Inner metal door on spring how do i get it off
2 Suggested Answers
jerardi
  • 14162 Answers
SOURCE: I replaced inside broken glass door but the inner glass window is loose.I am left with 2 thin flat metal springs.where do they go?
Posted on Nov 02, 2015
Broken Neff microwave hook for tension spring on door. Can I reconnect spring to metal frame or will there be too much tension?
If you very carefully prise off the inner trim of the door you should be able to see where the lug broke that was originally holding the screen. Use a small cable tie to fix one end of the spring to one a the angle pieces of metal around where the window is, about the same level (make sure the other end of the spring is on the hook assembly). You can secure the cable tie and adjust how tight you pull it to get to roughly the same tension it would be if still on the original lug. Cut off the excess of the tie and clip the frame back in position. Door should open and close now.
Hope this helps
Mar 28, 2013 | Neff H5430 Convection Microwave Oven
I need to refit the rubber door seal i managed to take it off but not sure how to fit the retaining metal band
its quite simple if you removed same....Assuming you have refitted the door boot seal the inner ring is normally fed on then tightened up with a securing screw some rings are a spring which needs to be stretched on to the seal, a good video is available at utube .com FIT DOOR BOOT SEAL
Jan 02, 2011 | Whirlpool Washing Machines
Our door wont shut...
cheap and effective way to fix is to gently remove the plastic ring from the inner door with a butter knife or small blade screw diver and attch the door hook spring to the inside metal fins
Feb 04, 2010 | Sharp R-1480 Microwave Oven
Plastic latches on door have no tension. Microwave thinks door is open, because latch is not ingaging. How do I access the latch hardware.
with butter knife or small flat head screw driver, carefully remove the plastic ring from ther inner door .cheap repair is to hook the spring to the metal fins inside the door if not order outer door panel
Jan 19, 2010 | Sharp R-1480 Microwave Oven
How do you replace a rear power window regulator on a 2001 Buick Regal?
take the inner door panel off and Then locate 1" holes stamped into the metal of the door. lower window so hidden bolts holding the window to the regulator appear in these hols and remove, push glass all the way up and brace as not to let it fall and hit your hand or break. Then locate 3 to 5, 10mm nuts, located on the inner metal face of the door that hold the regulator to the door, and remove. Remove regulator then window lift motor. (caution when seperating some regulators from thier motor, because some are spring loaded....finger removers).
good luck!
reverse for install
Sep 15, 2009 | 2001 Buick Regal
HJA 3300 Diplomat Oven Door Issue
my inner glass door exploded while cooking at 200 degrees.
Aug 17, 2009 | Ovens
1994 Jeep Grand Cherokee door seems to be locked but will not open from the outside no matter what. It will open from the inside but is a pain and would like the door to open from the outside.
Hi young_queen
A connecting spring or connecting small metal like arrangement synchronises the inner and outer lock to open . Each inner and outer lock would have one. The outer lock connector would have got weared out .Please change it
Mar 04, 2009 | 1994 Jeep Grand Cherokee
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Oct 27, 2008 | Neff H5470 Microwave Oven
Panasonic microwave door is stuck. The door is not opening
If you push in on the open door button and it just goes in and does not open the door, then the problem is that the plastic piece that actually opens the door has broken. You can verify this by removing the cover from the microwave and look inside. If you are handy just buy the part from the panasonic parts store in your city and replace it. If not take it in and they will replace it for you.
Good luck
Tom
Jun 12, 2008 | Panasonic Microwave Ovens
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
