I have a Nexbox A95x android tv box with KODI but I cannot seem yo load any ready made builds. I instal the repobut when I go to load from zip file and select nothing seems to work.
Does the Nexbox work lidentically to a fire stick because I have no problem loading builds onto my stick?
  • 170 Answers
SOURCE: File Loading
first save the waorksheet and later try copying it to your memory stick
Posted on Nov 04, 2007
  • 201 Answers
SOURCE: embroidery stick
Four questions:
What model Husqvarna sewing machine are you using?
Are you using a Husqvarna formatted USB stick?
Is the embroidery unit attached when you put in the stick?
Is your machine using the latest version of its software?
I might be able to give some more specific help once I know the answers to the above.
Posted on Oct 19, 2008
SOURCE: I can't load photos onto my digital photo frame
The  A701 is  a bit cranky.  I've found that it prefers  USB  flash sticks of upto  2GB. It likes the flash stick formatting  before use.  And it prefers  jpg files  added  to the root directory of the flash stick -  so  no images in folders. Finally but probably least important, it's not much point uploading  2MB  jpgs as  the screen  is pretty much  72DPI  smaller size JPGS  lead to a faster loading. ( try  around 900x 600 dpi )
Posted on Jan 02, 2009
  • 31 Answers
SOURCE: problems loading image files onto memory stick pro duo
You probably emptied the memory stick in the download, if the OS sees the memory stick as a removable device then a simple drag and drop will put a copy of the files back on the stick. If MS not see by OS then you cannot get them back on. Trick is that the operating system must see the memory stick as a device to exchange data. Some programs allow retrevial but do not make provision for storing.
Posted on Jan 07, 2009
  • 10406 Answers
SOURCE: transferring music files with a memory stick
Insert the memory stick into a USB port on your computer.
Windows will recognize the device,
and give you a choice of applications, i.e., play music with Windows Media Player, or, use Windows Explorer to browse.
Select Windows Explorer.
Click to select the files/folders.
Choose "Copy Files".
Copy into your "My Music" folder on your new computer.
Posted on Nov 14, 2009
After installing kodi 16.1 jarvis ..getting message kodi has stopped working !!!
There is a possibility that you have your cache filled up on kodi. You can clear cache on kodi by following the given steps at the end of this post. Secondly you can setup best kodi builds to continue smooth streaming.
Clear Cache on Kodi:
  1. Open Kodi Jarvis > Then click on System menu in front of your screen > Now select File Manager > Double click Add Source option at the bottom.
  2. Once you click on Add Source, a box will soon appear where you need to click on 'None' option and type > Click Done > Type URL Name below 'Super Repo' > Click Done > Then click OK.
  3. Once you are done, go back to Kodi Main Menu by pressing 'Esc' button on your keyboard > Go to System > Then select Add-ons > Then click on Install from Zip File > Super Repo > Then select Jarvis > Click on Repositories > Superrepo >
  4. Now select Install from Repository > Then Super Repo Repository [Jarvis][v6] > Go to Add-on Repository > Select SuperRepo All Repository [Jarvis][v6] > Hit Install
  5. Go back two steps and click on Install from Repository > SuperRepo All Repository [Jarvis][v6]> Program Add-ons > Merlin Wizard > Install
  6. Open Merlin Wizard, go to Tool Box option > Here you will presented with 3 options i.e. Clear Caches, Delete Packages, and Delete Thumbnails. The space that each of these options consume are also listed below these options.
19 Best Kodi Builds To Experience The Colors Of Kodi
Sep 07, 2017 | Televison & Video
I have the h96 pro android box tv its the 7.1 3g 32 its not stable programs say not responding or it freeze or dont download could someone help me
First of all I would load complete kodi wizard from google play store so you can start with erase build. There are a lot of tutorials on kodi on you tube that will help a great deal.Also make sure you have the latest kodi program 17.4 now also on play store. I like to use kodi no limits magic build as I find it the most complete build out there.
Aug 31, 2017 | Televison & Video
I have a mx android tv box it will not download such has kodi it says unsuccesfull it was fine until i set it to reset because of another prob have i deleted a important thing?
The best thing to do is populate the box by hand. Complete kodi setup wizard will help which is available on google play store. Once you have cleared the build them I suggest installing kodi no limits magic build as it is the most complete one I have found. There are several tutorials on you tube that will walk you thru the whole procedure. Also once you have a working build and after cleanine casch and packages then back up the build with complete wizard. So once you have a problem again then remove build and then back up build and you are working again with little effort.
Jul 17, 2017 | TV Box Televison & Video
What are the latest arrived MXQ SERIES android TV boxes?
Some of the newly arrived MXQ Series Android TV boxes are:
a. MXQ-M9X Fully Loaded Kodi Box 2GB/16GB
b. MXQ-M9X Fully Loaded Kodi Box 3GB/32GB
a. Custom Launcher
b. Top Hardware Spec.
c. Comprehensive on Device User Guides.
d. Amazing Performance.
e. Android 5.1 Operating system.
f. Plays 4K with no problems.
g. Up gradable by adding HDD, etc.
You can see the whole details about these Android TV boxes from Kodi Box. Here, you can also order them on best interesting offers and discounts.
Jul 15, 2017 | Televison & Video
Which newly arrived Android TV box support MP3 and WMA audio?
Here, I am providing you some newly arrived Android Tv boxes which support MP3 and WMA audio:
a. TP6 Fully Loaded Kodi TV Box Glod 3GB/32GB
b. MXQ-M9X Fully Loaded Kodi TV Box 2GB/16GB
c. H96-Pro+ Fully Loaded Kodi TV Box
d. T95K-Pro Fully Loaded Kodi TV Box, and much more.
To get the whole specification and purchase these latest models at a reasonable price, you can visit Kodi Box.
Jul 07, 2017 | Audio Players & Recorders
Where can I find an Android TV box for Android OS Version 5.1?
If you are looking for an Android TV box of OS version 5.1, I am having the best option for you.
You can purchase MXQ-M9X Fully Loaded Kodi TV Box. This is the best brand which provides high-quality TV boxes at a reasonable price.
Some of the major specifications of this model are:
a. Model name- MXQ-M9X
b. CPU - Amlogic S905 Quad Core 2.0G(Cortex-A53)
c. Languages - English/French/German/Spanish/Italian/ and 33 more languages
d. Bluetooth - 4.0
To get the whole specification, you can visit the link mentioned above.
Jul 07, 2017 | BOX Computers & Internet
How to buy kodi tv box at discount price?
If you are looking to buy an Android TV box at amazing discount and offers, you can visit Kodi TV Box.
Here, you will find the best collection of these branded Android TV boxes and can also see the reviews and specifications of these boxes. To get details about return policies, payment mode, etc you can click on the link mentioned above.
May 17, 2017 | TV Box Televison & Video
Do the Kodi tv box pick up the regular tv stations ?
Yes! Kodi does pick up regular TV stations and standard live TV channels. See the video tutorial (attached to this Answer).
Here's our written guide on How to Install TV Addons via Config Wizard:
Install TV Addons in Kodi VIDEO Tutorial KodiFireTVStick com Tutorials
To install TV Addons for Live TV channels, we recommend installing the Config Wizard in Kodi. Attached is our video tutorial on how to do this on Kodi that's running on Amazon Fire Stick, although you can use this same process for any device that's running Kodi.
Jan 06, 2017 | Televison & Video
My android mx box as frozen wont show nuthing only start up mbox how do i get past it
Unplug from mains ...then reconnect...go into settings and check if the Ethernet or wifi is connected....sometimes restarting the router puts things right...without that you can't proceed....if you have not already done so download kodi version 14 as this seems to be quite stable.once downloaded go into API installer and direct to your internal sd to locate the Kodi apk file.once installed you can then set up your ad dons.a quick simple way is to use a community build from you are someone who bought from droidsticks you can use the droid stick wizard providing you still have the codes.get back to me if you are still stuck.
Apr 13, 2015 | FocalPrice MX Google Android 4.2 Dual-Core...
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
