Radio won't recognise dongle,says no files. - Computers & Internet
I accidentally inserted a wifi dongle instead of a flash drive into the sub port of my wireless Bluetooth boombox, the Sony ZS-RS70BTB, will this break it? The dongle was reading NOT SUPPORTED.
No, because the voltage of all USBs are 5 volts. It says unsupported because your Boombox doesn't recognise a wifi dongle. I guess it is looking for music files. The wifi dongle will be fine as it won't recognise a Boombox as it is looking for a computer or television.
Jun 27, 2016 | Sony Audio Players & Recorders
Lg dongle won't connect need help I have all lg electrical equipt
some dongles are made by only to connect to the desktop or the laptops only. better thing is ask the service provider who sold that dongle.
Sep 02, 2012 | LG ANWF100 Wireless dongle
Trying to connect to internet the tv recognises the router but then says contact your provider as the DNS Server number is wrong i have contacted my provider AOL they have checked my router set up and
Check first if you have the right Dongle, and if it is connected to the right USB Slot.
The Dongle must be right for Model, and Brand, and it must be inserted into the HDD USB Slot only.
Then the Dongle and TV will install themselves. Wait a few minutes then Press "Source". It should be loaded.
Aug 16, 2012 | Computers & Internet
When i connect my tiny usb 2.0 bluetooth edr dongle mini wireless adapter my pc says usb device not recognised can you help me resolve the problem please
Please update the USB 2.0 drivers and try to use the device. If you are using desktop machine then try to connect the device in back USB port.
Feb 18, 2012 | Tiny Computers Tiny USB 2.0 Bluetooth V2.0...
Dongle for origins digitizing software won't work
I have Organs but no dongle where can I buy one.Or could you use other dongle with it or what can I do.
Jan 16, 2012 | Sewing Machines
I have purchased 5D Professional and cannot get the dongle installed, I have put the correct product activation code in and it has been recognised but will not accept that the dongle is inserted in my USB...
I purchased 5D pro and have the same problem. I contacted Viking and was told it was a known problem with no fix. I was instructed to take the dongle to my dealer to see if they can activate it.
May 21, 2011 | Husqvarna Designer I
My Lg 32ld550 and usb dongle won't "see" my wifi network. Can't get it connected.
Che\k in device manager if the dongle is working properly. For hat in run type "devmgmt.msc" and find the dongle and double click on it. If it says some problem try re-installing the drivers..if it says device is working properly then restart the computer and search for the wi-fi. If it still doesnt recognise take the dongle to a hot spot like a cafe and check if it can detect wifi. If it detects else were its and issue with the wifi at home..if it doesnt recognise the wifi in hotspot its an issue with the dongle.
Hope this helped.
Jan 23, 2011 | Computers & Internet
Laptop will not discover bluetooth devices
just make the blue tooth visible like on the phone
Apr 14, 2017 | Nokia Mini USB Bluetooth Dongle w/...
Problem setting up a dongle to my PC
NEVER install the dongle before the CD.
What has happend is windows has automatically installed your dongle with the wrong driver.
Try this.
Keep your dongle plugged in.
Goto start > control panel
Click system
Along the tab at the top select hardware, now click device manager.
Find your dongle, it should be under 'network adapters' (if you are not sure if it is the right one, unplug it at this point. If it dissapears from device manager - that is the one)
Now, click on it in device manager and press delete. Click OK to deleteing the driver.
Now, follow these steps carefully:
Unplug the dongle.
Restart the computer.
Start installation from CD
Only plug in the dongle when it tells you to, or the installation is complete.
Hope this helps
Mar 03, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
