Question about Ovens
Automatic setting keeps coming on
Suddenly the automatic setting is coming on , am then unable to switch my oven on
    New Friend:
Fashion is must in your life because fashionable life can make you perfect for your looking & professional. Dean Winchester Jensen Ackles Supernatural Brown Long Coat
Posted on Dec 20, 2017
    Habit-Forming:
    New Friend:
  • 7 Answers
Womens fashion shopping sites
http://www.kartohome.com/womens-fashion-shopping-sites
Womens fashion shopping sites in kolkata, Womens fashion shopping sites in india, Womens fashion shopping sites in noida, in mumbai, Womens fashion shopping sitesin banglore, Womens fashion shopping sites in delhi, etc.
Posted on Dec 30, 2016
Do i need to light a lincoln impinger gas oven
No you dont need to light up an lincoln impiger gas oven. Its automatic thus you only need to conennect it to gas and power then switch on the power switch not forgeting to set the temparature.
Dec 09, 2013 | Lincoln Impinger 1116 Gas Oven
What does the F-9 code for a Ge oven mean
An F9 error code on a General Electric (GE) oven indicates that the oven's electronic control system has detected a problem with the automatic door lock. The automatic door lock mechanism prevents the oven door from being opened when the oven is set for "Clean" mode. The malfunction may be a jammed door lock mechanism, a pinched or broken wire, a faulty lock switch or a fault in the control board itself.
Jun 17, 2011 | GE Ovens
Our smeg oven is not working. the clock is on but the oven and grill will not work? Help!
Check that the oven is on the 'manual cooking' setting rather than Automatic, if its on Auto it will not come on until the time set.
Dec 12, 2010 | Smeg Ovens
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Wall oven on automatic with 0.00 flashing and will not go
You need to set the clock to the correct time and this should take it out of automatic mode, it should then work o.k
Nov 30, 2008 | Ovens
Unable to get cooker out of automatic mode
If your oven has timer and it is flashing AUTO then you need to reset it to manual for it to work.
If no timer then it could be a faulty door micro switch, located at the front left side..\Hope this helps, please leave feed back.
Thanks
Nov 25, 2008 | Hotpoint Ovens
Automatic button on lower oven
This is how I reset my U1420NOGB/FD7907 NEFF double electric oven that I inherited also without an instruction book.
There are 4 buttons in a row and then a timer knob that moves left and right.The first button is black,second has an arrow,,third has an arrow and fourth a hand symbol on it.Hold down together, the black button and the arrow button next to it.Without releasing either,twist the timer knob clockwise(to the right)until correct time is showing.Do not release the other buttons at all ,until time is ok.If you miss correct time keep going ,dont go backwards.When time is correct,,release black and arrow buttons and auto will stop flashng ,and oven work.If auto doesn,t stop flashing at this point press the button with hand symbol (manual)on it once.
Aug 27, 2008 | Ovens
New world 90TCgyro fan oven timer
From the New World Web site: "How do I set my timer/programmer into manual when it is set in auto? (5 & 6 button versions) On your timer there are two buttons, which read "cook time" and "ready time". If your timer is in automatic, you can return it to manual by pressing these two buttons simultaneously. REMEMBER - if your oven is in automatic it will not work until the time you set it to come on or if you return it to manual." Find more info on the link below: http://www.newworldappliances.co.uk/Common-Questions_p18.aspx
Jul 26, 2007 | New World 90TC Electric Double Oven
Oven light always on, no heat
probably the clock not set properly - you have the oven on automatic. switch off at mains, wait 5 mins and set the clock according to the manual. if the over-temp stat has operated, the oven goes dead
May 05, 2007 | Smeg S351X/5 Electric Single Oven
Ovens Logo
52 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
