Question about Karcher Garden
Unable to connect high pressure hose to gun base on Karcher 3.99M
I am able to insert the high pressure hose to the gun base, but it will not click or lock into place. As such water leaks (big time). The hose connection head will make it past the gate inside the gun so I know the it is being inserted correctly, but it will not click in like it did the first time around. I have checked the manual as the instructions are very simple i.e. just push it in and it should lock into place with an audible "click". Please note that this unit is brand new and only been used twice in as many months, so this should not be a maintenance issue.
Has anyone else experienced this or is this a warranty issue????
You probably need to slide the rubber sheath back a quarter inch or so so that the "C" clip slips between the rubber and the wide part of the brass connector. That is what I had to do.
Posted on Apr 17, 2010
    Brigadier General:
  • 4,090 Answers
I am presuming when you insert the wand that you are also twisting it into place?
The click usually occurs when the wand is twisted and it locks. Simply pushing it in without twisting will cause water to flow big time as it's not sealed.
If you are doing all correct then the seal is damaged and should be returned for a warranty claim
Posted on Jul 22, 2009
I don't have any pressure. I have it connected to 3/4" hose, have no kinks in the hose and have the water open all the way. The high pressure hose is new for the machine Suggestions? I have an older...
Check where the hose goes on the machine there should be a screen in the connection that is probably dirty. take it out and clean it with a wire brush. Also take the gun off the hose and see if water comes out then. If so the gun has to be cleaned.
Mar 19, 2011 | Karcher Garden
Water leaking from spray gun
It depends on were the water is leaking from on the gun. If the water is leaking from were the high pressure hose goes into the gun it could be that on oring as been damaged. If the water is coming from the trigger you may need a new trigger gun.
If you tell me your model number (1.xxx-xxx.0) i can tell you the part number that you will need to give to your Karcher dealer/supplier to replace it.
Jan 02, 2011 | Karcher Garden
Cant get my soap dispenser hose working on my karcher winner 10, any suggestion?, lost my instructions manual so dont know weather i need to be doing anything for it!
If you have not yet found a solution, then here are some steps to take.
1. The soap dispenser only works on low pressure!!!!!!! So you have to REMOVE the high pressure Sprayer so that all you use is the Trigger Gun without the Extender.
2. Pull out the thin Plastic Hose with the filter attached in the end, and insert into your container of detergent.
It will only splatter the detergent over the area you want to clean, so you will then need to REATTACH the SPRAYER into the hand gun to work with the soap to lather, clean and spray of till clean.
This seems to be the way the system works on this model......also known as K2.36M (AU) in Australia or (EU) in Europe on the Karcher.com.au site then Service then Manuals. or on the link below.
Hope this helps any of you who has misplaced their Owners Manual just like I did and had a great problem trying to find a link as Karcher doesn't recognize the Model No: as Winner 10 or 11.
Cheers, Luke
Nov 19, 2010 | Karcher Vacuums
Why dose my Karcher K2.35 keep blowing the gun hose off?
There is a good chance you are missing the black plastic clip that holds the hose into the trigger gun. If you look at where the hose goes into the gun there should be a flat slot where a black plastic clip would slide in and keep the hose into the trigger gun.
Oct 24, 2010 | Karcher 2500 PSI Pressure Washer
Does not give a continous high pressure flow cuts in and out
that is sure signal of insufficient water supply!
try easy solution first:
make sure that your mains is fully open, that tap on whihc hose is hook up is fully open and hose is of "decent" diameter to allow sufficient flow.
if above solution do not work then you need to make another, more difficult arrangement:
prepare 20litres pressure tank with inlet connected to mains and outlet by short hose to power washer, fill it with water from mains, keep it under mains pressure and use karcher power washer normaly. this will solve water supply problem. twenty litres will last about 2min, because it is re-filled, under standard pressure therefore it will last about 3min...
third possibility is to stop washing...
if you find my advice helpfull, please do not hesitate to left the comment and vote for me, thanx!
Jul 31, 2010 | Karcher K2.26 Electric Power Washer
High pressure hose. How do you get if off the karcher k 3.99
there is a small clip on the triger where the hose attaches to is, pull clip out pull hose off
Jun 16, 2009 | Karcher K 5.85 M Electric Pressure Washer
Karcher K 3.68 M operation
These units have pressure valves that automatically turn off the pump once the pressure is high enough. The pressure switches do fail and sometimes stick and act as you've described.
May 07, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Can't get the spray gun onto the hose from the washer...no manual
Your posting is incomplete, so I'm not quite sure what we're dealing with here.  I understand the machine and the high-pressure hose are Karcher - right?  Is the gun also a Karcher part?  If all are Karcher parts, they should fit unless the screw threads have been damaged.  If they are not all Karcher parts, they will not fit because Karcher connectors are different from almost all others.
Please post again if this doesn't help, giving as much detail as possible, and I'll see what else I can offer.
Apr 04, 2009 | Karcher PSI Electric Pressure Washer
How do i connect the hose to the karcher k399 handle
Pop out the plastic tab at the base of your gun (use point of screwdriver/knife).
Then push the hose connection into the gun and push the plastic tab back into it's slot. This will hold the hose in place.
Jul 02, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
349 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
