Question about Refrigerators
Fridge not getting cold enough after really hot weather
  • 146 Answers
SOURCE: fridge doesn't get cold enough
 If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty.
If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
Posted on Nov 03, 2007
SOURCE: Our caravan fridge electrolux rm4206
remove the fridge from caravan, now turn upside down and leave for as long as possible. what this does is get rid of any air locks in the gas. once left for a month or too turn back and leave for a day to setal and refit to caravan.this should solve your problem, it has been tried and tested on our caravan and worked. (This will not work on a domestic house fridge because they work on a different system)
Posted on Feb 07, 2009
  • 544 Answers
SOURCE: ge profile atrica not getting cold enough
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
Posted on Mar 29, 2009
Sea Breeze
  • 4655 Answers
SOURCE: My fridge IS NOT getting cold enough. Temp control is maXxed. The freezer seems cold enough and making ice cubes. this is a GE fridge model #TBF16DRB
Try cleaning the coils beneath the refrigerator. Its possible that they are covered with dust and blocking a fresh flow of cool air to help cool the refrigerator inside. Just a little cleaning there will make a big difference. Check your door seals also a small opening will let the cool out and the hot in. Thanks, Sea Breeze
Posted on Apr 27, 2009
Instant Help
  • 73 Answers
SOURCE: Refrigerator not getting cold enough
1. If your refrig is a frost free type, you may want to check the freezer to ensure it isn't over loaded with food stuff, reason being air must flow freely threw out the entire refrigerator in order for the thomostat to work correctly. You should also check the coils on the rear of the refrig and make sure they are clean and dust free. If you still have problems after trying the above; you may need to call a repair service to come out and check the unit.
2. Pull it away from the wall if you can and try to vaccuum or dust off the vents and fans in the back (you might want to turn it off while you do that). We had a problem with our old fridge and it turned out that the vents were just really dusty and weren't pulling in enough air. Have you tried cleaning the heat exchange coils which are underneath or behind the refrigerator depending upon the design of your unit? If these are covered with dust bunnies the dust serves as an insulator and prohibits them from shedding heat from the coolant that passes through them. Hope that helps...!!
3. you must visit repair-shop if the problem still persists.
Good luck in correcting your problems.
Best Regards.
Posted on May 27, 2009
What setting should I have fridge on I doesn't feel cold enough I have it on 8c
fridge settings go from 8 hot to 1 really cold
start setting at around 4 monitor the green vegetables in the bottom draw ( crisper draw ) and adjust if they show signs of too cold ( browning or wilting of leaves
Jun 04, 2017 | Refrigerators
Heat doesnt work in my jeep cherokee when driving but when sitting heat works
Put a piece of cardboard in front of the radiator. Only if it's cold out though, Usually in really cold weather, the cooling affect of the cold air circulating around the radiator keeps the fluid from getting hot enough to produce heat unless your running in park.
Dec 17, 2013 | 1998 Jeep Grand Cherokee
Fridge does not seem cold enough. It is maybe 12 years old. Do I need a new fridge
The heat between the doors is normal but not really hot. if sides and between the doors is real hot then you have an air flow problem. Vacuum coils under it and coils by condenser fan. Check your Condenser fan by compressor.
Jul 28, 2013 | Refrigerators
My maytag side by side is not cooling right.when the weather gets hot and humid the freezer won't freeze anything and the fridge isn't cold enough.when the weather is cooler everything works fine. it is an...
Clean the condenser coils underneath the fridge.
Check condenser fan at bottom of back of ref.
that its not slowed or stopped
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
Aug 02, 2010 | Refrigerators
Freezer not getting cold enough.
That is normal since the cold control is on the refrigerator side and is satisfied. It needs to be in a heated environment and not in an unheated garage.
Jan 02, 2010 | Frigidaire FRT21P5A Top Freezer...
I moved my whirlpool fridge and now the doors get really hot and the fridge won't get cold enough.
Check to make sure the condenser fan underneath is running. You can access it from the back behind the cardboard cover. It should run when the compressor runs. Test it here- How to check everything
Sep 03, 2009 | Refrigerators
Fridge not getting cold enough. the temp in the fridge is 66.6! help please! less then a yr. ago i replaced the gasket, so i know it's not that. i also have it on the coldest setting. i wasn't having...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 14, 2009 | Refrigerators
Kenmore fridge is getting super hot
These fridges are designed that way believe it or not. Designed to eliminate condensation on surface but in hot weather they get really hot then stay warm until compressors cooldown. I would not worry.You can also call kenmore sears and they can tell you if it is fine.
Aug 12, 2009 | Kenmore Refrigerators
Frigidaire Freezer Runs Warm in Cold Weather
hi there the problem you have is that the temp in the garage is to low, the fridge part of your fridge freezer has priority and will only activate the compressor when req'd ie. in cold weather the fridge may not need to switch on the compressor for days at a time this is when the freezer will defrost.
All you can try doing is having some very low heating in your garage in the cold weather
hope this is of help.
Dec 11, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
