Besoin d`un code pour mannette urc-386 pour dvd intertek model 22001
  • Televison & ... Master
  • 6,694 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Posted on Dec 30, 2016
I had a Dell TV 2007, and I have`nt tv code for use with an universal mannette.
You can try using the mannette's code search function to find something that works. If a search through all codes stored in the mannette fails, you may have to try a different universal mannette. All universal mannetes do not contain all possible codes.
Mar 27, 2017 | Dell Televison & Video
Bonjour mes amis ofait j'ai un probleme avec mon blackberry 8520. ;j'ai besoin de connaitre mon MEP et et MEP2 si vous pouvez m'aider en ce moment je n'ai pas un autre phone pour dire
You have not menti0oned what is the problem with your Blackberry mobile. About the MEP andMEP2 codes, I dont know about MEP code. But MEP2 code is used to unlock mobiles. Hope you too know that. I know a good website to get the MEP2 code. You can check out ClassicUnlocking.com . You can select all the mobile information from the list of models provided and buy the code. Hope this will solve your problem of MEP2 code. Sorry i couldn't help you with MEP code.
May 20, 2012 | RIM BlackBerry Curve 8520 Smartphone
Ne trouve pas le pilote du dvd ram gt 31n le mien ne fonctionne plus
QUESTION: "can not find the driver dvd ram gt 31n mine no longer works"
Salut.
Il n'est pas clair ce que vous entendez par "DVD-RAM 31n GT." J'ai fait des recherches de ce numéro de modèle "GT 31n", sans succès. Je vais donc supposer que c'est le numéro de modèle du lecteur de disque optique interne (DVD-RAM) de votre ordinateur.
Vous ne dites pas quel système d'exploitation que vous utilisez. Vous avez également choisi de ne pas donner toutes les informations concernant votre ordinateur ou de ses spécifications. Ces aurait pu avoir été des éléments d'information utiles.
Presque chaque système d'exploitation informatique, en particulier les courants, ne nécessite aucun pilote supplémentaire pour les lecteurs optiques comme celle du lecteur DVD-RAM. Les pilotes pour fonctionner presque chaque lecteur optique sont déjà intégrés dans le système d'exploitation.
Le seul logiciel que vous pouvez télécharger pour ce lecteur optique est Firmware. Firmware améliore et renforce les spécifications de performance, mais on peut rarement réparer les défauts ou restaurer un disque optique non-fonctionnement d'une fonctionnalité normale avec Firmware.
Vérifiez l'étiquette pour le fabricant du lecteur. Il est susceptible d'avoir été fabriqué par l'une des entreprises connues pour ce produit (LG, Sony, Hitachi, Samsung, etc.) Allez sur le site Support et Téléchargements de cette entreprise et vérifiez les mises à jour du Firmware associés à ce lecteur optique et de votre système d'exploitation.
Je suis presque certain que peu importe où vous regardez, vous ne trouverez pas de pilotes pour ce périphérique.
Si l'appareil ne fonctionne pas il pourrait être un problème de Jumper Settings. Regardez à l'arrière du lecteur pour voir le Jumper Pins et le Jumper. Regardez sur l'étiquette pour voir un diagramme des paramètres différents pôles.
Si il est toujours défectueux, essayez de le connecter avec un autre câble IDE, et essayez de nettoyer la lentille laser avec un Nettoyeur de CD DVD Lens.
Si il est lente, c'est peut être un problème avec l'ordinateur. Certains systèmes d'exploitation va automatiquement ralentir un lecteur optique à une faible vitesse de base après il a démontré un certain nombre d'erreurs de lecture.
Aussi essayez de vérifier et modifier les paramètres (SATA /) IDE dans le BIOS.
Enfin, le lecteur peut aussi être défectueux et peut-être a besoin d'être remplacé.
J'espère que cela aide.
Si cette réponse va certaine manière à aider à résoudre votre requête, un problème ou de défaut, s'il vous plaît prendre le temps de l'évaluer.
Cela permet aux fournisseurs de solutions, comme moi, mieux comprendre les besoins et le point de vue des questionneurs, comme vous, et nous guide dans l'exploration des meilleures façons de fournir les réponses les plus complets de qualité, utiles et de haute et de solutions que nous pouvons.
Si vous avez besoin d'aide, s'il vous plaît n'hésitez pas à poster une autre question ou ajouter un commentaire à cette question.
Merci pour avoir utilisé FixYa.
Sep 15, 2011 | Computers & Internet
J'ai perdu les code pour programmer ma manette urc-386 avec ma t.v Toshiba.
jai besoin le code pour ma manette URC-386 pour ma TV LG FLATRON
Jan 15, 2011 | Televison & Video
2003 Yamaha FJR1300 code 12
Salut, Anonyme pour ce sc?nario, vous aurez besoin de votre service, fiche de pi?ces et manuel du propri?taire si vous ne trouvez pas le meilleur outil que vous avez achet? pour votre Honda, d?sespoir non, pour un z?ro z?ro, vous pouvez en t?l?charger un autre. Pour plus d'informations sur votre probl?me et les pr?cieux t?l?chargements "GRATUIT" dont vous aurez besoin pour la visualisation ou l'impression, veuillez cliquer sur les liens ci-dessous. Bonne chance et bonne journ?e.
error code 12
Yamaha Fault Codes
Yamaha 2003 FJR1300 Service Manual
OEM parts for Yamaha
YAMAHA FJR1300 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 05, 2017 | 2003 Yamaha FJR 1300
LE MOTEUR NE DEMARE PLUS.CODE ERREUR 60 YAMAHA YZF R1 2007
Salut, Tom pour ce sc?nario vous aurez besoin de votre service / manuel du propri?taire si vous ne pouvez pas trouver le premier et le meilleur outil que vous avez achet? pour votre Yamaha , ne d?sesp?rez pas , pour un simple $ 10 , vous pouvez t?l?charger un autre. Pour plus d'informations sur votre probl?me et pr?cieux t?l?chargements "libre" que vous aurez besoin s'il vous pla?t cliquer sur les liens ci-dessous . Bonne chance et bonne journ?e .
http://www.r1-forum.com/forums/105-07-08-r1-mechanical-help/211975-error-code-60-a.html
http://www.r6-forum.com/forums/57-garage-mechanical-help/123725-fault-code-60-where-should-i-start-help.html
Yamaha R1 YZFR1 2007 2008 Service Repair Manual Download Download Manuals...
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Dec 25, 2010 | 2007 Yamaha YZF-R1
I am having problems programing a universal remote control, I can't find codes for PRIMA TV
urc-386-remote.blogspot com
URC-386 HRS-GLOBAL
URC-386 Universal Remote Control
http://urc-386-remote.blogspot.com
Jan 19, 2010 | Prima C2012 TV
Remote control code
contact support at prima for the code lists for your model at
http://www.primaamerica.com/support.asp
or the remote manufacturer at
http://www.hrs-global.com/?cat=contact_us
one or the other should be able to inform you of what is required to get it working.
Nov 30, 2008 | Prima C2012 TV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
