I lost my phone a couple weeks ago. got new one called to check on sim and they say my number dont exist.....
SOURCE: Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
SOURCE: n73: call not allowed
i think they lock the imei too so what you can do is unlock the phone either in repair store or online
SOURCE: Can I use unlocked Blackjack with Boost Mobile?
no, it cant be done, Only boost / nextel phones work with boost mobile system
SOURCE: WINFAX PRO 10 - PHONEBOOK PROBLEM
Here is the REAL solution for this problem with Winfax and Windows XP with Service Pack 2 or newer...and there's NO subscription charged for this solution like www.getfaxing.com tries to get you to do...
1. Go to Control Panel, then Regional and Language Options.
2. Click the Languages tab, then press the Details button.
3. Next, click the Advanced tab.
4. Put a check in the box: "Turn off advanced text services"
5. Restart your computer, start Winfax, and VOILA! Enter your numbers.
