Question about Dryers
My engel wont run on 12volt but will on 240 volt
  • 400 Answers
SOURCE: I have an early grey model 39lt engel and it will
You will not find any service manual. You can try www.engelaustralia.com but I doubt it will help you. By the sounds of it your 12vdc oscillator is gone, it is usually a K3320 or similar on the old boards. On the new boards you would have to replace the board. G luck
Posted on Apr 20, 2009
  • 46 Answers
SOURCE: dryer wont get hot
check thermal fuse
Posted on Jan 21, 2010
  • 3289 Answers
SOURCE: what is the cprimary load
Ohm's law tells us that: volts = amps x resistance and watts =volts x amps. Watts (300) = volts (240) x Amps (?); or 300 / 240 = 1.25 Amps That means the inverter can supply up to 1.25 Amps to a 240 volt load.
The primary is 12 volts, this is just 1/20th of the secondary 240 volt output. Since the best you can ever get is 100% efficiency -this means you'll need to supply 20 times the current. 1.25 Amps (at 240V) x 20 = 25 Amps (at 12V). As a check, from above Ohm's law that states Watts=Volts X Amps we get: 12VDC x 25Amps = 300Watts. Check!
Some side notes. The Ohms law used above is for DC circuits and purely resistive loads on AC circuits. I do not know what your 1.25 A @ 240VAC load is - but I suspect it won't be purely resistive. Also, since we're working with an electronic inverter as opposed to a transformer and DC rectifier there are some things that push losses higher. You might need to provide a 30 Amp 12 VDC source voltage in order to provide the 1.25A @ 240VAC output. Lastly, I wouldn't not run the output at maximum for long periods of time - or at all. 1 Amp @ 240VAC would be much better.
I hope this answered your question & good luck! Please rate my reply - thank you.
Posted on Mar 09, 2011
  • 48482 Answers
SOURCE: Engel model MT45F-G4-S WORKS ON 12 VOLTS BUT NOT ON 240 VOLTS
Perhaps a blown fuse.
Posted on Jan 13, 2015
  • 2590 Answers
SOURCE: What temp is the best to run my 40 litre engel for 240 piwer and solar ??
Depends on how often and long the unit is left open, rule of thumb, fridge 4 deg C, freezer - 18 deg C.
Posted on Mar 03, 2016
We have an engel eclipse. We had it hooked up to 12volt and the generator and now it won't work on 12 volt. Any ideas?
http://www.engelaustralia.com.au/products_details.asp?productid=21365
While the below is not an eclipse, it is suggestive.
The only requirement needed for running your "E" or "F" series Engel Fridge - Freezer (The later Models) on a 240 volt generator is to ensure the generator you are using is A.V.R. Automatic Voltage Regulated. Please refer to your generators user manual. If it is an older generator with A.V.R., it doesn't hurt to add an in line spike protector or surge arrestor.
Engel Website
Jun 06, 2017 | Electrical Supplies
there is not BEST setting . it will be what keeps things frozen
Mar 03, 2016 | Engel Freezers
Works on 12v, but wont work on 240 v?
Does not make any sense that it works on 12 volts, but not on 240 volts......why would you try it on only 12 volts? How do you hookup just 12 volts? with the use of a rheostat? Are you trying direct current or alternating current?
Aug 11, 2014 | Engel MT45F 43 Quart Portable Refrigerator...
My camper fridge , Engel SRBT-565D Does not run on 12V ?
The compressor is on the way out and exceeds the current capacity of the 12v inverter circuit. The compressor runs on 32V AC @50 Hz and the inverter circuit is not able to produce sufficient current when the compressor becomes worn. It still runs on 240V circuit as this is a straight step down transformer from 240 volts and is not current limited..
May 20, 2012 | Freezers
What is the cprimary load on a 12volt to 240 volt 300watt inverter
Mar 09, 2011 | Electronics - Others
How much Power is Consumed by your Engel 12-Volt Refrigerator Freezer?
Refrigerator setting (minimum) and freezer setting (maximum - running continuously) the Engel 12-Volt Refrigerator Freezers use approximately 0.9 - 3.9 amps for the smaller units to 1.4 - 3.6 amps for the large 84 Quart MT80 unit. Basically your Engel 12-Volt Refrigerator Freezer uses less power than most 12-Volt coolers 1/2 their size. See our Engel Technical Chart for your particular 12-Volt Refrigerator Freezer.
Aug 12, 2010 | Bosch Refrigerators
Motor cycles on /off every few seconds
Bad relay on compressor or bad compressor.
Apr 07, 2010 | Engel 43 Qt.Portable Freezer.
Dryers Logo
Top Dryers Experts
