I have a fan world air conditioner but H1 keeps coming up and it switches off what can I do
What does H1 mean when it comes up on my fan world air conditionier
  • 104 Answers
Dehum is short for dehumidify. This setting is to remove the humidity from the air without doing any real airconditioning. Also, if the a/c is spitting water out the front, then the a/c is leaning forward too far. The a/c should be at least level or maybe leaning toward the outside a little bit to help facilitate drainage.
Posted on Jun 25, 2008
  • 1861 Answers
SOURCE: Radiator fan
You should check the 30 amp "RDI" fuse and the 7.5 ECU-IG fuse. Both fuses are critical to the operation of the fan system. The RDI fuse sends power to the fan #1 relay. The A/C amplifier turns on power to the fan #1 relay, this is why your fan works on A/C.
Now, with no cooling fan under "normal conditions" (A/C off), you need to have a good fan #2 relay, and a good water temp switch. This switch is on the engine, near the thermostat housing (I think); with a single plug, with a white with a blue trace wire going to it. Remove this wire from the sender, and jump it to ground (anywhere on the metal of the engine) with the key on (engine OFF). If the fan starts, you need a new water temp sending unit. If not, then consider a new fan #2 relay. This system is pretty simple.
Posted on Sep 24, 2008
  • 217 Answers
SOURCE: Kia Rio - Heater not working fan works but noise coming from fan.
open glove box and make sure that none of the papers from that can get down to blower motor
Posted on Jan 18, 2009
  • 3361 Answers
SOURCE: Snowflake blinking and air conditioner won't turn on.
If it is blinking it is in a 5 minute time delay.
It should settle to a steady snowflake after 5 minutes and come on normally.
Posted on May 25, 2009
SOURCE: 2003 Trailblazer Air Conditioner fan runs but no air out vents
Mine does the exact same thing. If I turn it off for a few minutes it will work again for about 15 minutes. Doesn't matter which area I select the air to come out. The fan blows hard but very little air comes out.
Posted on Aug 15, 2009
What does H1 code indicate?
Hello E, I appreciate your post!
I see that your Frigidaire air conditioner is displaying an error code of "H1". I have reviewed the air conditioner and the "H1" error code could be an "HI". The "HI" error code means that the room temperature is above the display range. I would recommend performing a reset on your air conditioner. In order to reset the air conditioner you need to unplug the power cord you can press the reset button and then the test button that should restart your air conditioner. If that does correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful for you. -Matt
Jan 22, 2016 | Frigidaire FRS12PYS1 12000 BTU Split...
Air conditioner fan is blowing but not air coming
If you mean that your OUTDOOR AIR CONDITIONER FAN MOTOR is blowing AND no air is coming out of the vents within your house, it clearly indicates to me that 1 of 2 things are wrong.
Either (1) your INDOOR AIR HANDLER is NOT running or (2) the INDOOR AIR HANDLER is running but your PLENUM has come apart.
If your INDOOR AIR HANDLER UNIT is NOT running, it could simply be the circuit breaker is OFF/TRIPPED and simply needs to be turned OFF; then turned ON. If that does not FIX your problem, then it is most likely your 5 micro-farad run capacitor for your indoor fan motor needs to be replaced. It will prevent your indoor fan motor from energizing. Worst case scenario would be your INDOOR FAN MOTOR has windings burnt and needs to be replaced. If your indoor air handling unit is equipped with a CONDENSATE VALVE CUT-OFF SWITCH, check to see if your drain pan is filled, thus energizing the switch. If the CONDENSATE VALVE CUT-OFF SWITCH is ENERGIZED, it will prevent the AIR HANDLER FROM energizing. That is the design and the reason for this valve.
Good luck.
Aug 26, 2014 | Heating & Cooling
My outside unit is working, but my inside unit makes noise and no air is coming out the vents. when i tuened the unit off a burst of cool air came from the air return vent.
You need to check the inside fan. Check the inside unit (where you change the filter), Open the panels and turn on the A/C Look for a panel switch located on the frame where you removed the panel and if there is a switch press it in. Listen for your fan to be turning, any scraping, scratching, means worn bearings, slow turning means bad relay, or capacitor. Hope this helps Fixya up.
Aug 13, 2011 | Whirlwind FH-778 Air Conditioner
My heater blows cold air why? I have a REAB 1010s need manual
Check your thermostat to see what your fan switch is set on. There should be two settings - auto and on. If it is set on auto, the fan only comes on when furnace runs. If the switch is set on on, the fan on your furnace is running all the time. Which means when temperature in the house reach what you have set on your thermostat, the furnace kicks off, but the fan keeps running and blows cool air. Some people run their fan all the time, especially if they have allergies, because that's a good way to clean the air.
Jan 02, 2011 | Heating & Cooling
What means h1
H-1. High pressure switch open. Check gas pressure/clean condenser coil/Check fan motor speed/Replace capacitor for defective.
Dec 17, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Intertherm heatpump outside fan will not come on, replace fan motor and capacitor, fan will not come on what could it be
some times heat pumps have a fan cycling switch to keep the head pressure normal in cool weather or check the defrost relay for the fan when a heat pump condenser gets frosted it will stop the fan and reverse into cooling mode for a few min. to melt the ice and this function is done by a relay or a printed circuit board if it goes bad you wont have voltage to the fan
Sep 30, 2010 | Intertherm P3RA-060K Air Conditioner
Fan does not run on high speed .
dear sir
if you how know to read a electric tester then check you air con,s selector switch please find out the fan motor wire in selector switch and test one by one and turn to fan on high speed mode and check on selector switch there electric supply comes on selector switch if it,s come and motor doesn't work then it,s mean motor high speed is defective if supply not come on selector switch then it,s mean selector swith is faulty .
if you can check like this then do if not then contact to a technician,
thank you
hope answer the question
please vote1
Sep 30, 2010 | Maytag Heating & Cooling
Heat would not come on and fan would not cut off even when thermostat was set to off. Took off the outside panel of the unit and red light was blinking 7 times - rollout switch fault. Since fan would not...
this means that the rollout switch was tripped by a flame coming from burners. could be a plugged fue or bad inducer motor, or a bad rollout switch. the fan will not shut off as a safety feature it keeps running incase the heat exchanger is to hot to keep a fire from starting. it will shut off after disconnecting power and restarting everything. watch the flames from burner when it lights to see if the actually roolout of the burner box toward the rollout sensor.
Dec 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
