Question about Tablets & eReaders
My rca tablet got broke on inside scereen and outter acreen and onrhe inside se like blouches of black ink
Rca 10" tablet need to connect to my phillips tv.Plug up nothing happens,Took a hdmi/rca cable from camera, hooked tablet to tv that made my tablets screen go black until unpluged from the tablet.
Screen going black usually means it is connected to another screen. Is there a setting on the tablet to enable output settings and a setting on the TV to enable input settings.
Jul 19, 2015 | Tablets & eReaders
Why does my RCA 7tablet have a exclamation mark on the battery when I plug it in to charge? It will not charge or turn on, what can I do.
That exclamation mark means the battery is bad or has a bad connection inside the device. If your battery is user-serviceable you could try removing the back of the device and checking the connection for corrosion or looseness. Depending on how old your device is, it just might be time for a new battery.
May 26, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
The charge dock on tablet broke so we can not charge tablet can it be fixed? We just got it this October.
Juello. Did some research on your tablet at Amazon, (http://amzn.to/1xWx6S5) and see that they also have an AC charger (AC charger adapter with a 3.5mm power jack and delivering 5VDC 2A). Available for $5: iRulu Black AC Home Wall Adapter Cable Charger for Tablet PC 5V 2000mAh or a there's a nice replacement KB and cover: iRulu New Portable 10 1 10 5 Android Tablet USB Keyboard Case Black . I would guess the connector snapped off inside the tablet, so you will have to remove it with some tweezers. If the pin for the AC adapter broke off inside the tablet, that's a problem, but most everything can be charged from the USB port too see this website:
How To Charge Samsung Galaxy Tab 2 Via USB Port On Computer Laptop PCNEXUS (Samsung used as an example). GL
Jan 08, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
My 10.1 RCA tablet with key boards screen suddenly stopped responding only in a few places on the screen. I have to keep rotating it to do anything. I bought it on Black Friday 2014 and the return policy...
I bought my son the 7 inch RCA tablet form Walmart on Black Friday 2014. This tablet has a one year manufacturers warranty so you should still be fine with your 10.1 in tablet if you contact RCA directly.
Dec 31, 2014 | Tablets & eReaders
What is wrong whith nabi 2 that has sreen probloms
sounds like your screen broke. Nabi has 2 'scereens' a piece of glass on top, then the LCD screen below. The LCD screen can be broken by hitting or twisting it. It can also become more prone to breakage if you leave it out in excessive heat.
Nabi will fix the screen for about $60...
Jul 02, 2014 | Nabi 2
Tablets & eReaders Logo
27 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
