I have the super general sgw 5800ms 5kg, I programmed it to wash, but it doesn't, it just starts beeping after a while and it won't open either
  • Barry Dec 31, 2016
    I switched off the power at the main DB and went to work, when I got home, I was able to open the door, but it doesn't solve my problem, the washing machine does not wash, it doesn't rinse, it doesn't drum clean, it just doesn't respond.
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: my servis m6011 5kg washing machine door won't
Possible that the door lock has jammed and so is not working.please check this link: door lock
Posted on Jul 04, 2012
Error 2 super general washing machine
I have super general washing machine model is sgw 620 this machine coming error E5
Oct 04, 2016 | General Washing Machines
SGW-7100 s
No question there !!
Aug 11, 2014 | Washing Machines
How to used super general sgw 5800
I do not know how to use Super General washing machine SGW 5800 I recently moved to a furnished apartment in Dubai I found this washing machine i could used it 1 time after many trails and after that i tried to operate it again but no hope. ...please help me
Jun 23, 2014 | Washing Machines
Super general washing machine (SGW 5800) front loader wont stop
Do an extra long rinse with no load, make sure door sensor in pushed in properly, then module should sort out itself
Apr 29, 2014 | Washing Machines
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
Super genral washing machine sgw 615 belt detail
Could you please describe the problem you are having?
Oct 17, 2012 | Washing Machines
My servis m6011 5kg washing machine door won't
Jul 03, 2012 | Washing Machines
Hi. I need some info on the fisher and paykel mw511 pride. When I press start the machine beeps and shows the short wash and spin lights. Any ideas?
Hi - I will need the product number found on the sticker in the rear of the machine - the controls has been changed so it needs to be programmed to a 5Kg machine.
I cant help you without that information as there are about 6 methods of doing this, the product number will tell me which is the correct way.
Jun 26, 2011 | Fisher and Paykel Washing Machines
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Hi i have an LG 5kg Fuzzy logic top loader and it will wash and fill the water but wont rinse or spin it does not beep or anything it just stops and the time displays stays on the same numbers and i can...
Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
Jan 21, 2011 | Washing Machines
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
