Question about Dryers
It is clothes not electract - Dryers
How to get out sticky stuff from dark clothes
http://www.howtocleanstuff.net/how-to-remove-sticker-residue-from-clothing/
Sep 22, 2014 | Clothing
What is the best on-line store to but hunting cloths?
Try this: http://www.cabelas.com/catalog/browse/_/N-1100943?WT.srch=1&WT.tsrc=PPC&WT.mc_id=google'meh_General_General%2B2'USA&WT.z_mc_id1=sYVEWO2sX&rid=20&pcrid=16293457403&gclid=CNbv0pnXgLUCFYpY3godVAkAZA
its has everything!
Jan 24, 2013 | Hunting
How do I wash my dog's clothing?
As with anything, always read the label for instructions on how to wash the clothing. I would also use a hypoallergenic laundry detergent because my dog was allergic to the detergent we once kept in the house.
Dec 31, 2012 | Dogs
How much should dog clothing cost?
I love my pooch as much as anyone, but there is no reason to spend more than $25 on a shirt for your dog, $40 if you're looking to buy a thick coat. There are plenty of options available at this price range.
Dec 31, 2012 | Dogs
.Do you have any good site of shop wholesale clothing?
Wholesaling is defined as the sale of goods or merchandise to retailers, commercial or to other professional business users. So for whole sale clothing means buy or sale clothe merchandise to retailers, commercial or to other professional business users. If you want to shop online wholesale fashion clothing you can buy it from online. If any one search for a wholesale fashion clothing from online I will recommend you for one of the best site. The company provide high quality and charming clothes. In this case, maybe you can get a satisfied result. Most of the clothes in this shop were wholesale from the same wholesale website.
Dec 03, 2012 | Cameras
Washed clothes with gasoline on them. Put into dryer now washer and dryer smell like gasoline. How do I get it out?
To remove gas (petrol) smell from clothing, soak overnight in baby oil (use like you would downy), then wash in baking soda, then wash with normal detergent. It will rid "gas smell" from an entire basket of clothes. Air Dry ONLY
From ehow website:
Step1
Buy a bottle of baby oil. Since gas is an oil based product it is going to take an oil based product to clean the gas out of your clothing. Baby oil is a great product to use as it shouldn't, in most cases, cause further damage to your clothing.
Step2
Soak your clothes with a bit of laundry detergent, water, and a generous portion of baby oil. Also dab some right on the stain before soaking.
Step3
Swash your clothes in the water for a while and let them sit for about five minutes. Transfer the clothes into your washer, once again remembering not to mix them with any other clothing, and let the cycle finish.
Step4
Wash the clothes. If you have a top load washer, let it partially fill up about 1/4 of the way with water. Put some of the baby oil in the wash with the clothes and swash it around a bit. Once the washer cycle begins, add the detergent and let the cycle finish. Make sure that your gas coated clothes are the only clothes you put in the wash.
Step5
Dry your clothing. Make sure you only AIR DRY on a clothes line these clothes. It could take more than one wash to get all the oil out of your clothing. If you use the dryer after the first, or even the second time, you could risk starting a fire in your dryer.
Step6
Check and see if any smell remains in your clothing. If the smell of gas remains on the clothing repeat the wash with baby oil again until the smell is gone.
Sep 04, 2011 | Frigidaire Electric Dryer
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
Drum spins off center and clothes get stuck between drum and casing
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
May 28, 2009 | Kenmore Dryers
Dryers Logo
Top Dryers Experts
