Question about Fuji Cameras
Can I shoot videos on a Fuji Film S700 without "manning" the camera??
  • 109 Answers
SOURCE: flash not popping up or
The S700 does NOT have a manual release for the flash to pop up, but it DOES have a spring already. DO NOT try to force it! Set the flash to "FORCE", leave your lens cap on and waste a shot to allow the flash hood to pop up. Reset your flash to the desired setting and now the flash is already open and ready for use without the delay and the startling effect it has when your concentrating on framing your shot. As for the other problem of no flash in any setting: Check your menus to see if you have the flash totally disabled, check your batteries, does the "charge indicating light" come on at all between shots? In RARE cases, the actual bulb that flashes may be burned out, or a component in the flash circuit itself,such as the capacitor, may have gone bad. Did the flash ever work? If under warranty, return for repair or replacement. There are NO user serviceable parts in these tiny cameras
Posted on Jul 16, 2009
  • 109 Answers
SOURCE: I need a new lcd screen for my fuji finepix s700,
Sounds like your LCD screen is broken. Did you drop the camera? You may be able to find a screen or a broken same model camera with a good screen on eBay. Changing it out, however is NOT for the faint of heart. You will need tiny tools to work on tiny parts with very small electrical connections, a steady hand and nerves of steel with a service manual at your fingertips so that you disassemble only what is needed in the correct order and don't do additional damage. Still want to try it? I recommend taking it to a reputable camera store and getting a quote to repair it. Weigh that cost against the cost of replacing the camera. In the meantime, switch over to the Electronic View Finder. Good luck. (FYI: I will undertake the repair of anything short of a nuclear device, but I will not try a digital camera of any kind.)
  • 300 Answers
SOURCE: How do I change resolution On Fuji S700 Fine Pix??
If I remember it right, the resolution setting were under F button on the back panel, on the right from the Playback button.
Please, let me know if I'm right. :)
Posted on Jul 30, 2009
SOURCE: fuji s700 taking good moon shots
shutter speed 50 to 80 ISO at 64 get your apature as small as it will go lagest f number set your focus to single point and single focus if you feel comfortable useing manual focus it is better but my manual focus stopped working here is the link to one of my moon shots on flickr
Posted on Oct 06, 2009
SOURCE: Fuji S7000 shuts itself down...without a reason
was using s7000, on the view screen, it looked like a piece of paper kept coming down the screen, the more pic's I took, the lower it came down, finally covering the screen completely. Also the batteries, will not last but maybe 15 minutes.
Posted on Jan 22, 2010
Is there a manual available for the Fuji Discovery 1000 Zoom camera? Also, where can one purchase film for this camera.
You can download the manual at
The camera uses standard 35mm film. 35mm film is available in black-and-white, color negative (print) and color reversal (slide) forms (and others). 35mm film should be available at any camera store, as well as many drugstores and even supermarkets.
Jan 09, 2011 | Fuji Discovery 1000 35mm Point and Shoot...
I replaced a broken LCD screen and now the backlight does not work, is that a setting or is there something wrong with the new screen? Fuji Film Finepix s700
Some cameras have a button to toggle the back light on and off. It is possible that the old screen damaged the back light drivers on the circuit board. It is also possible the new screen is defective. I have seen both scenarios.
Jerry G.
May 12, 2010 | Fuji FinePix S700 Digital Camera
Fuji camera screen does not display picture even when screen is turned on when taking picture. but screen shows picture when you view pictures already taken
Hi dear, you need to see the manual (
Some camera only use viewfinder to shoot photo,The LCD is for setup and display photo only.Because it's off it will save a lot of battery power so that you can shoot more photos.Check it out in the manual.Have FUN!
Jan 21, 2010 | Fuji FinePix S700 Digital Camera
Broken battery cover HR-3UF/LR6 for a fuji film digital camera
Do a search for your camera model on Ebay, may be available.
If not Ebay, then search the Internet.
Sep 01, 2009 | Fuji FinePix S700 Digital Camera
Re: turning on s700
How are your pictures coming out? If the photos you take after seeing these lines come out good, then it could be the LCD only. However, if you are unable to shoot, or the photo files are damaged, there may be a problem internally. You should contact Fuji to see if they have heard of this problem, and if not, contact local camera shops to see if they can take a look at it. Also, digital cameras and card will only last so long - they will wear out much sooner than their film counterparts did.
Jul 24, 2009 | Fuji FinePix S700 Digital Camera
Text imprint on Video with Fuji S700 - remove?
As for the video goblins: Have you tried reformatting the memory card (in the camera)? It sounds like a built-in advertisement, though redirects to a site called which DOES do imaging software. Was it a free card from some promotion, or perhaps an off-brand card? Have you tried a different memory card and got the same results? I have an S700 and use it almost everyday, with different capacity and brand cards with no problems. Was the camera purchased new from a reputable dealer and came with a warranty (NOT "open box")? If using a different memory card doesn't solve your problem, I would tend to think that someone "flashed" the firmware in the camera before you got it and added those lines at the top and bottom of your videos. Does it do it when you are just taking pictures and not videos? Have you tried a different viewer program on your computer? Some freebie software video programs put watermarks (your ghostly lines of text at the top and bottom) into the video until you purchase the unlocked version. Do these text lines appear when you are viewing the video in the camera also? As for the "clicking" sound, I am at a loss because there is nothing "motorized" like in the old days of film when a motor was actually transporting the film through a shutter gate and sprocket wheels. No mechanical movement in digital photography, except when using the optical zoom. Is your lens cap swinging in the breeze and striking the camera body? Is the clicking sound steady and constant, or intermittent?
May 31, 2009 | Fuji FinePix S700 Digital Camera
Black-n-purple viewing screen my fuji s700 (s7000) camera
Sounds like a bad LCD as I had a similar experience with a different brand. The part itself is probably not very cheap... but if you have $120 you could get the same camera, referbished.
May 03, 2009 | Cameras
Cameras Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
