Question about Sony Televison & Video
Sony crt tv tda8366 picture blanking fault sound ok av out is ok osd ok plz help me
    Top Expert:
  • Sony Master
  • 75,169 Answers
If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result will display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one..
Posted on Dec 30, 2016
premtech
  • 934 Answers
SOURCE: JVC AV 35750 single horizontal line
Jeremey,
It's ring cracks on the solder joints of the vertical IC... IC421 i mounted to a small heat sink on the board. With the unit off and unplugged remove the board and locate IC421 (LA7832) and closely examine the pins connecting this component to the foil side of the board. You'll notice small rings around the footings that are actually open cracks in the solder, caused by heating and cooling over a period of years. Simply and carefully reflow some solder over these cracked joints, careful not to get the ic too hot in the process, and put it back together.. That should sole the problem...
Another problem we encounter a lot in the vertical deflection circuit of this unit are the two feeder caps C424 (100UF/35V) and C425 (470uf/35v).. If you're already there you might want to go ahead and replace these as well - save taking the back off again if they go bad..
Bill
Posted on Nov 13, 2007
jingjao
  • 252 Answers
SOURCE: SANYO TV MODEL CM20SP8S CHASSIS AC3-A20
try to fine tune your tv using the remote control, or, if you had knowleged in electronics adjust the sound IF transformer using a wood stick or plastic don't use a metal in adjusting the IF
Posted on Oct 10, 2008
dap_music385
  • 15 Answers
SOURCE: too dark sony model kv21gmr1
Warning: The following procedures should be done by an expert.
1.First step is to check the physical condition of the set.Before starting troubleshooting try to resolder the board and find any cold or loss solder.Then after plug the set and see if the filament of the tube glows.If not the trouble is in heater circuit.
2.After seeing the filament if it glows, check the CRT socket and open it.If you can see a sign of terminal decay such as greenish unwanted element on terminal surface,replace the CRT socket.
3.If replacement does remedy the problem check RGB drivers and resolder or replace jungle IC.
4.Try also to adjust the screen adjustment found in the flyback transformer.
5.Another possible cause is the vertical IC.Adjust the screen to full and see if their is a white horizontal line on the screen.If so the problem isin vertical circuit.
Posted on Jul 13, 2009
  • 21 Answers
SOURCE: Panasonic Quintrex 32" 100Hz CRT
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
  • 5 Answers
SOURCE: Sharp CX80H6
This style of failure with the CX80h6 and indeed other CX80 & SX80 series SHARP 80cm sets is usually due to problems with the PIP (picture in picture) sub-board. This small board plugs vertically into the main left hand PCB (seen from rear of set) and is sealed in tin-plate for RF shielding. I've had two CX80h6 sets recently with this exact failure and both had problems with the PIP sub-board. One needed a new regular on the board while the other had a dry joint on the connector. This sub-board is not available from SHARP anymore, but in most cases the failed component is a discrete that usually can be sourced in it's own right. So this sub-board is where I think you should start your fault finding.
Regards,
Romsey
Posted on Aug 15, 2010
How do I fix 4 inch vertical line on my t.v?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to TV screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 01, 2015 | Sanyo Televison & Video
Crt tv sound ok but picture goes on & off
try checking the tv/av tact switch,if it is grounded or normally close or has a resistance with pressing, replace it with a new tact switch..
Jan 03, 2014 | Samsung Televison & Video
Sony kv j14l1
If there is any blinks occurs to standby power LED during switch On, and the set switches off automatically?
Jun 01, 2013 | Televison & Video
Sony tv osd ok but no picture
Check whether it is in AV mode. If not, check and replace its tuner.
Mar 31, 2013 | Televison & Video
Sony KV- 20FV12 get no signal on screen. Same cable outlet works on other TV as a test. Cable ON in menu. Auto Set search produces search but still no signal.
Hello
If auto search is going on smoothly, and there is no stations on air is memorized, and display no signal, there are tow possibilities. The first one is antenna is not connected properly. Check the antenna connection for firm. The second one is tuner fault. If the tuner inside the tV is faulty, or it does not gets proper voltage to work, this type of fault land display will see on screen. Check if proper voltages are comming to the tuner section in circuit board. If voltages are ok, and still there is no signal display, just check it with external video input. That is, connect it to any dvd or cd with AV connector, and set the TV to AV mode and play a disc. If there is picture, the video side of your TV is OK. If not, Video-chroma-RF jungle IC is faulty, and not the tuner. OK.
Feb 03, 2011 | Sony KV-20FV12 20" TV
I Hooked my dvd player to my tv,and i get sound
The common problem with it is that the Av plug you are using is fault, you have to purchase a new one. Or maybe you plug the one of picture into the tv's "video in".
Oct 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
It was working fine then no picture dark sceen sound work fine
More information is required. Your backlight is lit (screen not dark) but I need to know what you have connected to the TV (your sources) and how they are connected. Does the menu/OSD (on screen display) work?
Oct 19, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
OK SOUND NO PICTURE
More information is required. What do you have hooked up to the TV and how is it connected? Do you have a menu/OSD (on screen display)?
Jun 25, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Tv seems ok by static and now, no sound (or very faint)
The problem you're describing sounds like a tuner problem. BUT you say that you have the same problem with A-V input too. That's weird!!! Possibly the electronic TV-AV switching circuit is messed up and stuck in the TV (tuner) position. If this is the case you DO have a tuner problem and a switching problem too.
Jan 14, 2007 | Hitachi C29-F200 29" TV
Tuner and AV problem
TRY TUNER ASSEMBLY SOLDER JOINTS COULD BE DRY OR CRACKS GOOD LUCK
Nov 06, 2006 | Panasonic CT-20G13 20" TV
Televison & Video Logo
76 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
