What does no source mean when we go to stricter scan
What does "there is no definite scintigraphic evidence for active hypermetabolic neoplastic disease" mean?
Hello Peggy
You should really be asking a physician rather than a bunch of amateurs on a site like this. It tells me that they used a radioactive dye (scintigraphic evidence) and injected it into you before or during the scan to light up your lungs from the inside. The results show there is no active disease (tumor).
is the physiological state of increased rate of metabolic activity and is characterized by an abnormal increase in the body's basal metabolic rate.
The word neoplasm, meaning new growth in Greek, refers to any abnormal growth, whether malignant or benign. Neoplastic disease refers to both malignant and benign growths. All types of cancer fall into the category of malignant neoplastic diseases.
So it is good, your lungs are clear of cancer :>)
The following may help you.
PET-CT scan results. What they mean?!?!?! ' Cancer Survivors Network 9, 2012 - Chest: Multiple mild to moderately hypermetabolic mediastinal and hilar lymph ... Diagnostic considerations include granulomatous disease, ... explanations ("diagnostic considerations"); "neoplasm not excluded" means they ...
What Does Hypometabolic Mean On A Pet Scan - Doctor insights on ... What does "hypermetabolic" mean on the report of a pet scan? ... 4. When a pet scan report says "no other evidence of metastatic disease." does ...
Medical Definition of Scintigraphy - MedicineNet > home > medterms medical dictionary az listScintigraphy: A diagnostic test in which a two-dimensional picture of a body radiation source is obtained through the use of radioisotopes.
scintigraphic evidence Google Search
there is no definite scintigraphic evidence for active hypermetabolic...
Apr 20, 2017 | Active Health & Beauty
How can I disable the security alarm without disabling my car?
you cant.!
the operators guide tells you how to disable the door alarms
but not how to bypass the IMMOBILIZER
that be by DESIGN.
not possible.
(car has security keys, right>? for the IMMO.,! cluster lamp)
if it was easy, all cars would be easy to steal now.
and are NOT.
a 21s century deal. here.
and in usa , the fed. LAW. (and stricter every year !)
what to do is scan PCM to find out what is failing!
or get car serviced
you have 2 choices
get it serviced
or buy the FSM book read the pages on alarm, scan it and do the tests stated in the book, i bet you wont read the book.
just 4 bucks to read it
then ask questions.
we can answer.
but yes, a great dream it was...... sorry.
Feb 02, 2016 | 2003 Suzuki XL-7
1999 Grand Cherokee at night when headlights are on the right brake light goes off when you apply the brakes
The 1999 Jeep Gran Cherokee has standard all-wheel antilock brakes. The new braking system has electronic brake distribution capability, which makes for a quieter, less pulsing and more balanced braking experience. Possessing the largest brake rotors in the sport-utility segment, the Grand Cherokee meets or exceeds requirements for passenger vehicles, which are stricter than those for light trucks. -----------------------------------------------------------------------------------------
Original Launch X431 Master
Mar 09, 2013 | 2004 Jeep Grand Cherokee
I have a x6650 series printer and I am trying to scan a document but it keeps telling me that it can't retrieve my application list. However it has already scanned something for me today and...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If your printer is connected via the USB cable, disconnect it from your computer. Reboot your computer. Unplug and re-plug your printer from the power source to reset it. When the printer turns on, reconnect it your computer. Try to scan again.
If the printer is wirelessly connected to the computer, check the status of the WiFi light. Green light means your printer is connected to your network. Orange means otherwise.
Jun 16, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
My M42onv Vizio TV is showing a no signal message. I have tried scanning for channels and it didn't work.
make sure your source is correct when I say source it means channel 1,2 ect and External and AV if it has freeview build in then all you need to do is press the source button on the remote and it will come up a menu scroll down until it says digital press enter then that should work if not make sure that your arial is properly plugged in
Feb 02, 2011 | Vizio Televison & Video
Flatbed scanners that can scan prints and transparences had two light sources.
One for normal prints (ie reflective light source, the light shines from under the glass to the print/photo and reflects off this print/photo to the optical sensor).
On a scanner that can scan transparences there is a second light source in the lid that shines through the transparences pass the glass to the optical sensor. The light source under the glass is not used in this case.
The scanning software automatically selects the right source when you select to scan prints or transparences.
Sep 06, 2009 | Umax Astra 6450 Flatbed Scanner
Can't find twain source
The Twain source is the Picture or Photo program First I do not think your Scanner will run on XP because i have one and i have tried the original drivers Second I got my scanner running on an old computer with Win 2000 and had to use two sets of drivers FB330P/FB630P & FB630U/Fb636V then I open MS Photo editor and Click on FILE then go down to select source and click on the second entry of the scanner the go FILE Scan Image If you not not have MS Photo editor it may work with other programs
Jan 24, 2009 | Canon CanoScan FB630U Flatbed Scanner
Unable to "communicate with TWAIN data source." ??
This may happen because of overload to memory. If all are ok and still this error comes up means, the twain driver takes more time to load. wait for some seconds and then click scan, it will go.
Try to clean the hard disk and defrag the drive.
Jun 02, 2017 | HP PSC 1315 All-In-One InkJet Printer
Can't Scan with MX310 hooked up to Time Capsule
If you mean you connected it to the airport, that only supporting printing, not scanning. Have to plug it into the computer.
Jul 02, 2008 | Canon PIXMA MX310 All-In-One Printer
