Question about Boating
Overheating alarm stayed on on my johnson 2010 outboard motor and engine doesnt want to rev up
  • 157 Answers
SOURCE: relay switch for power tilt for Johnson outboard motor 40HP
Hello jalbin0308, I may can help but "NEED MORE INPUT" said ET. Model, year, HP, ect.
Posted on Oct 30, 2008
SOURCE: Johnson Outboard Motor 175HP
Not knowing what year it is...Light and alarm? Reason: overheat low oil etc. check water flow..water pump. The motor is most likily going into S.L.O.W mode. its a fail safe system. Last possibile reason ..CDI box and or stator.. pull plugs check compression...should be 120-150 lbs.
Posted on Feb 21, 2009
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Posted on Jul 25, 2009
  • 6 Answers
SOURCE: 35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Posted on Aug 22, 2009
Testimonial: "Hi, thank you very much for your help, I will strip the carb down and have a look. Once again, many thanks, I am very greatful"
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, How ...
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number - Evinrude
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
1976 johnson outboard,55EL76E is this a two stroke motor? It doesnt have any markings either way
Yes, it's a two-stroke, mix ratio 1 on50 tcw3 is fine for those old runners...
Sep 14, 2016 | Boating
How to set timing on 75 hp johnson outboard
creates an impulse to the cid as a magnet passes by . not much adjustment to timing small screw toward the front that moves the stator perhaps a 1/4 inch .
Aug 17, 2015 | Johnson Evinrude Timer Base, 6 Cyl 75-85...
Why does my 1991 60 hp Evinrude outboard alarm sound and motor sputter occasionally?
when the alarm goes off is the engine getting hot, try running it in gear under load while tied up and with the engine cover off see how hot it gets and if the water i circulating all the time , might have cooling problem !
Aug 04, 2014 | Seloc Johnson Evinrude Outboards 1973 to...
2003 johnson outboard motor cranks but cuts out
can only say DUH .sounds like a battery problem or a starter motor .
Apr 22, 2010 | Boating
40 Hp Johnson outboard motors stalls out after a few minutes running then takes forever to start again
May likely be one of two problems:
1. Fuel flow: Make sure fuel tank vent is open and not blocked while engine running. Check primer bulb is working and no air leaks along hose anywhere. Check function of fuel pump and ensure fuel is getting to the cylinders.
2. Overheating: Check engine isn't overheating and that water pump is operating properly while engine is running.
Sep 17, 2009 | Boating
Jun 25, 2009 | Boating
Boating Logo
55 people viewed this question
Top Boating Experts
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
