Question about Dishwashers
Is der a grease trap in a dishwasher.would it stop it from pumping the water in the spay arms plz help
  • 297 Answers
No there is not.if the arm is not working,most likely it is worn out.replace unit.
Posted on Jul 21, 2009
My new Samsung dishwasher has a HORRIBLE smell
There are 2 possible explanations for this, either the dishwasher has a buildup of food particles and grease in the pipes and pumps and that is starting to decay. Get a dishwasher cleaner and run it through a cycle. You can find several different brands, Finish seems pretty popular, at your local grocery store. The other possible source of the smell is sewer gas backing up into the dishwasher. This happens because the waste water connection from the dishwasher is linked into the pipes under the sink after the P-trap. Take a look under your kitchen sink, locate the connection where the dishwasher wastewater pipe connects to the sink pipes leading to the main stack. Now follow the pipes from the sink drain down there will be a P- trap that prevents sewer gas from backing up into the house, your dishwasher connection should be between those two. If your P-trap is between the dishwasher conncetion and the sink drain then you are getting swere gas flowing into your dishwasher and this is what you are smelling. If this is the case have a licensed plumber come in and reconfigure the pipes so the P-trap is after the dishwasher connection and the smell will stop. It shouldn't take a plumber long and the parts are cheap. Hope this helps.
Oct 10, 2017 | Samsung Dishwashers
How do you clean the pump filters?
Two possible problems
- You may have a problem with the water heater.
Tablet need to reach a given temperature to be dissolve
- Check if the water arm do turn ans spay water. To test, turn to a fix position, start the dishwasher and open after the the start of the cycle. Open the door and check the position of the arms.
If one of the arm is not turning, check the water holes One of them may be blocked
Oct 18, 2016 | Dishwashers
Mdc4650awb stopped working
Is it running to a point or not turning on at all. If it runs to the point when it should pump out the water and stops, then it's not the boards or electrical. I have found with dish washers that they need a good cleaning every 6 months. Dismantle the rotating arms, take out the parts underneath and remove the filters all the way to where the water enters the pump. There's often grease and blockages here. The rotating arms also get stuff forced through them that clogs the outlet holes, so dishes don't get as clean. I've found orange seeds jammed in the outlet holes that then swell up with the extra water. Hair gets in and traps grease and all kinds of stuff. I've found the plastic wrappers from dishwashing "pods" clogging the filters. You'll find everything from toothpicks to bits of bone people leave on their plates
Sep 30, 2014 | Maytag 24" Tall Tub Portable Dishwasher -...
Spray arm not turning on Bosch Tabletop S2R1B
The inside of the arms can get blocked, only if the water can move freely through them do they turn, cause by the water ejecting from the arms spay holes. Lift or pop the arm off its mount, its a push-click fit.
have a look inside it for debris like chicken bones and clean it out.
do the same for the socket the arm came off -check all tubes are clear.
Dec 14, 2013 | Bosch Dishwashers
1 spays not rotating, with water dribling from them. 2 water collecting base. program seems to run ok. filter and spray arms clean.
normally it is the chopper assembly next to the wash pump that could be clogged. But need the model number of the dishwasher before I can confirm.
Feb 10, 2011 | Whirlpool Dishwashers
Water is not spraying well while dishwasher is running. We had a service call and the technician cleaned a trap clogged with food near the water pump. I think the same thing happened but do not know how to...
You have to remove the sprayer arm, it's cover, and the cover underneath that located on the bottom of the dishwasher, inside the dishwasher. If you find a large amount of grease/food under these covers then you are not rinsing your dishes enough before placing in the washer.
The disposal unit in these units are nothing more than a cheap metal blade spinning over a metal grate. Anything tougher than a piece of cake and it's frosting runs the risk of breaking the gears that drives this.
Clean all the food/grease that you can access. Be careful while removing the gunk, I have found glass shards from broken dishes. Locate the disposal impeller and screen. It can be removed. Inspect it for damage and reinstall after cleaning.
Your water flow can be restricted if this is plugged.
Jul 03, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Top rack not cleaning properly, not sure if top spay arm is working ?
Ensure that the spray arm is movable. Inspect the spray holes in the top spray arm. If clogged, clean the openings. If no clog, position the spray arm in a certain position (e.g.: arms facing front and back). Then activate the dishwasher for a minute or so and open the door to determine if the spray arm has moved. If not, there may be an issue with the water feeding to the spray arm (typically via the water pump, etc.).
Feb 19, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Water is not reaching top spray arm.same problem about a year ago.took apart unit on bottom inside of dishwasher and removed build up;said it was because we have hard water.how can i fix it as it is of...
You're going to have to take the unit apart and clean the build-up again. Since you have hard water, it's recommeded that you use tablets instead of gel or liquid detergent. If you get a water softener, you'll have to use liquid. Good luck and sorry to hear about the hard water. I have the same thing here and it's no fun. Good luck :)
Jul 16, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore Elite dishwasher not cleaning well and leaving dark stains on the dishwasher walls. water pumps in to correct level and pumps out. First cup of soap the water is just warm. Second up its hot and...
Check the following to address this issue
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Jun 04, 2009 | Kenmore 24 in. 16049 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
