How do you put new batteries in the remote control? We are trying to change them but have not been successful, we are obviously putting them in the wrong way.
    Top Expert:
  • Televison & ... Master
  • 49,960 Answers
The bottom of the battery goes against the spring
in the compartment where the batteries go there is an imprint in the plastic which shows the position of the battery
Posted on Dec 30, 2016
Testimonial: "Thank you Bill. We had one of the batteries in the wrong way. You are most kind."
Why won't MX 900 turn on even after putting in new batteries
The obvious question here is: are the batteries installed the correct way? Here is a web page to download the operator manual:
http://www.universalremote.com/pdf/MX-900OwnerManual.pdf
Also; are your batteries good? are they making good contact? Has the remote been damaged by leaking batteries? Inspect and test.
Do you have the original remote controls for the devices you are trying to control? If so... do they work? Remember... they will need batteries too!
Are there manual switches on the device you want to control? Do they work? Can you turn it on and off?
We are moving through a process to identify which items work, which are good and which are faulty.
Jul 19, 2014 | Universal MX-900 Remote Control
Changed batteries in remote now remote not working
Was your remote working before changing the new batteries?.
If yes, try another pair of batteries.
Nov 04, 2013 | Hunter 52" Ceiling Fan With Light And...
TV remote won't work after changing batteries
When battery is changed, all the previous settings will be lost from the remote control. You should once again set it to your device, using codes.
Jan 10, 2013 | DISH Network Televison & Video
Samsung DVD Remote contol: Cannot change over from TV to DVD. DVD Receiver/TV button remains on TV.
Hello, take the batterys out wait 15 minutes and put it back it will work if not change the batteries.
success!
Apr 03, 2011 | Samsung Televison & Video
When we press any button, all we get is the the red light on top left side of remote light up. channnels will not change, volume not change, won't power on or off. how can we fix this.
Sorry but without knowing the particular model number of the remote control or indeed whether or not it is a philips universal remote control, I can't give you a definative answer to your problem. I recomend however, if you haven't changed the batteries in your remote that you put new one's in as the batteries maybe too weak to operate the remote fully, this will at least eliminate this possibility. If you are using using a Philips universal remote control then try resetting the remote using the correct code for machine, if you don't know the code then try the Philips support website for the code for your tv. After that I would consider that either the remote or the machine has developed a fault where the remote's I/R no longer transmits or the machine's I/R receiver no longer works. Personally I would purchase a cheap / middle of the range universal remote and try that to see if that works as it is a much cheaper option than having the machine looked at by a technician. If you would rather there are online sites where you can by genuine remotes for most tv's etc but obviously this is a more expensive option than a universal replacement.
Hope this helps,
James
Apr 25, 2010 | Philips Televison & Video
Solid red light
Have about a 30 second window to replace batteries before all codes are lost and when you put in the new batteries it goes into programing mode. Re-enter codes and try it again. Have the same remote and it has happened to me before.
Mar 12, 2010 | DISH Network IR Remote Control
Samsung TV remote. I noticed today my TV remote wasn't working. I changed the batteries and noticed there had been some leakage from the AAA batteries. Since changing the batteries the 8 buttons on the top...
Giving you some hints. Battery leakage is one enemy of tv control and other remote control. They can corrode your battery spring contact, give contact bridges with neighboring tracks that can cause erratic behavior of your remote.
Some repairs can be done but doesn't guarantee success. First is try to clean the corrosion on battery contact = no power usually. Erratic behavior cause by contact bridging = battery leak residues.
Opening a remote control. Some have screws on its small foot. Covered by a rubber or sticker. Some are notch clip in strategic location you have to fry that one by one, opening first on its weakest side. In some don't want to be open.
Cleaning the board by a soft eraser is one way. After you open the remote. Commonly the button area where contact takes place.
If the first procedure and cleaning doesn't work. Buy new remote or use universal remote controller.
Aug 23, 2009 | Samsung TV Remote Control
Sony RM-ASP001 for 400 disk changer stopped working
Try the command code switch. I recently had a similar problem when my remote suddenly stopped working. It worked fine one time but nothing the next time I tried it.
I checked the emitter with a digital camera and found it was not working. I did the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
Hope this helps.
Dec 23, 2008 | Sony RM-ASP001 Remote Control
Ps3 dvd remote control will not work with system
Add me to the list. When it gets to the screen thats says press and hold down both enter and start it just sits there.
Anyone find a solution
Dec 15, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
Top Televison & Video Experts
