Question about Exercise & Fitness
How do I replace batteries in my Raebok R1 exercise bike.
  • 5 Answers
SOURCE: bike makes a clicking noise when i try to start it
Your starter isn't getting enough power. Try checking your water levels in the battery and charging it with a trickle charger. Good Luck!
Posted on Jan 14, 2009
  • 31 Answers
SOURCE: The tension on the recumbent exercise bike does not get hard
If your bike has magnetic resistance and you changed the batteries this should make your tension work properly. Since it did not I believe that there are magnets somewhere on your bike that are wearing out. Or it could be a computer part. Your manual should tell what part you need to order and replace. I hope this information has been helpful.
Also make sure the batteries that you put in your bike are really new ones. Sometimes you can purchase new batteries at a store and they are actually a little weak. I had this problem with an elyptical trainer and I went and got other batteries and this fixed the problem.
Posted on Mar 16, 2009
SOURCE: battery missing for exercise bike
I have a Schwinn airdyne (model AD-3) that uses a button type battery in the count-down timer, which is above the work load indicator or the 'speedometer'. According to the manual I was given with the bike, it utilizes a 1 1/2 volt watch - type battery (LR44, A 76 or equivalent).
Hope this helps.
Posted on Apr 23, 2009
SOURCE: edge 491 exercise bike monitor panel dead
http://www.academy.com/images/pdf/Fitness_Quest/Edge_Recumbent_Bike_491r.pdf
Mine went dead last Spring. I ordered a replacement part from Fitness Quest. I think the link is above. Actually, while I was waiting for the part, I reconnected all the wires on the whole bike and the panel worked. So I actually have an extra new working panel if Fitness Quest doesn't have the part for some reason and u want mine. Double check ALL the connections of the wires first. They come loose easily.
Nancy
Posted on Aug 10, 2009
bwinton
  • 83 Answers
SOURCE: Lifefitness 9500hr recumbant exercise bike dead
This unit takes a special 6 volt battery. The battery is in one of two places. First place to look is under the unit. If you lay the bike over on its side there is an opening in the covers. If the battery is not there then you will need to take one of the side covers off. When you get the side off you cannot miss it. The battery is black with three cylinders. You can get the battery from sportsmith.net.
Posted on Mar 24, 2010
What is fault code E03 on Raebok Z8 Run treadmill
E03: This indicates a fault with the mounted speed sensor on the drive motor. Contact technical support.
Official Reebok Fitness
Mar 02, 2017 | Exercise & Fitness
On my Raebok treadmill what does E01 mean
E01: This indicates an interruption of power between the power in socket and the console. Check all wires at the base of the right arm are connected. If so, contact technical support. Official Reebok Fitness
Need replacement pedals for my resistant exercise bike
Rob, try any sporting goods that carry bicycles or bicycle repair shop for replacement pedals or order online.Check the attached links for replacement pedals. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
VP Exercise Bike Replacement Pedals 1 2 Stationary Bicycle Pedal Set with...
Parts for Life Fitness Bikes Pedals Battery Pedal Straps SPORTSMITH net
Exercise Bike Pedals eBay
Apr 12, 2016 | Cycling
Battery 9500hr
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
If the battery continues to fail, I would check the alternator brushes and see if they need to be replaced. Chances are they are worn and the battery is not being recharged sufficiently.
Battery 6 Volt 2 5 Amp Hr LifeFitness 0017 00003 0685 SPORTSMITH net
Feb 23, 2014 | Life Fitness 9500RHR Dove Tail Recumbent...
How do you change the battery on the leisurewise pro fitness exercise bike
Disconnect the small jack plug from the small display unit on the handlebars. Remove the display from the handlebars undoing the two small screws, the gently prise the front of the unit of exposing the small printed circuit board on which there are two button batteries ( LR 54 available from ebay or almost anywhere else ) Replace batteries and reassemble to Bike
Apr 08, 2013 | Exercise & Fitness
I have a vitamaster magnetic exercise bike and lost the battery cover now it does not work where can I get a replacement cover
You should contact the store that you got it from and ask them to send you a battery cover or if you have warranty to give you a new magnetic bike.
Sep 15, 2012 | Exercise & Fitness
Have a stairmaster recumbant bike which has generally worked well. Recently however had problems. Start pedalling to activate control panel, input data such as weight, level and time, however as soon as...
If the bike is working with Battery, Replace with alkaline batteries, and clean very well the spring with special electronic cleaner contacts, you can buy in any electronic stores.
2) Tight the connector well, and clean with cleaner contacts.
3) See if the small motor inside is working good, or the wires is faulty , and repair or replace.
LUBE very well the bike, follow the instruction manual steps.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
How to Lubricate an Elliptical Fitness Exercise Equipment
Nov 12, 2017 | Stairmaster 3800RC Recumbent Exercise Bike
I have a 2000 Yamaha R1. I charged the battery and it held the charge overnight. The next day I rode about 50miles, stoped the bike and the battery was dead again. It my understanding there is no...
1. Depending on what you mean by holding the charge.
2. As far I can tell, your battery have enough power to start the bike once or twice but then the charge is gone meaning the battery still have poer but the cranking power is below the needed amount.
3. Try take the bike to a battery shop, have them check the battery condition and the same time how well your bike recharging system.
4. If your charging system is good then just replace the battery.
Cheers
Nov 16, 2010 | 2005 Yamaha YZF-R1
Mar 14, 2009 | Cycling
Exercise & Fitness Logo
54 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
