Scren lighrt is 0 & OSD LOCK appear on screen, how could axess the screeen setting ???
4 Suggested Answers
rubydu
  • 102 Answers
SOURCE: Monitor faulty
change the menu buttons, if problem not solve change memory ic of monitor kit
Posted on Jul 16, 2009
Slasher_X
  • 767 Answers
SOURCE: osd lock window appears at
See my tip here: http://www.fixya.com/support/r9424404-fix_osd_lockout_or_screen_display
Posted on Jun 08, 2011
Slasher_X
  • 767 Answers
SOURCE: osd lock appears on my
Hi there.
I suggest you see my tip on the OSD lockout problem here: http://www.fixya.com/support/r9424404-fix_osd_lockout_or_screen_display
Slasher_X
Posted on Jul 21, 2011
How do I unlock the OSD lockout on a Samsung B2430H monitor. I've unplugged the power and computer connection cable. Tried holding the menu and auto keys nothing seems to work. There is just the...
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear.
Sep 09, 2013 | Samsung SyncMaster 753S 17" CRT Monitor
There is a blue lock that appears in the center of the screen
Change the OSD Lock option from ON to OFF by following these steps:
Press the Menu button on the remote or the control panel for 15 seconds to unlock the OSD menu.
When the OSD menu appears, select the Management option at the Main Menu, then select OFF at the OSD Lock option.
Select Exit to save the setting and exit the menu.
hope this helps
Aug 07, 2012 | Dell OptiPlex SX280 PC Desktop
How to unlock osd lock lg flatron w1643c
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear. system admin
May 30, 2012 | LG Computers & Internet
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
How to get rid of osd lock which appears frequently on screen?
Hold the MENU button for ten seconds to unlock or lock the OSD.
This information is from your manual for the L194WT:
OSD LOCKED/UNLOCKED
Please rate me if this solution works for you
Thanks......Have a great time
Jul 08, 2010 | ViewSonic Computers & Internet
The sceen say`s osd lock out and also the menu screen for the monitor is stuck on . The menu+- and auto set buttons wont respond
Try unplugging it for 1-2 minutes & try again. If not & it's a crt monitor not lcd then toss it & buy a new monitor. If it's an lcd,check the maker's website for additional info.
May 12, 2010 | Computers & Internet
Problem is i cant adjust colour and size because of showing "LOCK
This is how:
OSD Lock & Unlock
When pressing the AUTO button after locking the OSD
When pressing the MENU button after locking the OSD
This is the function that locks the OSD in order to keep the current states of settings or prevent others
from adjusting the current settings.
Lock : Hold down the MENU button for more than five (5) seconds to activate the OSD adjustment
lock function.
Unlock : Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment
lock function.
User manual:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=&prd_mdl_name=2233BW&prd_ia_sub_class_cd=P
Apr 23, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
I am using view sonic monitor & i am facing a problem with it .At the centre of the screen there is a message in blue colour filled box that"osd lock"its irritating
OSD and Power Lock Settings
• OSD Lock: Press and hold [1] and the up arrow 􀁓 for 10 seconds. If any buttons are
pressed the message OSD Locked will display for 5 seconds.
• OSD Unlock: Press and hold [1] and the up arrow 􀁓 again for 10 seconds.
• Power Button Lock: Press and hold [1] and the down arrow 􀁔 for 10 seconds. If the
power button is pressed the message Power Button Locked will display for 5 seconds. With
or without this setting, after a power failure, your LCD display’s power will automatically
turn ON when power is restored.
• Power Button Unlock: Press and hold [1] and the down arrow 􀁔 again for 10 seconds.
Well this Should resolve ur issue
May 13, 2009 | ViewSonic E70fb 17" CRT Monitor
OSD lock - I think
This is for Viewsonic LCD, but it's probly pretty similar for you...
OSD and Power Button Lock Modes
OSD Lock This mode locks all current control settings and prevents access to
the control menus until this mode is unlocked.
? OSD Lock: Press and hold [1] and the up arrow  for 10 seconds. If any
buttons are pressed the message OSD Locked will display for 5 seconds.
? OSD Unlock: Press and hold [1] and the up arrow  again for 10 seconds.
raj, rajkumar.ranju@gmail.com
Jul 22, 2008 | ViewSonic E70f 17" CRT Monitor
ViewSonic E70f 17" CRT pincushion changed itsself continously
Press the [1] key & hold it for 10 seconds / till OSD Unlock appears on the screen. When OSD unlock appears on the screen , release [1 ] & press [1] or [2] key. This will unlock the OSD.
May 22, 2008 | ViewSonic E70f 17" CRT Monitor
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
