can get the manual here http://us.lge.com/download/product/file/1000001586/60PC1D-UE.pdf
Posted on Apr 18, 2009
tonyw514
  • 66 Answers
SOURCE: Channel Scan on my Philips 26" TV only finds the local channels.
Hi.
you should go into your tv's setup menu and go to the tuner settings and make sure it is set to CATV (cable tv) and not Antenna/Air also splitting a cable to many times can cause the signal to weaken and gain a lot of noise/distortion that could be an issue that can only be solved by having the company come to the house and do a test ALSO when your in the tuner menu in under your tv's setup menu try adding a non local channel manualy and then see if the tv will tune to it, if so then you might have to add them manually at the worst... my guess is that it is not set to CATV/cable tv hope this helps and if not i hope someone else can.
Posted on May 24, 2009
How to use an antenna box for more channels
Once the antenna is mounted and connected to the TV then you can go into setup menu and do a channel search. You will be prompted to set it up as CABLE or AIR/ANTENNA. Select ANTENNA and it will program all available channels for you.
Apr 19, 2016 | Televison & Video
Connection or activation issue
Are you trying to watch local shows via your ROku? If yes, it won't be possible because the Roku doesn't have that capability like a cable box. Whatever channel you can find in the Roku's Channel Store, those are the only channels that you can access on it.
Mar 24, 2014 | Roku Televison & Video
Connect wii to netflix account
Hi Delores, yor image shows an iPhone; however, you must connect to your Netflix account with you Wii console.
Do you have wireless internet connection for your Wii? Do you have an established Netflix account? If so, then to download Netflix Instant Streaming for Wii you must go to the Wii Shop Channel.
  1. Select the Wii Shop Channel on the Wii Menu and select "Start."
  2. If you haven't already been to the Wii Shop Channel, you will need to read and agree to the User Agreement.
  3. A screen will appear asking you if you want to link a Club Nintendo account to your Wii Shop account.
    • If you have a Club Nintendo Membership, enter your User Name and Password, then select "Link."
    • If you do not have a Club Nintendo Membership, leave the fields blank and select "Skip."
  4. Select "Start Shopping" to continue to the Wii Shop Channel main menu.
  5. Select "Wii Channels" from the Wii Shop Channel main menu, then select "Netflix Instant Streaming for Wii." Select "Free 0 Wii Points."
  6. Select either the "Wii System Memory" or an "SD Card" as the download location. I'd suggest System Memory for Netflix.
  7. Select "OK," then "Yes" to download the channel.
  8. A screen will appear with Mario running across the screen and three blocks. Mario will hit the blocks as the download progresses.
  9. Once Netflix Instant Streaming for Wii has finished downloading, it will appear on the Wii menu.
Open Netflix, login to your existing account, and there you are!
Sep 01, 2013 | Cell Phones
I dont know how to download netflix on my wii
Connect your Wii console to the Internet A broadband Internet connection and access point are Follow the steps below to get connected.From the Wii main menu, use the Wii Remote to select the "Wii" button. Now, select "Wii Settings" to access the "Wii System Settings" menu.Using the arrow on the right side of the screen, scroll to page two and select "Internet. Select "Connection 1: None"(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.") Click on Wireless Connection" and then "Search for an Access Point." Select "OK" and the Wii will display all the wireless networks it finds. Select the wireless network that is yours. (If you're not sure which is yours, or you don't see any wireless networks,The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen: The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates.Once the Wii finishes downloading any updates, you will return to the main Wii menu screen. You will now need to download Netflix Instant Streaming for Wii from the Wii Shop Channel, then connect your Wii console to your Netflix account. Please see the step-by-step information below to finish the process and start watching Netflix content on your Wii.Download Netflix Instant Streaming for Wii from the Wii Shop Channel Now that your Wii console is connected to the Internet, you can download the Netflix Instant Streaming for Wii from the Wii Shop Channel. Once it's downloaded, you'll use it to stream movies and TV episodes with your Wii.
1 Select the Wii Shop Channel on the Wii Menu.
  1. If you have not previously accessed the Wii Shop Channel, you will need to read and agree to the User Agreement.
  2. A screen will appear asking you if you want to link a Club Nintendo account to your Wii Shop account.
    • If you have a Club Nintendo Membership, enter your User Name and Password, then select "Link" on the right.
    • If you do not have a Club Nintendo Membership, leave the fields blank and select "Do not link" on the left.
  3. Select "Wii Channels" from the Wii Shop Channel main menu, then select "Netflix Instant Streaming for Wii." Select "Free 0 Wii Points" to begin the download.
  4. Once Netflix Instant Streaming for Wii has finished downloading, it will be added to your Wii menu.After Netflix Instant Streaming for Wii has been added, the next thing you'll need to do is connect your Wii console with your Netflix account. Continue reading for more information.Connect your Wii console to your Netflix account Before you can watch TV episodes and movies streaming from Netflix, you will need to connect your Wii console to your Netflix account.On your WiiIf you're not already on this screen on your television, select Netflix Instant Streaming for Wii from the Wii menu. (Don't have this option?) On this screen you will be presented with a code; remain on this screen during the activation process.
  5. On your home computer
    Using an online device other than your Wii console - such as a PC, Mac, or Web-enabled phone - go to http://www.netflix.com/wii. (You will need to log into your Netflix account if you're not already logged in.)
  6. Still on your home computer
    Enter the code displayed on your television into the box on the bottom Netflix Web page, then click "Activate Now." (The code is case sensitive.)
  7. Back to your Wii
    Netflix will now attempt to activate the connection to your Wii console. This may take several minutes. When the process is complete, the Wii will automatically display your queue. (The screen on your computer will not change. Wait for the screen displayed by the Wii on your TV to indicate the activation has finished before going to another Web page.)
  8. And finally, watch TV episodes and movies streaming from Netflix on your Wii console by selecting the Netflix Instant Streaming for Wii on the Wii main menu
Aug 17, 2011 | Nintendo Wii Console
Hi! I am trying to connect my Wii to the internet in order to watch Netflix on my tv
Connecting to wireless network
1.Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
2.Now, select "Wii Settings" to access the "Wii System Settings" menu.
3.Using the arrow on the right side of the screen, scroll to page two and select "Internet."
4.Select "Connection 1: None"
5.Click on "Wireless Connection" and then "Search for an Access Point."
6.Select "OK" and the Wii will display all the wireless networks it finds.
7.Select the wireless network that is yours.
8.Select "OK," "Save Settings," and then "Yes."
Download Netlix
1.Select the Wii Shop Channel on the Wii Menu.
2.A screen will appear asking you if you want to link a Club Nintendo account to your Wii Shop account. 3.If you have a Club Nintendo Membership, enter your User Name and Password, then select "Link" on the right. 4.If you do not have a Club Nintendo Membership, leave the fields blank and select "Do not link" on the left.
5.Select "Wii Channels" from the Wii Shop Channel main menu, then select "Netflix Instant Streaming for Wii." Select "Free 0 Wii Points" to begin the download.
6.Once Netflix Instant Streaming for Wii has finished downloading, it will be added to your Wii menu.
  1. On your Wii
  2. On your home computer
  3. Still on your home computer
  4. Back to your Wii
  5. And finally, watch TV episodes and movies streaming from Netflix on your Wii console by selecting the Netflix Instant Streaming for Wii on the Wii main menu.
Jul 11, 2011 | Computers & Internet
How do i hook up the wii to beable to receive netflix
Hello, In order to for you to stream netflix from your wii, you must have an internet connection to your wii (if you need help on this, please feel free to contact me, or simply comment) along with a netflix account that includes streaming (about $7.99/month). From there, you have to options for configuring your wii:
  1. Using the disc
  • Go online, sign into your account, and under your account, you should find an option for streaming devices
  • Select the wii, and netflix will send you a disc
  • Put the disc into your wii, and follow the instructions to setup the wii for netflix
2. Wii shopping channel
  • If you don't feel like waiting for the disc, the go onto the Shopping Channel on the Wii
  • Search NetFlix, and the netflix channel will show up
  • Select the channel, and follow the instructions to configure your Wii
If you have any other questions about this, please feel free to contact me.
Feb 17, 2011 | Nintendo Wii Console
Our problem cantains a Wii.Our problem is how to get Netflix on the Wii without a disc or anything. We tried to fix it by putting in more information.
  2. If you have not previously accessed the Wii Shop Channel, you will need to read and agree to the User Agreement. For help locating the User Agreement, click here.
  4. Select "Wii Channels" from the Wii Shop Channel main menu, then select "Netflix Instant Streaming for Wii." Select "Free 0 Wii Points" to begin the download.
  5. Once Netflix Instant Streaming for Wii has finished downloading, it will be added to your Wii menu.
Printer-friendly version
  1. On your Wii
  4. Back to your Wii
More support for Netflix on Wii:
Feb 02, 2011 | Nintendo Wii Console
I need to know what channel to operate my wii on. I have a toshiba tv that is about 8 years old.
Try changing the TV inputs to VIDEO or AUX, using the remote or a button on your TV. If there is not a way to connect the Wii to the TV using the 3-cable system (Yellow, Red and White), then you might have to use a VCR or DVD player to plug the 3 cables into and then transmit the audio and video from the Wii using the regular cable line of VCR or DVD Player on TV channels 3 or 4. If your Wii has a regular TV Cable jack on the back, connect that to the jack on the back of you TV and select channel 3 or 4.
Jan 05, 2010 | Nintendo Wii Console
Unable to pick up local ''free'' channels following digital change over. Using RCA DTA800 converter and Phillips 2750/27 antenna. Can pick up only one local channel, but signal loss is more often the...
first of all, make sure all your connections are secure and threaded all the way in. Next, go to the main menu and press 5 (configuration) and press 1 (search for channels) if this doesn't work, press 4(signal strength meter) and see how strong your signal is. You may just need to re-position your antennae. If all else fails try system reset(number 5) and repeat search for channels. I've had similiar experiences with mine but I have a 62% signal strength and still get 20-something channels. Hope this helps.
Oct 11, 2009 | Televison & Video
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
