Question about Electrolux Kitchen Ranges
Regarding my ew30gs65gs1 electrolux range. The touch circuit board is "very" dirty. What can I safely use to clean the touch circuit biard and the glass. Thanks Stacy Whetzell
5 Suggested Answers
ndguy2481
  • 251 Answers
SOURCE: How to clean lower oven of 30" electric range by electrolux
try a lemon heated and the acid will eat away the food
Posted on Dec 01, 2008
TechBrian
  • 15 Answers
SOURCE: wave touch panel comes out of sleep mode by itself
Your range should have a two year part and labor warranty so contact Electrolux to schedule service. They will preorder and ship you the parts prior to a servicer arriving.
Posted on Mar 21, 2009
KevinWhite
  • 1902 Answers
SOURCE: I need to replace the
Hello & Welcome to FixYa
The heating issue can be caused by the oven temp sensor that is bad and needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement. You can view this video for glass replacement:
Please get back to me if you have any other questions.
Kevin
Posted on May 28, 2011
dcramer531
  • 1654 Answers
SOURCE: Between glass dirty on kenmore glass top range
The glass tops come off so they can be cleaned.
Changing the maintop on a Kenmore electric range is not difficult. Kenmore electric ranges will have either an open coil maintop or a Ceran glass maintop. The open coil maintop has the heating element coils visible and is the most common type of electric range. The Ceran glass maintops have the heating coils under the smooth glass maintop. Both maintops remove from the range in the same manner, but the Ceran glass maintop has securing screws in the front of the range.
  • Open the oven door and locate the screws under the lip of the maintop that secure the maintop to the range. Remove the screws with a Phillips-head screwdriver and close the oven door.
  • Grasp the sides of the maintop and slide the maintop forward until you can see the green ground wire and a bundle of wire in a strap near the rear center of the electric range.
  • Remove the screw that secures the green ground wire to the range with a Phillips-head screwdriver. Remove the screw that secures the wiring harness strap that is next to the ground wire screw with the screwdriver. Slide the maintop off of the range.
    Posted on Oct 23, 2011
    I have an electrolux gas range, model ew30gs65gs1. I get error code f14 when I plug it. Clear error code, try to set anything except the clock on the glass panel and o very f14 again.
    The F14 error indicates a problem between the touch pad and the display control board. This could be a wiring problem so check the wiring harness between the two parts. Make sure that the wires are properly seated and check for corrosion at the connectors. It could also indicate that either the touch pad or the display control board (or both) are faulty. If your wiring is good, you need to replace the touch pad. If the error persists after replacing the touch pad, you have to replace the display control board as well.
    The parts are available here: http://www.searspartsdirect.com/model-number/ew30gs65gs1/1412/0124250.html . See parts 19 and 20 on the control panel diagram.
    I hope this helps.
    Dec 28, 2016 | Electrolux Kitchen Ranges
    What does F 14 mean on electrolux stove?
    f14 misconnected keyboard cable. 1) verify connection between display board and touch panel (2 ribbon electrical cables).make sure the cables are completely seated into the connection point both ends. If the cables are connections check ok then replace the touch panel. If the problem persists still occurs replace the complete display board
    Dec 05, 2016 | Electrolux Kitchen Ranges
    What does code d-o mean
    Good Afternoon friend, that's a great question!
    From my understanding your Electrolux range is displaying a code of "d-o". The code could stand for open door, could be missing a sequence, or a miscommunication within the control panel. I would recommend performing a reset on your range and you can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not help resolve your issue I would suggest having a professional technician out to perform a proper diagnosis and repair. Hope this information is helpful. -Matt
    Mar 09, 2015 | Electrolux Wave-Touch EW30GS65GS 30"...
    On my Electrolux wave touch range, the burner buttons remain lighted, won't go onto sleep mode and when touched will not cause a burner to begin heating. It's as thought they are all stuck in the ligh
    Hello friend, thank you for your post!
    I understand that your Electrolux range burner buttons are remaining on. I have identified a few possibilities as faulty burner buttons, bad switches, or a disruption inside the control panel. Let's perform a reset on your range which can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue I would suggest consulting with a professional for proper repair. Hopefully this helps. -Matt
    Oct 11, 2014 | Electrolux EW30MO55HS | 30" Built-In Drop...
    My Electrolux wave touch range won't turn on after self clean.
    Hello friend, thanks for your inquiry!
    I understand that you have performed a self-clean on your Electrolux range and now your display is not showing. From the information you have provided it sounds like the control panel may have shorted out or a wire to your panel may have shorted out. I recommend reaching out to a technician for further assistance with properly diagnosing your range. Hope this helps to some degree. -Matt
    Sep 30, 2014 | Electrolux Kitchen Ranges
    Hello CRemo, thanks for your inquiry!
    How to fix error code 15
    Hi friend, thank you for your inquiry!
    Based off your post your Frigidaire range is providing you an "E15" error code. "E15" stands for a signal loss between the oven relay and EOC (Electronic Oven Control) I would perform a reset on your appliance. You can do that by disconnecting power to your range by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
    If that does not correct the issue it could mean that your oven relay board or electronic oven control may need to be replaced. If that is the case I would suggest seeking assistance from a professional to avoid any unnecessary part purchases. -Matt
    Sep 28, 2014 | Electrolux EW30ES65GS 30" Slide-in...
    Wave touch panel comes out of sleep mode by itself
    Mar 21, 2009 | Electrolux EW30ES65GS 30" Slide-in...
    Kitchen Ranges Logo
    46 people viewed this question
    Top Electrolux Kitchen Ranges Experts
    Craig Butler
    Craig Butler
    Robert Plante
    Andrew Taylor
    Andrew Taylor
    Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
